Making a 6 inch F3 Mirror/Dob
ATM lens making mirror making optics reflector equipment
1112 replies to this topic
#1 Lognic04
Lognic04
  • Loc: Melbourne, Aus
Posted 19 August 2018 - 07:06 PM
Hi all!
I was reading through Mel Bartels website, and the site and sketches from his 6 inch f/2.8 were just too cool - i have to see those views!
The 6 inch f3 will also be TINY! like a tabletop/ handheld dob!
The question is - do i want to make it f/3 or f2.8?
I already have the blank, grit and tool!
Will start hogging tonight, its gonna be a long time! But i do have a metal tool
Pyrex blank, 22mm.
Edited by Lognic04, 19 August 2018 - 07:23 PM.
  • Stevous and wrnchhead like this
#2 Pinbout
Pinbout
Posted 19 August 2018 - 07:28 PM
F3 or slower
it better to get a couple under your belt before going that fast but hey
question is do you have a paracorr II and a 21 ethos- ya need that to get his views
Edited by Pinbout, 19 August 2018 - 07:30 PM.
  • Lognic04 likes this
#3 Lognic04
Lognic04
Posted 19 August 2018 - 07:48 PM
An Ethos is an eyepiece that i have always wanted, but no paracorr - i have a GSO CC though?
#4 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 19 August 2018 - 09:27 PM
Wow I am learning tons from his website, great tip! I now understand the reason for parabolic vs spherical. Still reading, his super fast 6in is definitely fascinating!
#5 ccaissie
ccaissie
  • Loc: Whitefield, Maine
Posted 19 August 2018 - 09:45 PM
f/3 ... nice even number.
You ought to be able to hog that out pretty quick.  But if your tile tool is flat, that's going to thwart the metal tool hogging process.  Looks flat.  Would be ok for an f/8.
1.  hog out the glass with the metal tool to the approximate radius.
2.  make the tile tool to fit this curve.
3.  Smooth and fine the curve for polishing.
I admire Mel's observing and his scope building too!
Edited by ccaissie, 19 August 2018 - 09:49 PM.
#6 Pinbout
Pinbout
Posted 19 August 2018 - 10:58 PM
Cough, cough
#7 Lognic04
Lognic04
Posted 20 August 2018 - 06:14 AM
Made a rubbish start today - only 6 wets or about 10 mins on the glass, but I got 0.1mm hogged!
  • Pinbout likes this
#8 Oberon
Oberon
  • Loc: Hunter Valley NSW Australia
Posted 20 August 2018 - 06:39 AM
Cough, cough
#9 Pinbout
Pinbout
Posted 20 August 2018 - 08:20 AM
Is that an evil CC?
  • KennFromTX likes this
#10 calypsob
calypsob
Posted 20 August 2018 - 10:39 AM
a gso coma corrector will not work the same because a paracorr acts partially as a barlow by 15% I believe. The gso is better than nothing but in the long run you should definitely keep an eye out for an upgrade.
Edited by calypsob, 20 August 2018 - 10:40 AM.
#11 stargazer193857
stargazer193857
  • Loc: Southern Idaho
Posted 20 August 2018 - 12:46 PM
Wouldn't the central obstruction be too big?
#12 Pinbout
Pinbout
Posted 20 August 2018 - 01:25 PM
its widefield so it shouldn't matter
what matters is how big an exit pupil can he stand...that's why MB uses a 21mm 100*
the eyepiece will be bigger than the scope, well the p2 and 21mm... ha ha ha
#13 MitchAlsup
MitchAlsup
Posted 20 August 2018 - 04:17 PM
Shoot rough grinding at F/2.9. Then use fine grinding to move the FL ini one direction or the other.
F/2.8 may allow wider FOVs
F/3.0 may allow better correction of the FoV with P2
So the question devolves into:
a) are you more interested in widest possible FoVs, or
b) merely really wide FoVs and more pippoint stars?
It is a fine line to tread.
Lockwood says stay below F/2.75 and both of your are.
  • Augustus and Lognic04 like this
#14 Pinbout
Pinbout
Posted 20 August 2018 - 05:08 PM
Did you see mel’s Sketch up model in 3D warehouse?
#15 Lognic04
Lognic04
Posted 21 August 2018 - 03:26 AM
Sag is now 0.6mm after 25 wets.
#16 Steve Dodds
Steve Dodds
    Owner - Nova Optical
  • Loc: Utah
Posted 21 August 2018 - 06:31 AM
You are 1/5 of the way there.
#17 Lognic04
Lognic04
Posted 21 August 2018 - 07:42 AM
Goes really quick!!
I might switch to tile tool at 2.5mm or so to break the tool in?
#18 Lognic04
Lognic04
Posted 21 August 2018 - 06:23 PM
For the tube i wonder if i could just make literally a plywood box?
Tonight hopefully i can hit 1mm sag and i have the day off school tomorrow wink.gif grin.gif
Should be able to get to 2.5mm on the day off :) Then switch to tile tool
Edited by Lognic04, 21 August 2018 - 06:37 PM.
#19 Lognic04
Lognic04
Posted 22 August 2018 - 03:32 AM
1mm sag!
#20 Lognic04
Lognic04
Posted 23 August 2018 - 04:21 AM
1.3mm!
What do you guys waterproof plaster of Paris with? I couldn't afford dental plaster...
Should I pour the tool with tiles embedded inside?
  • wrnchhead likes this
#21 Pinbout
Pinbout
Posted 23 August 2018 - 05:29 AM
Epoxy resin
Edited by Pinbout, 23 August 2018 - 05:30 AM.
#22 Lognic04
Lognic04
Posted 23 August 2018 - 06:32 AM
These tiles have an extremely hard ceramic side and a softer back - which side do I use?
#23 Pinbout
Pinbout
Posted 23 August 2018 - 08:35 AM
you have glazed tiles?
#24 Lognic04
Lognic04
Posted 23 August 2018 - 03:50 PM
I think so
#25 Lognic04
Lognic04
Posted 23 August 2018 - 04:52 PM
Should I make a coin tool? The coins here have no zinc in them though, only copper/nickel
Also tagged with one or more of these keywords: ATM, lens making, mirror making, optics, reflector, equipment
