AL Herschel II. 400 objects project. 8" SCT using RT IMX224
399 replies to this topic
#376 S1mas
S1mas
  • Loc: Lithuania
Posted 14 April 2019 - 04:15 PM
#332 and #333 targets are very low
9x30s  Observed in Sharpcap 3.2. Saved as viewed.
NGC 5595 and NGC 5597 are a pair of faint galaxies separated by 4 arc minutes. The northwest object is the Sc spiral NGC 5595 with faint halo and a somewhat brighter circular core with a stellar nucleus.
NGC 5597 is to the southeast and is somewhat fainter. It is a Sb spiral with an elongated halo and a dim stellar nucleus.
  • Starman27, eros312, roelb and 2 others like this
#377 S1mas
S1mas
  • Loc: Lithuania
Posted 14 April 2019 - 04:22 PM
#334 target is very low
NGC 5728 is a Sb spiral grouped with NGC 5716. It has a fairly bright halo with broad central brightening. The core is prominent, and the nucleus contains two stellar points.
  • Starman27, roelb, makeitso and 1 other like this
#378 S1mas
S1mas
  • Loc: Lithuania
Posted 14 April 2019 - 04:28 PM
#335 target is very low
NGC 5791 is a Sa spiral galaxy. It has a bright stellar nucleus embedded in a small round core and an irregular halo. It is paired with the galaxies IC 1077 and IC 1081.
  • roelb, makeitso and Steph_2.0 like this
#379 S1mas
S1mas
  • Loc: Lithuania
Posted 14 April 2019 - 04:34 PM
#336 target is very low
NGC 5878 is a Sb spiral with a diffuse mottled disk. A fairly bright halo contains a small oval core with a stellar nucleus. The halo is unevenly concentrated near the core.
#380 S1mas
S1mas
  • Loc: Lithuania
Posted 14 April 2019 - 04:41 PM
#337 target is very low
NGC 5861 is a 11th magnitude Spiral Galaxy appearing in the constellation Libra. It is 79 million light years from our solar system.
NGC 5861 appears roughly 2.8 x 1.1 arcminutes in size, corresponding to a physical diameter of 63638 light years. It is a spiral galaxy of morphological type SABc, and is receding at 1859 kilometers per second - about 0.6% of light speed.
#381 S1mas
S1mas
  • Loc: Lithuania
Posted 14 April 2019 - 04:48 PM
#338 target is very low
NGC 5812 is a 11th magnitude Elliptical Galaxy appearing in the constellation Libra. It is 87 million light years from our solar system.
NGC 5812 appears roughly 2.7 x 2.3 arcminutes in size, corresponding to a physical diameter of 67378 light years. It is an elliptical galaxy of morphological type E, and is receding at 1917 kilometers per second - about 0.6% of light speed.
#382 S1mas
S1mas
  • Loc: Lithuania
Posted 14 April 2019 - 04:53 PM
#339 target is very low
NGC 5427 is Sc spiral interacting with NGC 5426. This pair of interacting galaxies is separated by about 2 arc minutes north to south. The northern system, NGC 5427, is the larger and brighter of the two. It is slightly elongated and contains a bright core with a stellar nucleus.
NGC 5426, the southern component, has a moderately faint halo and an extended core with a faint stellar nucleus. A 13th magnitude star is superimposed upon the halo of NGC 5426.
#383 Rickster
Rickster
  • Loc: NC Kansas Bortle 3 SQM 21.8+
Posted 15 April 2019 - 02:22 PM
Simas,  Kudos on your perseverance.  You are getting close to the finish line.  This is going to be a nice "catalog" for others to use.
I was looking at one of your videos and see that you have a wide angle camera monitoring your scope.  I want to add a similar camera to my set up.  But I use a dark location, so it would take a very sensitive camera.  If I remember correctly, you also use a dark location.  So I am curious to know how you are getting such a good image of your scope.  Which camera/lens are you using?  Are you using any illumination of the scope?
#384 S1mas
S1mas
  • Loc: Lithuania
Posted 16 April 2019 - 11:38 AM
Hi Rick, camera itself has12 those micro IR lamps to illuminate nearby, up to 20 meters, objects. It was quite cheap:
https://www.aliexpre....27424c4dYsg7GN
#385 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 02:44 PM
#340 target is very low
11x30s  Observed in Sharpcap 3.2. Saved as viewed.
NGC 5668 is a Sc spiral with a small faint nucleus. In larger telescopes NGC 5668 is weakly concentrated. Its broad, mottled core is just slightly brighter than its outer halo, which is about 2 arc minutes in diameter.
Edited by S1mas, 21 April 2019 - 02:44 PM.
#386 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 02:50 PM
#341 target is very low
15x30s  Observed in Sharpcap 3.2. Saved as viewed.
NGC 5775 is a Sb spiral paired with nearby NGC 5774. It has a thin, long core with faint extensions making the galaxy's total length about 4 arc minutes. Its companion galaxy, NGC 5774, is a dwarf system. It is much fainter with a faint elongated halo.
Edited by S1mas, 21 April 2019 - 02:51 PM.
  • eros312, roelb, makeitso and 1 other like this
#387 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 02:57 PM
#342 target is very low
16x30s  Observed in Sharpcap 3.2. Saved as viewed.
NGC 5638 is a 11th magnitude Elliptical Galaxy appearing in the constellation Virgo. It is 85 million light years from our solar system.
NGC 5638 appears roughly 1.9 x 1.7 arcminutes in size, corresponding to a physical diameter of 47737 light years. It is an elliptical galaxy of morphological type E, and is receding at 1657 kilometers per second - about 0.6% of light speed.
