Upgrading mount... iOptron CEM120
108 replies to this topic
#101 amoncayo
amoncayo
Posted 02 October 2019 - 02:40 PM
Five minute guided subs at 2.5 meters of focal length with 55 pounds on the mount. Not the improvement in eccentricity as the nigth work on. I attribute this to cool down of the mirror and stabilization of the atmosphere. I'm now 90 percent convinced that my copy of this mount works for that much weight and focal length.
Rgrds-Ross
Ross,
Can you share the fit files for image 34 and for either image 37 or 53? You can post those on the CEM user forum too, since here the file size limit is too small to allow looking at detail.
Al
#102 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 02 October 2019 - 06:03 PM
The camera is a fragment using the ASI071C-  a one shot color camera - so the output may look a little strange to you as they have not been de-bayered.  This is not the absolute corner but it's not the center either. The Planewave has an utterly flat field (it's actually amazing) so it usually doesn't matter (tilted cameras aside) where you take a fragment.
I moved the imaging system from my Paramount (thanks to my helper) without dismounting the imaging system. The results compare to what I saw on the Paramount. I was pretty amazed when after doing nothing the results changed. The seeing went off as the Jetstream moved in a bit later.
https://www.dropbox....age 23.fit?dl=0 is a link to another one (CCD Image23.fit) which you can peruse. That one has NGC6946 in the middle.
Someday my QHY will return from China and I'll put that back on with an improved adapter spacer and we'll see if this issue (for me) can be closed out.
Rgrds-Ross
#103 amoncayo
amoncayo
Posted 02 October 2019 - 06:07 PM
Rgrds-Ross
Thanks Ross.
I was hoping to see just "how much" elongation was visible in #34, since that was >0.5 eccentricity, relative to the good ones taken later. I'm assuming your guiding only became better as the night progressed? (Or maybe I missed that from your post..?)
Al
#104 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 02 October 2019 - 06:28 PM
No, actually the guiding got worse as the night wore on! By 4AM my subs were close to 3 arc seconds in my second system 10 feet away from the CEM120EC2
I think that what happened was that the mirror finally reached equilibrium and that the seeing improved between 7PM and 9PM. My imaging partner (who is vastly better at this than I am) never images at our location until about 2 hours after sunset. His advice to me when I was initially disappointed was to "wait" which proved to be correct. Once the temp stopped dropping I was surprised at the resultant change in image quality.
Nevertheless, I'm still thinking that there's something going on with the encoders, I'm just in a sweet spot of some kind. I'm very curious to see what happens when the big camera comes back.
I also use a 25" F8 RC scope from time to time. We actually use an air conditioner to cool that scope just before/after sunset or we get oblong stars sometimes all night. That scope is a truss design and we still needed fans to keep the airflow laminar where the truss ends and there is a short tube. It never occurred to me that the PW needed some extra cool down as it's been in New Mexico at 8000 feet for a long time where the thin air cools causes faster cooling and less tube current. (Or at least that's my latest crackpot theory.)
Rgrds-Ross
  • amoncayo likes this
#105 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 19 November 2019 - 10:27 PM
To close this one out, the system is now working just fine with the camera repaired. It's pretty clear that the QHY16200A camera's fan had enough vibration in it to cause the problem. Still very strange that the motion was clearly in the RA direction.
Rgrds-Ros
#106 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 20 November 2019 - 09:14 AM
Rgrds-Ros
I'd assume it vibrates in all directions, but excites the 'weakest link'.  So it's either easier in RA because there the gears are permanently moving, or its not even the mount but, e.g., some clamping in the optics train that happens to be RA-oriented.
(I had a hell of a time with the 2" clamping of my AP - not via vibrations, but it would sag under gravity pull, creating some tilt, and I thought my corrector is badly adjusted.... confused1.gif )
#107 DuncanM
DuncanM
  • Loc: Arizona Sky Village or the rain forest
Posted 22 November 2019 - 01:38 AM
Just an FYI, iOptron has release a new firmware for the CEM120/EC/EC2:
https://www.ioptron....cles.asp?ID=309 :
V20190718 Mount firmware package upgrade
What has been done in firmware:
 Improved CEM120EC/EC2 tracking stability under heavy payload
 Addressed sometime mount may run away during guiding
#108 rrice
rrice
  • Loc: Santa Fe, NM
Posted 01 January 2020 - 11:41 PM
I sold my CGEM and Love my now 1 year old cem 120ec. Soooo much better. 152 refractor and a 106 side by side no problems
  • Mbenj2405 likes this
#109 ScottS
ScottS
  • Loc: Central Ohio
Posted 01 April 2020 - 05:54 PM
Update to this old thread I started back in October 2018: So I'm move closer and closer to pulling the trigger on the purchase of the iOptron CEM120EC2.  I read a lot that this mount had quite a few software glitches etc. and wondering if the firmware issues have been improved by now? Still looking at the EC2 and the Tri-Pier 360. But wonder if there was really a big need for the extra encoder the EC2 has over the EC for imaging. I will probably still be go with the EC2 regardless, but just wondered about the EC2 vs EC. The other big reasons I'm looking at this mount is due to the cable management system and all the ports located on the back and front. I can see getting rid of  some many attached misc. accessories such as my RigRunner, USB Hus etc. and I think this is really awesome.
Edit [ I've also read that iOptron's customer support isn't the greatest and that there are still issues with the EC models.  I guess I don't mind dropping $6999 + 900 for the mount and pier, but I sure would expect it to be a quality working product with out a lot of issues that needs address etc etc.
Thanks again
Edited by ScottS, 02 April 2020 - 12:53 PM.
