ASTAP on the J4125 takes about 4-5 seconds to solve. ASTAP is like 10 times faster that everything else I have tried.
Chris
I'm not sure what you are timing and calling being solved, but on my GigaByte BRIX-S running a Gemini Lake, quad-core J4105 processor I can solve a field taken with my 384mm focal length 80mm refractor in about five seconds using PlateSolve2 from within Sequence Generator Pro (SGP). But, that time does NOT include the base exposure time nor the download from the camera for a 20 mega pixel sensor and those two steps actually take just as long (or longer) than the plate solve itself. Plus, that's for a single solve and typically I need to make at least one additional mount move to get within the ten pixel tolerance (about 13 arc seconds) that I've set for centering.
Thus, given the mount move (for final centering, a few seconds), the exposure time (about 2s for broadband), the download by SGP (4s), and the solve by PlateSolve2 (5s) it usually takes about 15 to 20 seconds for any single plate solve sequence. But, only 5 seconds of that time is taken by the "solve" itself. But, as I mentioned earlier it usually takes two sequences to get within my ten pixel tolerance so the entire process usually takes something like forty seconds (or longer, depending upon the base exposure time).
Frankly, I think a good part of this time is just the overhead from using SGP, which tends to be a pretty slow application.
Edited by james7ca, 20 November 2021 - 06:30 AM.
