Small triplet or quadruplet for full-frame DSLR
18 replies to this topic
#1 CrossoverManiac
CrossoverManiac
Posted 23 September 2018 - 08:30 PM
This is for a full-frame camera in the 300-500mm focal length range, specifically for DSOs that are larger than 60 arc-minutes across but not so large that the object only takes up a small portion of the picture as it would with a wide-angle camera lens ( ≤ 300 mm).
#2 PirateMike
PirateMike
  • Loc: A Green Dot On A Blue Sea
Posted 23 September 2018 - 10:57 PM
Are you asking for a suggestion?
#3 t-ara-fan
t-ara-fan
Posted 23 September 2018 - 11:32 PM
Budget?
#4 Jerry Lodriguss
Jerry Lodriguss
    Vendor
  • Loc: Voorhees, NJ
Posted 24 September 2018 - 12:18 AM
AT65EDQ quadruplet apochromat is 420mm of focal length at f/6.5.
You will get a some vignetting with a full frame camera, but it can be corrected with flats.
To do better than this, you would need something like a Tak with a larger focuser and large focal reducer, and that can get pretty expensive.
Jerry
Edited by Jerry Lodriguss, 24 September 2018 - 12:23 AM.
  • tim53 likes this
#5 CrossoverManiac
CrossoverManiac
Posted 24 September 2018 - 01:15 AM
Yes.  Also, I'm trying to keep the OTA down to 2.5 kg or less.
Edited by CrossoverManiac, 24 September 2018 - 01:16 AM.
#6 PirateMike
PirateMike
Posted 24 September 2018 - 01:45 AM
The 65EDQ is no longer sold by Astro-Tech but you can find the same scope (I presume) here... https://www.teleskop...d-flatener.html
It does weight 2.8kg which includes the weight of the rings.
#7 Samir Kharusi
Samir Kharusi
  • Loc: Oman
Posted 24 September 2018 - 01:51 AM
If you are willing to go to twice the price but end up with dual daytime/astro use, consider the Canon EF 400mm f5.6; a great birding lens and great for astro, though one f-stop slower than I would have preferred for use unguided. At a dark site using a Canon APS-C camera ideally you need 4 minute subs as minimal (though you might get away with 3 minute subs or even two minute subs if there is any light pollution). With the later model 5D's you may happily use 2-minute subs even at the darkest sites. The later 5D versions have lower Read Noise than the more common Canon APS-C. That should be short enough for most mid-price mounts, unguided. On the other hand if you are already using autoguiding you may well prefer to save yourself some hundreds of $ and go for the APO at f6.5 (minimal length subs on an APS-C 5+ minutes, hence autoguiding necessary on most mounts). So, basically, to get a more focused recommendation, I think you should state what camera you wish to use it with, and whether you autoguide or not. Personally I place great preference for non guided use, but others are already set up for autoguiding...
#8 einarin
einarin
Posted 24 September 2018 - 01:54 AM
Or this.
#9 CrossoverManiac
CrossoverManiac
Posted 24 September 2018 - 02:24 AM
Or this.
According to the site, field correction is 32 mm.  For a full-frame camera, it would have to be 43 mm.
#10 CrossoverManiac
CrossoverManiac
Posted 24 September 2018 - 02:26 AM
What about the Meade 70mm quadruplet?  How would that compare with a 80mm cf triplet ?
#11 Coconuts
Coconuts
Posted 24 September 2018 - 08:00 PM
I would suggest that you consider the Hutech/Borg 360 mm f/4.0 astrograph family.  Here are four "standard" configurations:
https://www.sciencec...rgPackage/9.htm
https://www.sciencec...gPackage/10.htm
https://www.sciencec...gPackage/11.htm
https://www.sciencec...gPackage/12.htm
All configurations are equally fast (f/4.0), and a hallmark of Hutech/Borg systems is very light, thin-walled but stiff components that keep the overall mass down.  The last in the list above has a mass of 1.9 kg, well below your 2.5 kg goal, but a lot faster than many other candidates.  All of their astrographs started off designed for medium format film, and so are even better corrected for full-frame sensors.
The Hutech/Borg "system" can be a bit intimidating at first; any specific configuration consists of a number of compatible components selected from a long list, which you can peruse here:
https://www.sciencec...parts/index.htm
The pre-configured astrographs listed above parse that long component part list for you, though.  Their optical quality is excellent, and the price when compared to peers (Takahashi, etc) is very reasonable.  This last comment may seem a stretch, but these are certainly great astrographs at a reasonable price.
