FireCapture Debayering
5 replies to this topic
#1 roelb
roelb
  • Loc: Belgium, Antwerp
Posted 11 July 2018 - 05:31 PM
I have a strange behavior with FC.
When recording with debayer off, the bayered capture color looks "pink".
Didn't have with previously sessions and it happens not always.
First x captures look good and suddenly the problem arises.
Is their somebody who experienced a similar behavior?
Thanks in advance.
#2 TorstenEdelmann
TorstenEdelmann
  • Loc: Landsberg, Germany
Posted 11 July 2018 - 11:29 PM
Roel,
One explanation would be that maybe for unknown reason the ROI offset position is shifted by on pixel in x or y so the recording is not bayer-safe anymore meaning you'd need to use another than your standard debayer pattern during stacking. FC tries to keep your ROI bayer-safe on all operations (moving, resizing etc.) but given the fact how buggy this piece of software is I wouldn't bet my life on it wink.gif  If I remember correctly the ROI offset is written to the log so maybe it's worth checking your capture logfiles for ROI x/y offsets not multiple of 2. You can send them via PM or email if you like and I'll have a look.
Torsten
  • dan777, RedLionNJ and roelb like this
#3 TorstenEdelmann
TorstenEdelmann
Posted 14 July 2018 - 02:02 AM
Roel,
I checked your logs and ROI offset looks good from what I can tell. I don't see and odd-numbered x/y positions. Another point to mention: if the color looks wrong in AutoStakkert go to the color menu and choose one of the "Force..." entries until the color looks ok in the frame view. Depending on data the "Automatic" bayer detection in AS could be wrong so you need to select the correct bayer pattern yourself in the color menu. If you ever have the case that you need to select 2 different bayer patterns for the same camera when stacking your data than FC propably shifted the ROI offset wrongly. If you (or others) can reproduce this I'd be interested in getting the instruction so I can fix. So far this never happened to me.
Torsten
#4 roelb
roelb
Posted 14 July 2018 - 04:16 AM
I did the forced debayering in AutoStakkert. For one capture GBRG, for another capture GRBG was needed.
#5 roelb
roelb
Posted 14 July 2018 - 04:19 AM
Oh, both captured with same ASI224MC.
#6 TorstenEdelmann
TorstenEdelmann
Posted 14 July 2018 - 05:24 AM
Sorry no explanation so far. If you ever know how this happens in FC let me know.
Torsten
