APM 140mm DOUBLET APO REFRACTOR
27 replies to this topic
#1 Larry Carlino
Larry Carlino
Posted 10 September 2018 - 08:45 AM
Some two dozen observing sessions and direct comparisons with instruments of known quality have convinced me that this APM 140ED is indeed an excellent telescope. It is well built, nicely finished, and it boasts very fine optical quality. In addition, its relatively light weight and short tube length allows the effective use of a mid-size equatorial or alt-azimuth mount. It has almost the punch of a 6-inch refractor in a package that is clearly more portable.
Click here to view the article
  • Jon_Doh likes this
#2 ichdien
ichdien
Posted 10 September 2018 - 09:57 AM
"The TEC 140 is a beautifully-crafted telescope with outstanding optical and mechanical quality, but it is expensive and just heavy enough to require a beefy mount . . . ."
Hmmm . . .  APM lists the 140's weight, with rings, as 9.8 kilograms.  TEC lists the weight of their 140, without rings, as 8.6 kilograms.
  • Scott99 and AstroNutz like this
#3 Larry Carlino
Larry Carlino
Posted 10 September 2018 - 10:24 AM
I've just weighed the APM 140ED and got 8.4kg with the rings attached.  I did have a TEC 140 triplet several years ago and never did weigh it, but I found that it was not quite stable enough on the same UA Unistar set-up that is being used for the APM.  The length of the scopes is basically identical, but the TEC is a bit more front-heavy because of its triplet lens configuration.
Larry C
  • Scott99 likes this
#4 jrbarnett
  • Loc: Petaluma, CA
Posted 10 September 2018 - 01:32 PM
I thought that seeing quality and not optical quality was the most common reason any given instrument does not resolve to the Dawes limit, and that as aperture increases wholly irrespective of figure quality of the optics, the probability of seeing not supporting the Dawes Limit split goes up.  Few places on Earth support sub-arc-second seeing consistently yet any scope larger than 4.56" has a sub-arc-second Dawes limit.
  • Scott99, 21681577 and TonyCaf like this
#5 Sheldon
Sheldon
  • Loc: Broken Arrow, OK
Posted 10 September 2018 - 05:21 PM
Tim Havens and compared my 10" Starliner Deluxe Newtonian to his Takahashi 150mm ED Doublet.  We aimed at Jupiter where there was no question on either of our parts as to which presented the best image; the Starliner  won.  The we went to a small spiral Galaxy which showed up very well in my Starliner.  It was brighter - naturally than the image in his Takahashi; the fact of the matter - however - is that the 6" refractor showed the spiral arms clearly whilst my 10" just showed far less.  My conclusion - affirmed since and by many - is that a super high quality refractor can more than make up for light gathering deficit through superior contrast.    The Starliner is the best planetary scope I've used, but anyone who would not recognize the potential of a high quality 140mm refractor on DSOs is missing the point.
  • mattyfatz, roadi and Jon_Doh like this
#6 RichA
RichA
  • Loc: Toronto, Canada
Posted 14 September 2018 - 06:27 PM
Doesn't always work that way.  Even when images "look" poor in a larger scope, you often see more detail than in a smaller one for a variety of reasons, colour rendition, contrast, resolution all play a part.  Also, good seeing doesn't always match the surroundings you might think.  I once live with a backyard verging on a major street, but the seeing was the best I've had and consistent.  I could regularly in the summer split 0.6-0.7 doubles with an 8."  Go figure
#7 oldtimer
oldtimer
  • Loc: Lake County Illinois
Posted 15 September 2018 - 01:36 PM
I've said it before and I'll probably say it again, There are only 3 planets worth looking at and one of those only every 2 years. That said I'm not concerned about CA. With almost countless other objects to view I'll not give up my 140mm Vixen. In fact even at F5.7 it does a better job on the planets then my old 6" F8 achro.. Bought mine used for $900 and never regretted it.
  • Scott99 and Simply Peter like this
#8 Deep13
Deep13
  • Loc: NE Ohio
Posted 15 September 2018 - 05:10 PM
Well, someone has to ask. How much does it cost?
  • Scott99, FreddyH, ram812 and 1 other like this
#9 HansD
HansD
Posted 18 September 2018 - 11:11 AM
‘The question invariably comes up:  Is this telescope truly “apochromatic”?’
This is a simple question, with a simple answer. Two glass elements can only bring two wavelengths of light to focus at the same point, therefore it is achromatic. It takes three elements to bring three wavelengths to focus at the same point, which would make it apochromatic.
