Mars tonight on September 11, 2018:
Edited by Sasa, 12 September 2018 - 02:35 AM.
Posted 11 September 2018 - 08:52 PM
Alexander,
The very classic Mars view. Excellent sketch.
Frank ![]()
Posted 12 September 2018 - 12:05 PM
Alexander,
Very nice sketch of Mars
Posted 13 September 2018 - 02:37 AM
Last night I set up my larger refractor. Before I started with sketch, view was quite sharp at 167x. As you can expect, once I started with the work it never came back at the same level. Being lazy I stayed at 167x.
Hellas was not that bright as night before. However I think I glimpsed in it a brighter smaller spot. Saw it only 3 times for very short time, it could be a trick played to my eyes.
Posted 17 September 2018 - 06:01 PM
Big ups to you for persistence and sheer ability, Alexander! ![]()
Posted 18 September 2018 - 02:04 AM
Very good set of sketches, especially with such modest apertures!
Posted 24 September 2018 - 03:39 PM
After stormy yesterday night atmosphere cleaned a lot from dust. It was still windy today (and tonight) with quickly changing weather between completely clear sky to rain, even hailstones occasionally. I saw through window bright Moon, the sky was almost clear with just some clouds quickly approaching from north. I knew I must be fast, luckily this is possible with 60mm refractor. At the end I got about 14 minutes of observing and sketching Mars before the sky got completely clouded. View was surprisingly reasonably good. In short moments I saw interesting texture with numerous darker and lighter patches. I wish I had more time to capture them more precisely:
Posted 27 September 2018 - 02:40 AM
Two nights ago I took out my larger 82mm refractor. I wanted to explore in more detail those interesting patches I saw on previous night with 60mm refractor. Alas, I got usual bad seeing and I was happy to see at least something. Here is my best guess of what was going on the Mars globe:
Posted 29 September 2018 - 02:37 PM
Mars is getting smaller and it seemed tonight like it was too small for 60mm telescope. It was hard to notice anything else beyond the two polar caps and Terra Sirenum. According to WinJUPOS, Solis Planum and Margaritifer Terra were supposed to be on western edge. All I could see in this area were just vague, very faint and slighlty darker undefinite patches
Edited by Sasa, 29 September 2018 - 02:38 PM.
Posted 29 September 2018 - 02:49 PM
Good job Sasa, a nice souvenir for this opposition!
Michel
Posted 29 September 2018 - 03:57 PM
Thanks Michel. I should go to Japan more often...
Posted 30 September 2018 - 07:17 AM
Wow, nice job!!!!
Pete
Posted 30 September 2018 - 04:25 PM
Thanks Pete, here is another one from tonight. As I was half an hour late, Mars was showing the same face as previous night so one could compare the two observations. Tonight, Solis Planum and Margaritifer Terra were more pronounced, even with some hints of tips. But nothing definite:
Edited by Sasa, 30 September 2018 - 04:31 PM.
Posted 30 September 2018 - 05:09 PM
Very nice work!
Posted 01 October 2018 - 05:40 AM
Thanks, btw I see all the time bright northern polar region. However on images, or in sketches through larger scopes (like recent one from Paul Abel), there is nothing. I was paying special attention to it last night. It was clearly there, I would say even much more pronounced than souther cap. So is this a trick played on my eyes, like in small telescopes the brighter edges somehow tend to be larger? I don't know. It is one of the most pronounced albedo features, I usually see first this northern cap and with more concentration the darker albedo features. To me it looks quite real.
Posted 03 October 2018 - 09:58 AM
I have no clue why you see this, my only wild guess would be that it is some form of chromatic aberration? but only if you’re using an achromatic refractor, if your scopes are apochromatic this would be much less… but i don't know your telescopes ... just a thought
Posted 03 October 2018 - 12:24 PM
Most of this apparition (16.3” D-K) I have been routinely getting a brightness – often very bluish – along/inside the N. limb: evidently the NP Hood. As I indicate more an arc than a circular cap-like aspect; in fact many images are showing a similar arc. Tho’ I suspect some have processed it out???
With using an ADC I can confidently say bluish (and real!) and have posted several sketches here showing that. The apodizer further cleans up the limb regions.
What you are getting accords well with my 3” refractor views……that rounder effect I feel is down to the diffraction effects of lo-res (perhaps some irradiation also) – much as we get larger Airy disks with smaller apertures as compared to larger. In fact my most of my more recent views with the co-mounted 3”gave a very cap-like apparent ellipse ('NPC') effect and even more apparent with the 3” stopped down to 1½“(160x no ADC but a Ramsden ep for dispersion cancelling).
To show an extreme example attached is a rendering from last apparition (posted here back then) where the SPC, sub-res in the 3”, mimicked a bright star complete with 1st diffraction ring!
Hope to post some of my recent Mars shortly – very busy time domestically lately, but hoping for an opportunity next weekend………
Dave.
Edited by David Gray, 03 October 2018 - 12:33 PM.
Posted 03 October 2018 - 12:49 PM
Thanks David, you are the right person to answer my question as you routinely observe Mars with both large and small aperture. I'm glad that my sketches correspond to the view in your 3" refractor. It brings more confidence back to me. It was quite shaken by the absence of the bright north polar cap on many recent images and sketches.
I think you explanation as an effect of limited resolution of small refractor is spot on.
Posted 04 October 2018 - 08:22 AM
Very nice work
Posted 04 October 2018 - 03:42 PM
Thanks Paul, after short period of bad weather, we had clean sky tonight. Mars is still ok even in the small telescope
Just for fun, here is a comparison with the situation at the end of August when I captured at the same position:
Edited by Sasa, 04 October 2018 - 03:43 PM.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
