Can I use 19mm thick plate glass to grind 14 inch mirror ?
32 replies to this topic
#26 ed_turco
ed_turco
  • Loc: Lincoln, RI
Posted 19 January 2020 - 11:19 AM
Someone pointed out that a great amount of experience is required for such a project.  I have 60 years of experience as an ATM and I wouldn't touch such a project -- ever.
#27 GTom
GTom
Posted 19 January 2020 - 11:31 AM
I don't mind wasting $120 worth of plate glass :D. ATM is not a for-profit operation anyway. Obviously I'd approach a $1600 pyrex blank with more care.
  • brave_ulysses likes this
#28 Pierre Lemay
Pierre Lemay
  • Loc: Montréal, Canada
Posted 19 January 2020 - 01:36 PM
Ed, I have almost 40 years of ATM experience including the fabrication of more than half a dozen mirrors, up to a 20 inch f/3.9, 1/2 inch edge, conical mirror. I know going into this project, eyes wide opened, that my chances of successfully parabolizing a smooth, 1/4 wave curve are slim. It will be a frustrating struggle, including the fabrication of the 7 inch m.a. diagonal.
However, whether I am successful or not, it will be fun and educational. And if I succeed?: The prize is a 100 pound, 28 inch quasi-flat footed telescope that will be a pleasure to transport, store and observe with.
  • brave_ulysses and sopticals like this
#29 macdonjh
macdonjh
Posted 19 January 2020 - 03:05 PM
Just curious: is the temperature used to slump also hot enough for annealing?  If somebody had a strained piece of glass and slumped it, would it emerge from the kiln stress-free if it was cooled properly?
#30 GTom
GTom
Posted 19 January 2020 - 04:16 PM
Here is a project aiming for a 1" thick, 28" f3 Borosilicate mirror, not slumped (sry, only German). He hasn't finished it to diffraction limit that time and complained about support issues with the conventional 18pt cell.
AFAIK slumping is done at 650°C, annealing needs only around 500.
Edited by GTom, 19 January 2020 - 04:18 PM.
#31 Stathis_Firstlight
Stathis_Firstlight
    Stathis Firstlight
  • Loc: Germany
Posted 20 January 2020 - 12:54 PM
 Hello Samir,
17 years ago I made two 360 mm diameter with 20 mm thick boroslilicate glass (14" x 0.8") f/4.5 mirrors.
Details see here:
http://www.stathis-f...ingscopeeng.htm
With one mirror an ATM friend build an all aluminum ultralight travel dobson:
http://www.stathis-f...g_14incheng.htm
Although at that time I had no access to interferometric measurements to measure for astigmatism as well, the mirrors got really good with no astig visible.
So, it can be done this thin, if you follow consequently the rules of large thin mirror making. As you use plate glass, be prepared to spend more time with figuring, or accept to get an inferior accurancy.
Among the most experienced and talented mirror makers I know of, he is THE ultra thin mirror extremist. When he started this mirror, I was pretty sure, that this would work as a light bucked only with flaw Images at high power. He showed me, that I was wrong.
#32 Jack Day
Jack Day
  • Loc: Wenatchee, WA
Posted 20 January 2020 - 01:09 PM
My first mirror was a 14" f/5.4.  It turned out well, but I am not sure I would want to go much below that  if I did it again.  F/4.8 to F/5 seems like a good compromize.
Good luck!
#33 GTom
GTom
Posted 20 January 2020 - 05:26 PM
Amazing work indeed! As I gathered from the astrotreff forum, the scope well surpassed "atmosphere-limited" quality.
I was wondering, which, approximately same weight f3 28" design would sit better in the cell while pointing on the horizon:
- Conventional flatback, 11mm thin in the center but 1" strong rim touching the edge support
- Slumped, e.g. 19mm thin everywhere
- Mel Bartel's type "overslumped" with thicker center and thinner edge, again, using 3/4" material. Maybe try that with a 4" hole and Cassegrain type center support?
