AL Herschel II. 400 objects project. 8" SCT using RT IMX224
399 replies to this topic
#101 S1mas
S1mas
  • Loc: Lithuania
Posted 14 October 2018 - 05:14 PM
#81
30x30s
NGC 514 is a 11th magnitude Spiral Galaxy appearing in the constellation Pisces. It is 85 million light years from our solar system.
NGC 514 appears roughly 3.5 x 2.5 arcminutes in size, corresponding to a physical diameter of 86980 light years. It is a spiral galaxy of morphological type SABc, and is receding at 2471 kilometers per second - about 0.8% of light speed.
  • Starman27, eros312, roelb and 1 other like this
#102 S1mas
S1mas
  • Loc: Lithuania
Posted 15 October 2018 - 03:08 PM
#82
25x30s
NGC 6824 is a 12th magnitude Spiral Galaxy appearing in the constellation Cygnus. It is 182 million light years from our solar system.
NGC 6824 appears roughly 1.9 x 1.4 arcminutes in size, corresponding to a physical diameter of 101414 light years. It is a spiral galaxy of morphological type Sab, and is receding at 3544 kilometers per second - about 1.2% of light speed.
  • roelb likes this
#103 S1mas
S1mas
  • Loc: Lithuania
Posted 17 October 2018 - 03:03 PM
#83
25x30s
NGC 1605 is a faint group of 40 stars of 13th magnitude and fainter. The cluster lies between two loose groups of brighter field stars.
  • roelb likes this
#104 S1mas
S1mas
  • Loc: Lithuania
Posted 17 October 2018 - 03:14 PM
#84
10x30s
NGC 1582 is a 7th magnitude Open Cluster appearing in the constellation Perseus. It is 3588 light years from our solar system.
NGC 1582's apparent size is approximately 24.0 arcminutes, corresponding to a physical diameter of 25 light years.
  • Starman27 and roelb like this
#105 S1mas
S1mas
  • Loc: Lithuania
Posted 17 October 2018 - 03:38 PM
#85
15x30s
NGC 7600 is a 11th magnitude Elliptical Galaxy appearing in the constellation Aquarius. It is 161 million light years from our solar system.
NGC 7600 appears roughly 2.1 x 1.0 arcminutes in size, corresponding to a physical diameter of 97434 light years. It is an elliptical galaxy of morphological type E-S0, and is receding at 3441 kilometers per second - about 1.1% of light speed.
#106 S1mas
S1mas
  • Loc: Lithuania
Posted 31 October 2018 - 01:41 PM
#86
25x30s
The Crescent Nebula ( part ), NGC 6888 or Caldwell 27, is an emission nebula in the constellation Cygnus.
  • Ptarmigan, Starman27, saguaro and 2 others like this
#107 S1mas
S1mas
  • Loc: Lithuania
Posted 31 October 2018 - 03:09 PM
#87
25x30s
Sometimes called the Iris Nebula, NGC 7023 is about 6 light-years across, and 1,300 light-years away. Within the Iris, dusty nebular material surrounds a massive, hot, young star in its formative years.
  • Starman27, saguaro and roelb like this
#108 S1mas
S1mas
  • Loc: Lithuania
Posted 31 October 2018 - 03:21 PM
#88
10x30s
NGC 7067 is a 9th magnitude Open Cluster appearing in the constellation Cygnus. It is 12 thousand light years from our solar system.
NGC 7067's apparent size is approximately 6.0 arcminutes, corresponding to a physical diameter of 20 light years.
#109 S1mas
S1mas
  • Loc: Lithuania
Posted 31 October 2018 - 03:32 PM
#89
10x30s
NGC 7082 is a 7th magnitude Open Cluster appearing in the constellation Cygnus. It is 4703 light years from our solar system.
NGC 7082's apparent size is approximately 25.0 arcminutes, corresponding to a physical diameter of 34 light years.
#110 S1mas
S1mas
  • Loc: Lithuania
Posted 31 October 2018 - 03:57 PM
#90
25x30s
NGC 7129 is a Bright Nebula appearing in the constellation Cepheus.
NGC 7129 appears roughly 2.0 x 2.0 arcminutes in size.
#111 S1mas
S1mas
  • Loc: Lithuania
Posted 31 October 2018 - 04:17 PM
#91
19x30s
NGC 7139 is a very faint, moderately large, circular, grey smudge with a somewhat brighter center and diffuse edges. The halo, 45' in diameter, is about the size of Jupiter's disk. A 13th magnitude star is 1' SE of the planetary's center. To the east is a triangle of stars, from the southern vertex of which a string of stars curve southwest.
NGC 7139 appears moderately faint, quite, large, and round with uniform brightness. An O-III makes the periphery more distinct. A 13.5 magnitude star touches the NE edge, and a pair of 14th magnitude stars lies 1' NW.
#112 S1mas
S1mas
  • Loc: Lithuania
Posted 31 October 2018 - 04:58 PM
#92
25x30s. Through thick mist.
NGC 660 is one of only about 10 polar ring galaxies that are known. It is classified as a Sa barred spiral, but it believed to have formed from the collision of two galaxies in the past.
Our perspective of NGC 660 is inclined from the axis of the disk so that the foreground portion of the ring does not cross the plane in the center, but towards one side. The central region of this galaxy is considered a "starburst" region due to the extreme amount of star formation. NGC 660 galaxy is estimated to be 24 million light years away.|
  • Starman27, eros312 and roelb like this
#113 S1mas
S1mas
  • Loc: Lithuania
Posted 07 November 2018 - 07:20 PM
#93
25x30s
NGC 2023 is a 10th magnitude Bright Nebula appearing in the constellation Orion. It is 1533 light years from our solar system.
