Advice on mount and tripod for APM 100
94 replies to this topic
#1 Dougeo
Dougeo
  • Loc: Apache Junction, AZ
Posted 01 November 2018 - 03:49 PM
Hi all,
Need your help in determining which mount and tripod will function best with the APM 100 90 degree binoculars. The weight is 16.43 lbs  so I would need a mount that would adequately manage this. there are two I was considering; the first was a  Stellarvue M2C mount and tripod  and the other a Manfrotto 405 large 3 axis head and H/D tripod but would consider others as well.
I know it has the Stellarvue M2C has the load capacity but can be adapted to hold the APM 100 and if so what would I need to do so?
The Manfrotto 405 has a load capacity of 16.53lbs and with the APM 100 weighing in at 16.43 is cutting it pretty close.
Any help ,advice, options, ideas ,direction or otherwise is much appreciated!
Thanks for your help!
Doug
#2 hallelujah
hallelujah
  • Loc: North Star over Colorado
Posted 01 November 2018 - 04:19 PM
Manfrotto pro geared tripod #475 max. load capacity 26.6 lbs.
https://www.ebay.com...bndbG:rk:2:pf:0
Manfrotto Triman geared tripod #3246 max. load capacity 26.6 lbs.
https://www.ebay.com...b2i8K:rk:3:pf:0
There are more listed on eBay
Manfrotto 516 head. (max. load cap. 22 lbs.)
https://www.ebay.com...bvpfZ:rk:2:pf:0
Stan
Edited by hallelujah, 01 November 2018 - 04:31 PM.
  • StarDustBin and AIF like this
#3 AIF
AIF
  • Loc: Finland, Helsinki
Posted 01 November 2018 - 04:40 PM
Just bough myself 475B and it feels extremely sturdy. As a mount Im looking into MVH502AH, but it will be too light for your use.
#4 hallelujah
hallelujah
Posted 01 November 2018 - 04:43 PM
Max. load cap. is 15.4 lbs. for the MVH502AH.
Stan
#5 RickyD85
RickyD85
  • Loc: London/Kent, UK
Posted 01 November 2018 - 04:44 PM
I use 475B with N12 head, very nice setup IMO.
Edited by RickyD85, 01 November 2018 - 04:44 PM.
  • genelew, Dougeo and AIF like this
#6 genelew
genelew
  • Loc: Westchester County NY
Posted 01 November 2018 - 05:10 PM
This is what I have and I love it. So smooth and the counterbalance stabilizes the bino in whatever position you put it.
Gene
  • Dougeo likes this
#7 Dougeo
Dougeo
Posted 01 November 2018 - 05:14 PM
Thanks everyone for your input.
Stan, looks like the 516 head is strong enough, do you know what  is required to mount the APM 100?
Doug
#8 oldmanrick
oldmanrick
  • Loc: Western Montana, USA
Posted 01 November 2018 - 05:17 PM
I use the Manfrotto 161 Mk II tripod with a Manfrotto Model 400 geared head for my 45 degree ones.
I believe the tripod is rated for 46 pounds, and the head for 22 pounds.
These are somewhat spendy new, but usually can eventually be picked up on eBay for a more reasonable price.
The geared head has to be used backwards, (altitude crank/knob on opposite side from observer), as forward it only tilts up to 30 degrees.  Backwards it reaches zenith.  When sweeping the sky, this isn't too much problem for me, as I tend to move the Alt adjustment up or down about 3/4 of the fov, and sweep horizontally with the Az control.
This combination is rock solid and the head is very precise in it's adjustments.  I like this head very much for what I do, although most others seem to favor a HD video head.
  • Dougeo likes this
#9 GamesForOne
GamesForOne
  • Loc: Knoxville, TN
Posted 01 November 2018 - 05:33 PM
I really tried to like the MVH502AH but it was a no go after a couple of seasons of use and I sold it. The primary problem is that the friction drag has no adjustment range. It is either too loose, or too tight. There is hardly any in-between. I don't know if the bridged design is just that way -- or if I just got a bad one -- but since the counterspring is not alone enough to hold the weight you need that bit of friction drag. Even if the spring was adequate you'd still want some friction drag to keep it from moving too easily in the wind, etc.