It is quite possible that an achromat outperforms an apochromat in a particular application, such as visual impressions of planets and doubles. And it may be that one does better visually and the other does better photographically. If you use a narrow band filter there may be no difference at all.
Manufacturers who feel the need to mislabel things are simply being dishonest.
#10 spaceoddity
spaceoddity
  • Loc: Cloudsylvania
Posted 18 September 2018 - 03:53 PM
Too much for me.
https://farpointastr...focuser-bundle/
#11 Jeff Morgan
Jeff Morgan
  • Loc: Prescott, AZ
Posted 19 September 2018 - 02:07 PM
What type of back focus capability does the APM 140 have?
  • Tbsweet likes this
#12 Deep13
Deep13
  • Loc: NE Ohio
Posted 20 September 2018 - 03:18 AM
$3600 plus the cost of a mount. For a 4.5" telescope.
#13 TomK1
TomK1
  • Loc: Grosse Pointe Woods, Michigan
Posted 26 September 2018 - 11:32 PM
5.5".......not 4.5".
#14 Starlease
Starlease
  • Loc: Rocky mountains.
Posted 27 September 2018 - 10:43 AM
My 5 inch apo shows the dark lanes in the trifid nebula better than my 10 inch Dob.  There is something about refractors.
Edited by Starlease, 27 September 2018 - 10:43 AM.
  • ram812, ratnamaravind and Cowboybob like this
#15 Deep13
Deep13
  • Loc: NE Ohio
Posted 09 October 2018 - 10:40 PM
Oh, yes. My mistake.
#16 SteveFour86
SteveFour86
  • Loc: Bay City, OR
Posted 13 October 2018 - 09:49 AM
Thank you for the review it was very detailed and informative.  Some day I will be able to drop that kind of money on a scope.
  • Don Allen, Cowboybob and Mage like this
#17 niksi
niksi
Posted 17 October 2018 - 11:24 AM
I have been using it now for almost 3 years. I use the number 0006. Its great on moon and planets. Its also good for deep sky. Stars are almost perfect, but there ist still a glimps of astigmatism.
#18 starmanbob
starmanbob
Posted 06 November 2018 - 12:35 PM
Thanks for the thorough review Lawrence.  I have a nice 100mm Stellarvue triplet, and I've always thought about adding something in the 140 range for a little more punch.  The APM sounds like it would fit the bill pretty well.  I'm a purely visual observer, so I can't really see the point in going all out for a top of the line fluorite rig.  Any one have any thoughts/opinions re: the value of a 140 vs a 100 (101.5, lol) for visual?  Thanks...
  • Hankster likes this
#19 junomike
junomike
  • Loc: Ontario
Posted 10 November 2018 - 07:45 AM
The APM 140ED was on my Radar and still could be if one surfaced locally.  I only wish Markus had used a smaller OTA instead of using the same OTA for the 152ED.
I understand the cost savings on his part, but a smaller, lighter OTA would be better for some folks with smaller mounts and lifting limitations.
#20 SirOtto
SirOtto
  • Loc: Staatsburg, New York
Posted 14 November 2018 - 10:43 AM
How about it's use in Astrophotography?  Anybody try?
  • TonyCaf likes this
#21 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 19 November 2018 - 01:56 PM
Being naive about EUR prices. The Price listed on APM includes VAT? If so, do we deduct the VAT from the cost of the telescope before shipping costs?
#22 nicknacknock
nicknacknock
    A man of many qualities, even if they are mostly bad ones
  • Loc: Nicosia, Cyprus
Posted 20 November 2018 - 01:54 AM
With 2.5" focuser: EUR 2,100.84 export price + shipping cost
With 3.7" focuser: EUR 2,521.01 export price + shipping cost
Above prices apply to those outside the European Union, hence outside the scope of VAT.
#23 Maho68
Maho68
Posted 26 January 2019 - 05:27 PM
I have this APM SD APO 140/980 mm with 3,7 " focuser for 3099 € (july 2018)
is fantastic view of the moon ,planets must wait for higher deklination
that has better strehl curve as APM 152 f8
#24 arlenhamby
arlenhamby
  • Loc: Porter, Texas
Posted 02 February 2019 - 10:09 AM
https://luntsolarsys...3-optical-tube/
#25 BinTian
BinTian
Posted 30 March 2019 - 07:43 PM
红外 much
