Reworking an old Meade Starfinder mount
32 replies to this topic
#26 Tom Stock
Tom Stock
  • Loc: Saint Augustine, FL
Posted 26 August 2021 - 11:09 AM
Well I finished restoring my old starfinder mount.
I found that I could get replacement bushings (which were missing) from mcmastercarr.com, and I sanded all the rust off the dec shaft.  I may replace the shaft eventually but for now it's fine.  I also managed to get the DC drive working. Most of the set screws were missing, so I located those also.
I purchased a Meade SN-6 to put on this mount for now which should work for short exposure photometry images.
I needed to replace the 25lb counterweight.  I found a 11lb counterweight in my junk box, but it was for a 3/4" shaft, so I chucked it up in my mini lathe and bored out the center to fit a 1" shaft and painted it black.
I've always wanted one of these mounts. I remember drooling over photos of it in S&T in the early 90s when I got my first dob.  I have a thing for manual RA driven german mounts on pedestals.  I'll also be making a larger dec circle, but I haven't been able to do that yet as I broke my leg and required surgery so I've been locked up for weeks.
I have a 10" mirror blank on the way, and will eventually by grinding and polishing a the mirror for a 10" reflector which will also land on this mount.
Some day I really hope to find a Meade RG mount somewhere near Florida.  Just throwing that out there!
Edited by Tom Stock, 26 August 2021 - 11:17 AM.
  • Paul Hyndman, Marc-Andre, Bomber Bob and 2 others like this
#27 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 26 August 2021 - 02:42 PM
That looks very nice. Good job.
#28 Tom Stock
Tom Stock
Posted 01 September 2021 - 05:18 PM
There was a lot of drag on the shafts.  It took a lot of effort to rotate either shafts.  So I took it all apart, and it did come apart very easily.
I found a black grease on the plastic bushings, and cleaned it all up.  I replaced the old grease with some pink stuff my dad had.  That didn’t work, there was still too much friction.  I took it all apart again and cleaned up the pink stuff.  Just for the heck of it, when I reassembled it this time, I didn’t put anything on the bushings at all.  It actually seemed to help, but still not good enough, and took it all apart once again.
When I removed the bushings and cleaned the housing, I noticed that there were some dimples made with a punch where the bushings sat.  I guess these were to keep the bushings in place.  I felt that they were pinching the bushing and causing too much friction, so I filed them smooth.
After putting it all back together, I noticed a big difference in the shaft movement.  It was much better.  And after another disassembly I put a little light weight oil on the bushings.  That made another big improvement.
I’d like to replace the plastic bushings with metal ones.
This mount has a large RA setting circle, but a small DEC circle.  I had larger 6" setting circle so I replaced the small one.  I came up with a bushing with a 1" ID, and a 1-1/2" OD, and it will work fine.  A minor problem was that there wasn’t an indicator for the large DEC circle.  I made a 6" semicircle, drilled and tapped a hole on the housing, and bolted the new indicator to the housing.
More to come . . .
What did you use to color the dec circle black while leaving the engravings in the white?
Alumiblack and white engraving marking crayon?
Edited by Tom Stock, 01 September 2021 - 05:21 PM.
#29 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 01 September 2021 - 05:30 PM
The dec circle was untouched.  It was that way when I purchased it.
#30 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 01 September 2021 - 05:32 PM
I will be selling the belt drive motor that Geo made up, and the electronics, with the gear, and black housing.
I also will be selling the Starfinder mount, as the picture way back showed.  It has an AC CD, that was original to those type mounts.
It's a nice mount, I just have others so I won't be using it.
Edited by Garyth64, 01 September 2021 - 05:35 PM.
#31 Tom Stock
Tom Stock
Posted 11 September 2021 - 01:05 PM
The new one not the old one... how did you blacken it?
Edited by Tom Stock, 11 September 2021 - 01:06 PM.
#32 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 11 September 2021 - 02:26 PM
I forgot about the unpainted one.  I sold it a long time ago, and kept the painted one.
#33 Tom Stock
Tom Stock
Posted 12 September 2021 - 09:14 AM
Ah ok didn't realize they were two difference circles.