I opted for used 503HDV (not the plain 503!). The older design has a much better friction drag.
Michael Mc
  • AIF likes this
#10 hallelujah
hallelujah
Posted 01 November 2018 - 05:48 PM
Doug
Doug,
I do not have the APM 100 or any BT's.
I'm sure that there are others that would be able to answer your mounting question.
Stan
#11 KGE
KGE
  • Loc: Connecticut
Posted 01 November 2018 - 06:11 PM
Bigger is better. I would recommend the Manfrotto 161mk2 tripod with an APM fork.
Kevin
Russian 12x60  60 o
Miyauchi 22x77 45 o
CXN Busch 10x80 45 o
Miyauchi 100-45 Fluorite APO
Miyauchi 100-90 Fluorite APO
APM 100-90 ED-APO
APM 120-90 ED-APO
  • Garfield, Tyson M and Dougeo like this
#12 hallelujah
hallelujah
Posted 01 November 2018 - 06:25 PM
Kevin
https://www.ebay.com... tripod&_sop=15
Stan
Edited by hallelujah, 01 November 2018 - 06:27 PM.
#13 SMark
SMark
  • Loc: Atlanta, GA USA
Posted 01 November 2018 - 06:37 PM
Doug
I use the 516 head with the 3068 tripod and it's a great combo. Check out the pics below...
Also, I use the Manfrotto 357PLONG plate in the 516 to attach it to the APM.
Edited by SMark, 01 November 2018 - 06:43 PM.
  • hallelujah, Dougeo and StarDustBin like this
#14 hallelujah
hallelujah
Posted 01 November 2018 - 06:44 PM
Stan
Edited by hallelujah, 01 November 2018 - 06:48 PM.
#15 Dougeo
Dougeo
Posted 01 November 2018 - 06:51 PM
Kevin, what are you using for your APM 100-90?
#16 Dougeo
Dougeo
Posted 01 November 2018 - 06:59 PM
That's what I'm looking for, how does the whole rig work for you?
Doug
#17 KGE
KGE
  • Loc: Connecticut
Posted 01 November 2018 - 08:00 PM
Here's the 100-90 on a 161mk2 and APM fork. It is a very stable combination.
Kevin
  • Tyson M, duck2k and StarDustBin like this
#18 Dougeo
Dougeo
Posted 01 November 2018 - 08:33 PM
Kevin
Very nice!
#19 SMark
SMark
Posted 01 November 2018 - 09:01 PM
Doug
It works great. Perfect, as far as I'm concerned. I'm not one to overspend, though you can't go wrong in this business when you do. My setup was purchased on eBay for just a few hundred dollars.
  • hallelujah likes this
#20 duck2k
duck2k
  • Loc: Fountain Hills, AZ
Posted 01 November 2018 - 10:04 PM
I find the Oberwerk wooden tripod is just right with the APM fork mount.  It can handle up to 40lbs and you have the convenience of adding an eyepiece tray.  Great set up, and easy to break down.
Edited by duck2k, 01 November 2018 - 10:06 PM.
  • Tyson M, gozer, Dougeo and 1 other like this
#21 Dougeo
Dougeo
Posted 01 November 2018 - 10:43 PM
Very nice set up!
I like the fork mount but the only place I have found that has it in stock is Farpoint Astro for about 743ish. Where did you find yours?
  • duck2k likes this
#22 Dougeo
Dougeo
Posted 01 November 2018 - 11:01 PM
I've been looking this evening for the 516 head new and not having too much success,seems it's been discontinued. Also been on eBay but can't seem to locate any used that look in good shape.
I found a new n12 but none used. I did find a nice use 3068 tripod so making progress
#23 SMark
SMark
Posted 01 November 2018 - 11:11 PM
The 516 is discontinued, but regularly come up on eBay, and the N12 is pretty new.
I was going to say that the one that Stan linked to above was a good one, but I see it's already been snatched-up...
#24 hallelujah
hallelujah
Posted 01 November 2018 - 11:14 PM
https://www.ebay.com...bvpfZ:rk:1:pf:0
Stan
#25 SMark
SMark
Posted 01 November 2018 - 11:15 PM
A bit more expensive, but this one is near new...
https://www.bhphotov...-BoCY9YQAvD_BwE
