Rolling bars in ASI120mm
9 replies to this topic
#1 StarmanDan
StarmanDan
  • Loc: Deep in the heart of Texas
Posted 12 July 2018 - 09:27 PM
I purchased a ZWO ASI120MM last week from a CN member and have been checking it out.  I'm having issues with rolling bars running across the image when used in "live" mode.  I've tried two different laptops (both win xp and win7), updated drivers on both the computers and camera, different cables, ran the lappys with just the battery and plugged in the wall but I can't get the bars to go away.  Any ideas before I have to return it?
#2 GA-HAMAL
GA-HAMAL
  • Loc: Poland
Posted 13 July 2018 - 01:00 AM
#3 StarmanDan
StarmanDan
Posted 13 July 2018 - 08:04 AM
I've tried it both at work and home. Same result.
#4 syyntax
syyntax
  • Loc: Acworth, GA
Posted 13 July 2018 - 09:38 AM
Try in USB 2.0 if you haven't already.
#5 mikefulb
mikefulb
Posted 13 July 2018 - 10:06 AM
If you are using AC powered lights for illumination and using a short exposure due to the brightness compared to astronomical conditions I think you are just picking up the 60HZ nature of the power source.
Try testing using sunlight for illumination.
#6 StarmanDan
StarmanDan
Posted 13 July 2018 - 10:48 AM
Syyntax, my lappys have usb2 on them. Tried a usb3 hub thinking maybe the usb2 might not have enough power or bad power on the ports. Still no effect.
Mikeflb, the bars only become apparent when using shorter exposures needed for "live" frame rates. As I plan to use this for planetary as well as for guiding, I'm concerned how the bars will affect planetary work.
#7 mikefulb
mikefulb
Posted 13 July 2018 - 11:45 AM
You are most likely seeing the AC powered lights going on and off 60 times a second. Use sunlight or a DC light source.
#8 StarmanDan
StarmanDan
Posted 13 July 2018 - 11:54 AM
So I've tried outside and the bars appear to have gone away.  Hope it's just the lights.  Need to try outside tonight as I've noticed that the bars do get smaller with faster exposures and with exposures longer than half a second, the bars likely get smeared across the image as to not be detectable.
#9 StarmanDan
StarmanDan
Posted 13 July 2018 - 12:14 PM
Yep, I feel dumb. Turned off the lights and bars go away. I keep forgetting everything is CFL lights now. Stupid me. Thanks yall!
#10 mikefulb
mikefulb
Posted 13 July 2018 - 01:48 PM
Trust me the first time I saw them I was dumbfounded.  :)
What is more insidious is if you use a light panel with PWM for dimming as a flat box and take some short flats...
