I may be unique on this forum since I own both an SB mount (MX+) and a CEM120EC2. (I also owned a Mach 1 for quite a while. I'd still own the Mach 1 if I hadn't scored a share in a local observatory. Here's what I think about the issues in this thread. The Mach 1 does not have the same capacity as the MX+ or the CEM120EC2. So, to me, it's better to compare it to the MYT and the CEM60EC which I can't personally do from experience although I did use an MYT once.)
I'd sum up my experiences with these points-----
1. There is simply no practical advantage between a GEM and a CEM design, when you are talking about these two mounts. Period. Theory is very nice, but in practice good manufacturing technique wins out over theory. The thousands of SB and AP observatory class mounts out there are running just fine. The CEM is no easier to balance than any other equatorial mount I've ever used. There are certain to be edge use cases in favor or one or the other but I haven't found one yet. I've put four systems on both and just haven't seen any difference that I can attribute to CEM/GEM design differnces. In fact, the CEM is 7 pounds heavier than the MX+ to achieve the same weight capacity. Alt/AZ adjustments are smooth and accurate on both mounts.
2. Support is good from iOptron and they will send you parts. I just changed out the USB3 board and sent them back the old one. Just one example. However, both SB and AP have much better support models. I sent an email to AP about buying a field flattener and received a response within 24 hours from Roland himself. You will never hear from iOptron in that time frame. I'm still waiting for answers to three questions I posed weeks ago about bugs I've found in the software they provide with the mount. The SB forum can provide you with answers in the middle of the night - it has done that for me. SB and AP have full repair facilities in the USA (where I live). I'm not sure that iOptron can repair a CEM120EC2 here.
3. Despite how annoying my current bug list is, in a practical sense, the CEM120EC2 works at least as well as the MX+. I've put up to 80 pounds on both mounts and they both track (same location) at around .3 arc seconds of error. Can even be a bit better on good nights. The mounts are seeing limited. The mechanicals are superb on both. The CEM has a little squeak when slewing my MX+ burbles when tracking.
4. The CEM120EC2 is a bargain. It's almost 3000 dollars cheaper than the MX+ once you add in the necessary bits and pieces to give you a full system. This assumes that you buy them and don't build things yourself. As a practical matter you can buy an ASI1600MM-C, the companion filter wheel, a nice OAG and a guide camera for the difference. Or fly to China see the Great Wall and fly back.
5. You get a full through the mount power and USB cabling implementation with the CEM. Right now I have my wide field system (WO71 Star) on the mount. It's got a ZWO 1600MM-C, companion 7 position filter wheel, moonlite electric focuser, a ZWO290 mini guide camera plus an Optec Flatman. All five components are attached to the saddle plate and power is supplied to the main camera and focuser from the plate as well. I have had ZERO USB failures over 4 complete nights of imaging since I set it up and zero USB failures over several weeks using the same stuff on a different OTA. The same setup on the MX+ required an additional, a USB hub, bypassing the Versaplate and some power splitters to boot to get the same result.
6. The big advantage of the MX+ is (to me) the seamless integration of the system with the SKYX. I love the SB forum, I get tips there all the time about how to use the system better. Trying to use it with the CEM120EC2 has been problemmatic. This is probably a separate post but, for example, the CEM will not accept custom tracking rates in DEC and RA. This makes imaging things like comets, satellites and asteroids more difficult. Even though the SKYX supports this generally (I've used it on non Bisque mounts) an error is thrown with the CEM120. SB owns problems with the mount and the software. It's really this kind of integration that led AP to build out APCC (I think).
7. I personally find the CEM120EC2 driver software GUI for the mount a reall dog's dinner. It has three different panels to deal with. It is slow to load. Some features don't work. It interferes with my (T-Point) pointing model and it doesn't support custom tracking rates. They should have looked at what others provide and not tried to build something entirely different.
As always, YMMV, IMHO and please correct anything you think I've got wrong (PCAYTIGW?).
Rgrds-Ross