Edited by S1mas, 21 April 2019 - 03:03 PM.
#388 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 03:16 PM
#343 and #344 target is very low
Object lower:
NGC 5506 is a 11th magnitude Spiral Galaxy appearing in the constellation Virgo. It is 92 million light years from our solar system.
NGC 5506 appears roughly 2.9 x 0.8 arcminutes in size, corresponding to a physical diameter of 77205 light years. It is a spiral galaxy of morphological type SABa, and is receding at 1819 kilometers per second - about 0.6% of light speed.
Object higher:
NGC 5507 is a 12th magnitude Spiral Galaxy appearing in the constellation Virgo. It is 92 million light years from our solar system.
NGC 5507 appears roughly 1.6 x 0.8 arcminutes in size, corresponding to a physical diameter of 42862 light years. It is a spiral galaxy of morphological type S0, and is receding at 1824 kilometers per second - about 0.6% of light speed.
#389 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 03:29 PM
#345 target is very low
NGC 5493 is a 11th magnitude Spiral Galaxy appearing in the constellation Virgo. It is 132 million light years from our solar system.
NGC 5493 appears roughly 2.2 x 1.9 arcminutes in size, corresponding to a physical diameter of 83204 light years. It is a spiral galaxy of morphological type S0, and is receding at 2695 kilometers per second - about 0.9% of light speed.
#390 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 03:41 PM
#346 target is very low
NGC 5750 is a 11th magnitude Spiral Galaxy appearing in the constellation Virgo. It is 84 million light years from our solar system.
NGC 5750 appears roughly 2.6 x 1.4 arcminutes in size, corresponding to a physical diameter of 65133 light years. It is a spiral galaxy of morphological type S0-a, and is receding at 1660 kilometers per second - about 0.6% of light speed.
  • eros312, makeitso and Steph_2.0 like this
#391 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 03:52 PM
#347 target is low
NGC 5806 is a Sb spiral paired with nearby NGC 5813 and NGC 5814. It is the easternmost member of the NGC 5856 group, a cluster of galaxies scattered over one degree of sky near the 4th magnitude star 110 Virginis.
NGC 5806 appears rather faint, and its 2 arc minutes halo contains a moderately concentrated core in which is embedded a faint stellar nucleus.
#392 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 04:03 PM
#348 target is low
NGC 5813 an E1 elliptical galaxy paired with NGC 5814. NGC 5813 is a bright galaxy with a 1.5 arc minute halo that contains a small bright core and a sharp nonstellar nucleus.
It is a member of the NGC 5846 group, a cluster of galaxies scattered over one degree of sky near the 4th magnitude star 110 Virginis. NGC 5814 is 5 arc minutes southeast of NGC 5813.
#393 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 04:15 PM
#349 target is low
NGC 5838 is a 10th magnitude Elliptical Galaxy appearing in the constellation Virgo. It is 67 million light years from our solar system.
NGC 5838 appears roughly 3.9 x 1.3 arcminutes in size, corresponding to a physical diameter of 75908 light years. It is an elliptical galaxy of morphological type E-S0, and is receding at 1252 kilometers per second - about 0.4% of light speed.
#394 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 04:27 PM
#350 target is low
NGC 5831 is a 11th magnitude Elliptical Galaxy appearing in the constellation Virgo. It is 88 million light years from our solar system.
NGC 5831 appears roughly 2.2 x 2.0 arcminutes in size, corresponding to a physical diameter of 56952 light years. It is an elliptical galaxy of morphological type E, and is receding at 1631 kilometers per second - about 0.5% of light speed.
#395 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 04:38 PM
#351 target is low
NGC 5850 is a Sb barred spiral. It is located 10 arc minutes southeast of NGC 5846. With a stellar nucleus, NGC 5850 has a bright circular core surrounded by a much fainter diffuse halo.
#396 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 04:51 PM
#352 target is low
NGC 5854 is a 11th magnitude Spiral Galaxy appearing in the constellation Virgo. It is 90 million light years from our solar system.
NGC 5854 appears roughly 3.0 x 0.7 arcminutes in size, corresponding to a physical diameter of 79119 light years. It is a spiral galaxy of morphological type S0-a, and is receding at 1730 kilometers per second - about 0.6% of light speed.
#397 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 04:56 PM
#353 target is low
NGC 5864 is an E7 ellipical galaxy with a with small elongated nucleus.
It is located northeast of the NGC 5846 galaxy group and is that cluster's most isolated member.
Edited by S1mas, 21 April 2019 - 04:59 PM.
#398 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 05:10 PM
#354 target is low
NGC 6106 is a 12th magnitude Spiral Galaxy appearing in the constellation Hercules. It is 78 million light years from our solar system.
NGC 6106 appears roughly 2.2 x 1.2 arcminutes in size, corresponding to a physical diameter of 49508 light years. It is a spiral galaxy of morphological type Sc, and is receding at 1450 kilometers per second - about 0.5% of light speed.
#399 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 05:19 PM
#355 target is low
16x20s  Observed in Sharpcap 3.2. Saved as viewed.
NGC 6070 is a 11th magnitude Spiral Galaxy appearing in the constellation Serpens. It is 85 million light years from our solar system.
NGC 6070 appears roughly 3.5 x 1.8 arcminutes in size, corresponding to a physical diameter of 86446 light years. It is a spiral galaxy of morphological type Sc, and is receding at 2003 kilometers per second - about 0.7% of light speed.
#400 S1mas
S1mas
  • Loc: Lithuania
Posted 21 April 2019 - 05:26 PM
Here will be a break till August, when another portion of targets will be reachable.
  • eros312 likes this