NGC 2023 appears roughly 10.0 x 10.0 arcminutes in size, corresponding to a physical diameter of 4 light years.
#114 S1mas
S1mas
  • Loc: Lithuania
Posted 16 November 2018 - 05:58 PM
#94
25x30s
NGC1977. The beautiful grouping of reflection nebulae NGC 1973, NGC 1975, and NGC 1977 in Orion are often overlooked in favor of the better known Orion Nebula (M 42). But this bright nebulous complex is interesting in its own right, being one of the brightest reflection nebulae in the sky.
  • Starman27, saguaro, roelb and 1 other like this
#115 S1mas
S1mas
  • Loc: Lithuania
Posted 16 November 2018 - 06:17 PM
#95
25x30s
NGC 2071 is a 8th magnitude Bright Nebula appearing in the constellation Orion. It is 554 light years from our solar system.
NGC 2071 appears roughly 4.0 x 3.0 arcminutes in size, corresponding to a physical diameter of 1 light years.
#116 S1mas
S1mas
  • Loc: Lithuania
Posted 16 November 2018 - 06:57 PM
#96
25x30s
NGC 1637 is relatively bright. Its 3' x 2' NNE-SSW halo contains a circular core with a stellar nucleus. A 13th magnitude star lies 2' NE of the center.
The halo is unevenly bright with hints of spiral structure in the NE and SE portions. The core is moderately large but unevenly bright and has a stellar nucleus.
  • Starman27, Stargazer3236, roelb and 1 other like this
#117 S1mas
S1mas
  • Loc: Lithuania
Posted 25 November 2018 - 06:45 PM
#97
40x15s
NGC 1032 is a 11th magnitude Spiral Galaxy appearing in the constellation Cetus. It is 124 million light years from our solar system.
NGC 1032 appears roughly 3.6 x 0.9 arcminutes in size, corresponding to a physical diameter of 129670 light years. It is a spiral galaxy of morphological type S0-a, and is receding at 2727 kilometers per second - about 0.9% of light speed.
  • Starman27, eros312, OleCuss and 1 other like this
#118 S1mas
S1mas
  • Loc: Lithuania
Posted 25 November 2018 - 07:13 PM
#98
40x5s
NGC 2112 is a 9th magnitude Open Cluster appearing in the constellation Orion. It is 3066 light years from our solar system.
NGC 2112's apparent size is approximately 18.0 arcminutes, corresponding to a physical diameter of 16 light years.
  • Starman27, OleCuss and roelb like this
#119 S1mas
S1mas
  • Loc: Lithuania
Posted 25 November 2018 - 07:34 PM
#99
20x30s
NGC 1762 is a 12th magnitude Spiral Galaxy appearing in the constellation Orion. It is 334 million light years from our solar system.
NGC 1762 appears roughly 1.8 x 1.1 arcminutes in size, corresponding to a physical diameter of 169976 light years. It is a spiral galaxy of morphological type Sc, and is receding at 4752 kilometers per second - about 1.6% of light speed.
#120 S1mas
S1mas
  • Loc: Lithuania
Posted 27 November 2018 - 02:05 PM
#100
20x30s
NGC 7785 is a 11th magnitude Elliptical Galaxy appearing in the constellation Pisces. It is 184 million light years from our solar system.
NGC 7785 appears roughly 1.9 x 1.1 arcminutes in size, corresponding to a physical diameter of 104277 light years. It is an elliptical galaxy of morphological type E, and is receding at 3871 kilometers per second - about 1.3% of light speed.
#121 S1mas
S1mas
  • Loc: Lithuania
Posted 27 November 2018 - 02:34 PM
#101
25x30s
NGC 125 is a 12th magnitude Spiral Galaxy appearing in the constellation Pisces. It is 250 million light years from our solar system.
NGC 125 appears roughly 1.4 x 1.2 arcminutes in size, corresponding to a physical diameter of 101737 light years. It is a spiral galaxy of morphological type S0-a, and is receding at 5301 kilometers per second - about 1.8% of light speed.
#122 S1mas
S1mas
  • Loc: Lithuania
Posted 27 November 2018 - 03:10 PM
#102
25x30s
  • Ptarmigan, Starman27, eros312 and 2 others like this
#123 S1mas
S1mas
  • Loc: Lithuania
Posted 27 November 2018 - 04:14 PM
#103
25x30s
NGC 1070 is a 12th magnitude Spiral Galaxy appearing in the constellation Cetus. It is 190 million light years from our solar system.
NGC 1070 appears roughly 2.3 x 2.0 arcminutes in size, corresponding to a physical diameter of 128744 light years. It is a spiral galaxy of morphological type Sb, and is receding at 4092 kilometers per second - about 1.4% of light speed.
#124 S1mas
S1mas
  • Loc: Lithuania
Posted 27 November 2018 - 04:47 PM
#104
25x30s
NGC 1514 is a very dim planetary nebula in the constellation Taurus. It was discovered by William Herschel on November 13th, 1790. He described it as "A most singular phenomenon!" The appearance of this object caused him to rethink his idea of planetary nebulae.
#125 S1mas
S1mas
  • Loc: Lithuania
Posted 29 November 2018 - 02:14 PM
#105
25x30s
NGC 1579 is a reflection nebula with dark lanes. It appears as a bright, elongated patch. On the east side is an oval core, and on the west detached filamentary segments. Several faint stars are embedded in the nebula.
