ST80 as a solar viewing instrument
10 replies to this topic
#1 James Paulson
James Paulson
Posted 25 September 2018 - 07:04 AM
Is there a safe way that I can convert an ST80 into a solar viewing scope? Is a Herschell wedge all that is required?
#2 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 25 September 2018 - 07:13 AM
Do you mean for white-light viewing of transits and sun spots only, or something else?
Obvious question I know, but just checking, because I noticed that there was no mention of a filter.  I have been testing using the solar filter from my 90mm Skywatcher Mak on a ST80 for this purpose, so I can see if it will work for school, or whether I need to build a solar cone projector.
Wedges are expensive, filters are cheap.  You also mention viewing.  Do you also intend more detailed recording or observation?
Edited by SchoolMaster, 25 September 2018 - 08:14 AM.
#3 sickfish
sickfish
  • Loc: Watertown Ma.
Posted 25 September 2018 - 07:45 AM
I made a filter for mine using Baader film and a pvc pipe.
The size of the pvc pipe fits snug over the dew shield.
This does not convert the scope to a sun only instrument.
#4 MalVeauX
MalVeauX
  • Loc: Florida
Posted 25 September 2018 - 09:05 AM
Heya,
I use an ST80 for all things solar, from white light to hydrogen alpha to calcium k, etc. It's great for it.
If you want to view the sun in white light, a Herschel Wedge will do it, but so will a simple bit of Baader Solar Film (much cheaper; you can get it in a premade cell for probably $50 from Astrozap). And if you want to turn it into a hydrogen alpha solar scope, you can do it with a Quark Chromosphere too.
Here's the stock ST80 with a Astrozap pre-made cell with Baader Solar Film:
Here's the ST80 with a 2" focuser upgrade and a Quark Chromosphere (to go narrowband into hydrogen alpha):
And to put it on the sun fast, I just rubber-banded a Sol Searcher on there as needed. You can also use a Dynapod Helio-Pod (cheaper and made to do just this too).
Very best,
  • MAURITS, rowdy388, LFORLEESEE and 3 others like this
#5 Don W
Don W
    demi-god
  • Loc: Wisconsin, USA
Posted 25 September 2018 - 10:27 AM
I have one set up with Baader film in a homemade cell, and another one with a projection screen, funnel thingy. That's a technical term. LOL
  • MAURITS, hopskipson, petmic and 2 others like this
#6 44ye
44ye
  • Loc: MACKINAW TOWNSHIP CHEBOYGAN CO MI
Posted 25 September 2018 - 01:41 PM
These are for white light ie Sun Spots ( has not been one in weeksfrown.gif  )
Major cost of Sun Funnel is EYEPIECE and the Screen material
Sun Funnel pictured above link
https://eclipse2017....n_Funnel_v4.pdf
SUN GUN link
http://www.sunguntel...e.com/MAIN.html
44ye
Don
Edited by 44ye, 25 September 2018 - 01:48 PM.
  • Don W likes this
#7 44ye
44ye
Posted 25 September 2018 - 01:57 PM
Don W
 What eyepiece are you using ?  My projection is not nearly as big its about 1/3 that size .
44ye
Don
#8 Don W
Don W
    demi-god
Posted 25 September 2018 - 03:22 PM
I think it's a Meade 9mm MA.
  • 44ye likes this
#9 James Paulson
James Paulson
Posted 13 October 2018 - 09:23 AM
For those using the ST80 for solar, what do you think of it overall? What white light filter do you recommend? Are there false color images present?
#10 Don W
Don W
    demi-god
Posted 13 October 2018 - 10:53 AM
No false color that I can see. An achromat works fine for solar viewing. I would suggest either making your own cell using Baader film or buying a filter with Baader film. I like my sun funnel. Works great for group viewing.
  • James Paulson likes this
#11 James Paulson
James Paulson
Posted 15 October 2018 - 06:59 AM
I was looking at the one that Orion sells and I think that is the way I will go. I should have one instrument suitable for solar viewing, and it seems nice and lightweight, good for those quick daytime views, and quite honestly I am not using it for anything else.
