In this case, there are some very interesting aspects to the pattern. Very clearly, there are concentric diffraction rings in each of the diffraction spots - as if they were out-of-focus stars. I had not seen this before. This is an integration of 206 600-second Ha subs so the data is pretty clean.
Another interesting aspect is that the pattern is so consistent between subs, despite a heavy dither. If this were a reflection artifact from the microlenses, one would expect the artifacts to move around as the star falls in the microlenses differently after each dither. So, my conclusion was that it is a diffraction artifact, not a reflection artifact.
So I did some literature searching and found the answer. This is, in my opinion, the Talbot effect, first observed by Henry Talbot in 1863. Talbot observed that when light is incident upon a diffraction grating, the image of the grating repeats at a distance (or multiple of) called the Talbot length defined as:
Zt = 2a^2/lambda
Where "a" is the grating spacing and "lambda" is the light wavelength. As applied to microlenses, here is my take. The Talbot effect would form a reflected Talbot image the Talbot length in front of the sensor. In my case, the "grating" spacing is 3.8u or 3800nm and lambda is 656nm. The Talbot length is then 44,000nm or 0.044mm. So, the Talbot effect is forming an image of the microlenses about 0.044mm above the sensor plane. Another Talbot image is created at every additional Talbot length between the sensor and the cover glass. These images are then reflected off of the sensor cover glass and imaged by the pixels. However, these images are out-of-focus by the distance from the Talbot image, reflected off of the cover glass and back to the sensor. So, the Talbot image closest to the cover glass forms the smallest artifact, and those closer to the sensor form the larger ones.
At least that's my take on it. I need to do some more research on the Talbot effect, but I think this is the right track. In fact, there is a paper that I am studying now that discusses the Talbot effect on microlenses:
https://www.suss-mic...onal_Talbot.pdf
So, at least we now have a name for it.
Tim
