Repair of the base of a Meade DS2105 MAK
Meade Maksutov
1 reply to this topic
#1 zanxion72
zanxion72
Posted 12 July 2018 - 06:49 AM
I have been given a Meade DS2105 MAK optical tube. It is in fair condition with its mirror and front lens in excellent condition. The problem with it is that it is way out of collimation. I have removed the back and tried to collimate it, but there is a problem with the screws. They have striped the plastic and they won't stay put. With he faintest knock it gets out of collimation again. What can I do? What do you recommend? I thought of using larger screws, but sooner or later they will wear the plastic. Has anyone had any similar problem?
#2 zanxion72
zanxion72
Posted 23 July 2018 - 01:11 AM
Finally, I got it fixed in a really rough way using screws from here and there. It was collimated equally roughly in a visual way from the back of the tube centering everything as much possible. It is usable, but it needs further collimation as the views are not as sharp as before, for example, yesterday the bands on Jupiter were not clearly visible using he 26mm super plossl.
Also tagged with one or more of these keywords: Meade, Maksutov
