Shielding For a Horrendous Streetlight?
35 replies to this topic
#26 starcanoe
starcanoe
Posted 06 July 2018 - 11:37 AM
You really need to design a shade that will insert into the globe. It can be designed such that  the light can still leave the bulb and hit the area around the fixture but not allow any direct rays to hit your property.
Some aluminum sheet metal would be fine. Heck, you could probably cobble something together out a large aluminum beer can (you might want to sand off the paint on that one :) )
#27 csa/montana
csa/montana
    Den Mama & Gold Star Award Winner
  • Loc: montana
Posted 06 July 2018 - 01:56 PM
That would be fine, only if the utility company would install it; and they may not allow it.
  • Poynting likes this
#28 xiando
xiando
  • Loc: Cloudy NEOhio
Posted 06 July 2018 - 02:11 PM
It is exactly what it looks like, a few pieces of tape didn't help much at all. At least they did something. I guess I can request more pieces of tape.
I would again urge you to take matters into your own hands a build a simple two pole "banner-style" light shield, fill a couple of 5 gallon pails with sand to act as bases for the poles, and haul them and the banner out to your yard as needed to block the light.
  • SeaBee1 likes this
#29 starcanoe
starcanoe
Posted 06 July 2018 - 02:33 PM
They had no trouble wrapping the bulb with tape. That just decreases the light going in all directions. And it probably causes the bulb to over heat. For that matter it might catch fire.
If they will DO THAT shortly after being asked to do something about the light it seems to me they wouldn't have any trouble putting something in there that doesn't decrease the light in every direction, won't cause the lamp to overheat, won't catch fire (or melt), and actually works.
Of course, such a thing needs to be designed so better specs on the lamp and the geometry of the whole situation needs to be accounted for to design such a shield properly.
Edited by starcanoe, 06 July 2018 - 02:34 PM.
#30 Poynting
Poynting
  • Loc: Orlando, FL
Posted 06 July 2018 - 02:46 PM
There is a clear cylinder around which the bulb is inserted that the tape was placed on. I will consider this and ask them though. Worst case they say no. I would like the shielding option not only for observing, but also for the light reaching my windows at night.
Thank you, I am considering how to implement this, as it seems innocuous to the lamp and could provide perfect shielding as needed. Also cheap!
#31 xiando
xiando
Posted 06 July 2018 - 03:00 PM
a pair of plastic coated garden poles (from a real gardening store in onesey twoseys, online for bulk, but not home depot et al afaik, I've checked and they don't carry them)
like the dark green ones shown here (below the ads section in the images area of the query page)  https://www.bing.com...poles&FORM=IGRE
They're about 3/4" in diameter and can be purchased in heights from ~4ft tall to 8ft tall. Cost is insignificant ~$5-10 each.
(last time I purchase some 7 footers they were $5 each. basically just conduit with a plastic coating, a flat section for hitting with a mallet, and a conical tip for driving into a soft substrate. Plenty durable for the purpose.
A small section of standard ~opaque, ripstop plastic tarp (brown would be a good unobtrusive color) . A 6'x8' costs all of ~$10 and you'd only need a ~2ft x 2ft section if you put the banner "upwind" of the scope between it and the light source... (nearer requires larger sections...)
2ea 5 gallon pails (home depot, etc)
a couple bags of play sand or something else the poles can be sunk into when assembled.
a grommet kit (for modifying the section of tarp) ~$350 at walmart
some stout rope/twine etc for attaching the "banner" to the top of the poles or bungy cords (wallmart has bags of them in the camping section  for<$5)
pails with sand stay intact and carry from/back to garage.
poles with banner stay intact as set.
Assembly is easy. Just set pails at spread distance, unfurl banner (already on poles)  and then stick poles into each.
First time out, adjust height of banner for optimal shielding. Mark poles so you can easily set again if necessary.
Dis-assembly is just as easy.
or however you figure the solution. point is, targeted shield works. Even if not ideal or permanent.
Edited by xiando, 06 July 2018 - 03:06 PM.
#32 spacemunkee
spacemunkee
  • Loc: Cincinnati, Ohio
Posted 06 July 2018 - 03:01 PM
I don't see the tape lasting anyway even if it did help. Likely dry out and peel away.
How about making a widely tapered cone out of some sheet metal to sit on the bulb to try and reflect the light downward. Could be slightly tilted away from your direction and leave a small opening at the top to let some light hit the top of the globe to still be aesthetically pleasing. Paint the outside of it black if need be.
#33 gnowellsct
gnowellsct
Posted 06 July 2018 - 03:46 PM
A 5 gallon bucket would probably do the trick. Is it all HOA? I hope you get a solution soon my friend!
Zactly put bucket up when observing take it down when done. Or a big paper bag. Not plastic.
  • ThermalSeeker likes this
#34 Poynting
Poynting
  • Loc: Orlando, FL
Posted 06 July 2018 - 03:49 PM
I don't own this lamp, so I don't feel comfortable doing these, especially with a cop living on the street. The paper bag idea is the least worrisome, but I then block light to everyone, which has its potential problems.
  • csa/montana likes this
#35 spacemunkee
spacemunkee
Posted 06 July 2018 - 04:10 PM
I wasn't condoning installing yourself but see if you can coordinate with them and have them install an acceptable shade you make. Sounds like they are agreeable to help asap by promptly installing some unsightly tape on it.  As far as the cop he may not like the lights either.. Most I've known are just like you and I until they have to put that badge on in the morning.smile.gif
If I could only do something about my near neighbor with his 20 foot high leds lighting up his yard like a sports complex for his late night partying and cornhole games. frown.gif
#36 MiguelStrongEye
MiguelStrongEye
  • Loc: 80113 Colorado
Posted 11 July 2018 - 04:54 PM
Hope that works for you.
i wound up taking my neighbor into a zoning hearing before they’d do anything, and I was willing to do the work and supply the materials.
i was put on “probation” in college for installing switches in the j-boxes feeding a couple of particularly egregious offenders.
fortunately around here most munis are being pretty serious about light pollution.
Edited by MiguelStrongEye, 11 July 2018 - 04:55 PM.