All the best,
Kevin
Edited by Coconuts, 24 September 2018 - 08:20 PM.
  • GlenM likes this
#12 Samir Kharusi
Samir Kharusi
  • Loc: Oman
Posted 25 September 2018 - 03:42 AM
Dang! You do get what you pay for undecided.gif  f-ratio costs.
$750 f6.5 TSAPO65Q
$1250 f5.6 Canon EF 400mm
$2000+ f4 Borg
#13 CrossoverManiac
CrossoverManiac
Posted 25 September 2018 - 02:30 PM
$750 f6.5 TSAPO65Q
$2000+ f4 Borg
That seems to true...except with Newtonian astrographs...sort of.  TPO does offer some pretty cheap imaging Newtonians starting at $300 for a 6-inch f/4, which would put the focal length around 600 mm, which would encompass the entire Andromeda Galaxy in the FOV using a full-frame DSLR.  However, the problem is now dropping at least $1500 minimum for a mount big enough to handle it.  Also spending a few hundred on a coma corrector for correcting distortions of the stars that are common among fast Newtonian telescopes and making sure it is one that will correct for a field large enough for a full-frame camera otherwise it defeats the entire purpose of getting a scope with a 600-mm focal length, which has the user going back to looking for the right telephoto lens or short refractor.  I only have a Star Adventurer that maxes out at 11 lbs since it was made primarily for wide angle astrophotography (though I *originally* bought my Star Adventurer for this: https://www.youtube....?v=Bz0sBkp2kso)
One way or another, you will pay $$$ for that shot.
It's only now I see why some many people in AP putting more emphasis on getting the right tracking mount than the right telescope.
Edited by CrossoverManiac, 25 September 2018 - 02:43 PM.
#14 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 25 September 2018 - 11:22 PM
What objects are you planning on photographing that are larger than 60' ? There are only 8 M-Objects larger than that, and a few more NGC/IC objects, but most of them are much fainter and require a modded camera or narrowband imaging. There are targets like the nebula complex around Sadr and the entire Horsehead area, but for all intents, in AP, 300mm is still a very wide angle lens.
Andromeda is the largest target in the N Hemisphere, (not counting Barnards Loop), but it's still only 3.5 sq deq. A 300mm lens has an FOV of 31.7 sq deq. on a FF camera, so Andromeda will only take up 11% of the field. The Pleiades, the second largest M-Object is half the size of Andromeda.
Full frames excel for wide angle, but to get any sort of reach at the long end is going to require some expensive long glass, be it a lens or an APO.
Andromeda frames nicely at 500-600mm on a FF. For most other DSO's, you'll need even more fl, a lot more,(or you could just crop down to an APS-c sensor FOV, and sacrifice your wasted pixels.)
BTW, good luck getting the Star Adventurer to work at those focal lengths, even with autoguiding.
#15 Kendahl
Kendahl
  • Loc: Omaha, Nebraska
Posted 26 September 2018 - 12:25 AM
KEH has a well used Canon 400mm F/5.6 L USM EF lens for $648. Adorama has three of them from $729 to $879. B&H has one for $916.50.
For similar money, there are several wide field, triplet ED refractors with focal length reducers / field flatteners that get you near 400 mm focal length.
#16 Scott Rose
Scott Rose
  • Loc: Beachwood Ohio
Posted 30 November 2018 - 10:37 AM
I started using a PrimaLuce 65mm quad that I got from Daniel at Woodland hills.  Very nicely built scope with good optics.
#17 giorgio_ne
giorgio_ne
  • Loc: London, England
Posted 30 November 2018 - 11:17 AM
What about this one: 450mm at f5.3 with an image circle of 44mm.
#18 jeff.bottman
jeff.bottman
Posted 30 November 2018 - 01:28 PM
I second Jerry, my AT65EDQ quadruplet yields round stars edge to edge over a full frame D750 field.  And it plays very well with a super lightweight german eq mount, the iOptron SmartEQ Pro+.  Schlepped it all to the Texas SP along with guide scope/camera via air, no problem.  And got a first rate "first-timers" image.
Although now I lust after this 107mm / f3.9 lightweight APO:  https://telescopes.n...al-package.html
#19 andysea
andysea
  • Loc: Seattle, WA
Posted 30 November 2018 - 04:36 PM
I have pre-ordered this one https://agenaastro.c...-gold-6620.html
51mm f4.9  quad with excellent correction - if the diagrams are true -  for full frame cameras.
Edited by andysea, 30 November 2018 - 04:37 PM.
