Cosmic Challenge: Dissecting M101
#1
Posted 01 July 2018 - 05:30 AM
Click here to view the article
- Lewis Cason, okiestarman56 and cookjaiii like this
#2
Posted 03 July 2018 - 09:38 PM
But with time and patience, M101 is visible, with difficulty, through 50-mm binoculars even given a suburban sky with a naked-eye limiting magnitude of perhaps 4.5.
Hi, Phil! What Bortle number would you estimate those kinds of skies at? I live in the city under hard Bortle 9 skies, but reach limiting magnitudes of ~5.0-5.5.
I set up my 15x70 binoculars + parallelogram mount last night to search for M101, but got no convincing hints. I was able to barely, with effort, see M51, and in a brief moment of clarity saw a mag 11.5 star pop a time or two. The transparency was not the best, but good for summer (I live in Houston so there's tons of gulf moisture). The skyglow was bright enough that I was able to see plainly into the deepest shadows under the trees 50' away, and the sky was the color of a planetary nebula overhead and in the direction of Ursa Major, simultaneously blue and green. Towards the horizon or my many light domes it turned tan. I will keep trying for M101 under hopefully better conditions.
Clear Skies!
Lauren Herrington
- Augustus likes this
#3
Posted 04 July 2018 - 09:32 PM
I’m sure under pristine unpolluted skies that M101 is visible with instruments under 100mm. I was checking my observer’s log from last year around this time and viewed the sketch with my 8” at about 70x. It was a barely discernible irregular grey patch only marginally lighter than the background. More magnification did not produce meaningful detail and certainly nothing like the structure Phil sketched with his 18”. I live in a Bortle 5 zone and took an SQM reading of the area which yielded a reading of 20.35. I typically have good-excellent transparency.
- Tyson M and TieDyeAstronomer like this
#4
Posted 05 July 2018 - 07:48 PM
Hey Chesterguy1! Thanks for sharing your report!
Definitely! I've been able to see it quite "easily" (for a deep sky object) in my 15x70 binoculars from a Bortle 3-4 site, and one where the big light dome is to the North too, so not the best for M101. But having such a low surface brightness, it sure does get wiped out fast. I bet it would be a bigger struggle from my club's Bortle 4.5 dark site.
Clear Skies!
Lauren Herrington
#5
Posted 06 July 2018 - 07:58 AM
Hi Tie:
For me, it's always a better target this time of year: high in the sky, more north/northwest and away from the small light dome of my city, which for me is NE. It's still a tough target and even with my 15" it reveals little structural detail from my admittedly suburban zone. It is, of course, much easier to find with the 15" (although I would never classify it as easy from my locale). What I can see readily--but is more elusive in the 8" are the nearby NGC galaxies, 5473 and 5474. I cannot see 5477. Thus, the galaxies Phil sees within the structure of M101 are simply not possible unless I go to a much darker site.
Gogiboy
- PhilH likes this
#6
Posted 07 July 2018 - 02:27 PM
I can sweep up M101 fairly easily with my Celestron 8x42s from a really good dark site.
Dave Mitsky
#7
Posted 07 July 2018 - 02:32 PM
M101 and its HII regions can be quite spectacular through a large aperture from a pristine site.
http://www.robgendle...m/M101text.html
http://messier.seds.org/m/m101.html
Here's an image that I captured years ago using the BRT.
M101 (The Pinwheel Galaxy)
2/22/2013
14" f/11 Celestron C14 SCT working at f/5.3
FLI MicroLine CCD camera
100 seconds
Bradford Robotic Telescope
http://www.telescope.org/
Tenerife, the Canary Islands
Dave Mitsky
- PhilH and John O'Hara like this
#8
Posted 13 July 2018 - 08:45 PM
Great article, Phil!
- Dave Mitsky and PhilH like this
#9
Posted 28 July 2018 - 03:02 PM
of 8,000 feet on the North Rim of the Grand canyon during new
moon in June. I observed it through a 20" f/4.5 reflector owned by
Steve Dodder of the Saguaro Astronomy Club, who host a week
long star party at the North Rim each year as an outreach event
in conjunction with the North Rim Lodge and the Park Service.
Through the 20-inch using a 14mm 82 degree eyepiece (150X)
M-101 looked exactly like Dave Mitsky's astrophoto, above.
ALL of the H-II and star-forming knots in the spiral arms
were clearly visible. With averted vision, even the faintest
knots shown in Dave's photo were visible. This was the finest
view of M-101 I have ever had, and will remain one of my
greatest moments at the eyepiece of a telescope. The skies
at 8,000 feet were incredibly dark, with so many stars that the\
constellations were hard to pick out! M-101 was AWESOME!!
Ron Abbott
#10
Posted 30 July 2018 - 10:01 PM
I never knew these NGC regions existed inside M101. I just discovered the pinwheel spiral arm structure for the first time this year with my 8" dob from a dark site. I know now to bump up the magnification for closer scrutiny!
Also I found this galaxy easy to sweep up with the 10 x 50 binos from my dark site.
Thanks for the article
- PhilH likes this
