Long slow Newtonians
equipment mirror making observing planet reflector
239 replies to this topic
#226 icomet
icomet
  • Loc: Montana
Posted 16 April 2020 - 03:37 PM
Tape wrapped around the tube before I painted it, to get the stripe.
#227 icomet
icomet
  • Loc: Montana
Posted 25 April 2020 - 10:33 PM
Newts of the following optics size/focal ratios -
10" f/4.7 (Orion)
10" f/6 (Swayze)
10" f/7.5 (suspected Optical Craftsman or Cave Astrola)
All three scopes will be built using the same type/size of tube (fiber).
All will be able to then be able to share a set of Cave Astrola 12" rotating rings, providing
I can get the rings to fit.
Well, boys and girls, this little ATM'er has found a lathe with 15" jaws.
The rings are being "trimmed" as we speak. I'm talking a very small amount, too.
One of the scopes might be put into a dob base. Always need one of those. Also work better for
the "huddled masses" outreach sessions. The scope can then be made "fudgeicle proof" more
easily, and "feet on the ground", also.
Image of rings after cleaning and before machining.
Clear Skies.
#228 icomet
icomet
  • Loc: Montana
Posted 28 April 2020 - 05:12 PM
The rotating rings went from 12.188" ID to 12.288" ID. I will be repainting them soon.
Mean time, I started to paint the tube. It will have another color, also.  No, it doesn't glow in the dark.
That's the mount for the scope in the image with the inner rings.
Clear Skies.
  • L. Regira, Jeff B, Bomber Bob and 1 other like this
#229 icomet
icomet
  • Loc: Montana
Posted 02 May 2020 - 10:15 PM
12.288"  ID for the rings fits great. But I forgot something. I had, at first, thought of a way that I should
put this OTA together. It was correct thinking; one should listen to oneself.
Instead, I painted the tube. You guessed it, the paint is just a little too thick. Rats!
I can get the inner ring on, it will just take a bit, and will probably have to touch up some scarring.
Be different. Paint something out of the ordinary. Was going to do more, but stopped here. I can always
pick up the painting where I left off.
Those are 1969 Cave Astrola rotating rings hangin' there. Between those and the other 1960's parts that are
going into this scope, I should be able to get away with a posting on the "Classic Telescope" forum.
Clear Skies.
  • 25585 likes this
#230 CCD-Freak
CCD-Freak
    Vendor - Portable Observatories
  • Loc: Whitesboro,Texas
Posted 05 May 2020 - 06:27 PM
Here is another scope built around an Edmund 8" F8 mirror.  I bought the mirror in a cell at the TSP swap meet around 1992 for s whopping $40.  I built a Dob with it for my son to use.  The Edmund mirror puts up very nice planetary and lunar imges and does a good job on DSOs too.   If you find an old Edmund 8" F8 mirror....grab it.!!!  (^8
8inF8-Dob-JL-xsm.jpg   8" F8 at TSP 94
John
CCD-Freak
WD5IKX
Edited by CCD-Freak, 05 May 2020 - 07:24 PM.
  • Sol Robbins, Deep13, L. Regira and 6 others like this
#231 Deep13
Deep13
  • Loc: NE Ohio
Posted 06 May 2020 - 11:44 AM
attachicon.gif8inF8-Dob-JL-xsm.jpg  8" F8 at TSP 94
John
CCD-Freak
WD5IKX
Found one, grabbed it, had Terry Ostahowski recoat it. It's on a Meade RG EQ mount.
  • CCD-Freak and 25585 like this
#232 Zamboni
Zamboni
  • Loc: Colorado Springs
Posted 06 May 2020 - 01:56 PM
Post reported for pornographic content!
Seriously, that sounds like an amazing planetary beast.
  • Deep13 likes this
#233 Jeff B
Jeff B
Posted 06 May 2020 - 06:50 PM
Grad it by the edge though.
  • Deep13 likes this
#234 Deep13
Deep13
  • Loc: NE Ohio
Posted 07 May 2020 - 01:12 PM
I'll see if the planets are every high in the sky again. But I'll try it out on Jupiter, Mars, and Saturn this summer. I've added a cooling fan, fine focuser, a Rigel finder, Antares secondary, and a thin-vane Astrosystems holder. I'll compare it to my 5" f/12 refractor.
  • Astrojensen likes this
#235 Galicapernistein
Galicapernistein
Posted 07 May 2020 - 02:05 PM
With only a 4” difference in focal lengths between an 8” F8 and 5” F12, that sounds like it will be an interesting comparison.
#236 Deep13
Deep13
  • Loc: NE Ohio
Posted 07 May 2020 - 03:14 PM
More surface area vs. unobstructed optics.
  • Galicapernistein likes this
#237 izar187
izar187
  • Loc: 43N
Posted 07 May 2020 - 11:11 PM
I think the 8 will whomp the 5 pretty soundly.
  • areyoukiddingme likes this
#238 icomet
icomet
  • Loc: Montana
Posted 29 May 2020 - 09:32 PM
10" f/7.5
Clear Skies.
  • Galicapernistein, daquad, steve t and 3 others like this
#239 25585
25585
Posted 30 May 2020 - 12:03 AM
#240 icomet
icomet
  • Loc: Montana
Posted 30 May 2020 - 12:28 PM
Okay. All long Newtonians together.
These are the long newts that I have restored or built.
12.5" f/7  model D 1950's  Cave Astrola
10" f/7.5 with 60's optics (Optical Craftsman ?) on a 1981 Meade DS - 16 mount
6" f/10 with Beck mirror on a "reserected" CG 5 AGT mount
(Blue striped "Swayze 10" f/6 dob against the wall)
Clear Skies.
  • daquad, steve t, Jeff B1 and 2 others like this
Also tagged with one or more of these keywords: equipment, mirror making, observing, planet, reflector
