.965 Eyepieces: Who is still using them? Showcase them here!
#28
Posted 02 November 2018 - 06:46 PM
Terra,
What a collection!
Besides the Jena Ziess, what would you say are next in terms of optical quality?
- Terra Nova and ANM like this
#30
Posted 02 November 2018 - 06:51 PM
Edited by terraclarke, 02 November 2018 - 06:52 PM.
#31
Posted 02 November 2018 - 06:57 PM
And a few more Celestron circle Ts (40mm Kellner and 5mm and 4mm Orthos):
Hmm... a 4mm Celestron ortho. Maybe something to try. Would be good for lunar and splitting doubles
#32
Posted 02 November 2018 - 07:05 PM
- steve t and Bonco2 like this
#33
Posted 02 November 2018 - 07:17 PM
Side question related to the 0.965" eyepieces. Do any of you that use 0.965" eyepieces also use them along with a 0.965" barlow?
I have a couple of the 0.965" barlows that came with my classic scopes but I have not really used them other than to see if it works because they are too long. Have not done any critical viewing to determine quality
#34
Posted 02 November 2018 - 08:07 PM
What's in the pretty box???
Who cares about the ep's, where dja get the box???
#35
Posted 02 November 2018 - 09:41 PM
Between my Zeiss and Pentax .965's", my 1.25" ep's barely get any use for high power observing. Here's my Zeiss ep family, forgive the OTA's and 2" ep's but I wasn't going to reshoot this.
Ortho's to the left, Huygens to the right and Wide in the middle. The O's and W get regular use, the H's not so much.
- roscoe, steve t, Sasa and 5 others like this
#36
Posted 02 November 2018 - 11:31 PM
The Meade 134 that Telescope Warehouse sells is really good. I can't reach focus with the barlow after the diagonal and it's about 2.6x before the diagonal. It works great with the 60mm f7 and 12.5mm Tani ortho. Too much magnification with the 5mm Orion. Next time out I'll try it with a recently acquired 9mm Criterion AR.
#37
Posted 02 November 2018 - 11:33 PM
Terra,
I don't think I have ever seen a compression ring 0.965" diagonal. Who makes them?
I'm not Terra, but.... Swift diagonals have compression rings.....and nice prisms, too. A little hard to find, though....
- Terra Nova likes this
#39
Posted 03 November 2018 - 12:24 AM
Thanks roscoe. Will keep an eye out for them
#41
Posted 03 November 2018 - 12:31 AM
Jaimo!,
lovely looking set of eyepieces. What the one in the middle front row?
#43
Posted 03 November 2018 - 02:26 AM
Terra,
Takahashi used to make one. Good luck finding one, though.
If you can stomach the cost, you could make yourself a really high-end 0.965" diagonal (or really a 0.965"/1.25" diagonal) from Baader parts, plus a 0.965"/T2 adapter from Aliexpress. It'll be bigger than a common 0.965" diagonal, though.
Clear skies!
Thomas, Denmark
- DMala likes this
#44
Posted 03 November 2018 - 08:53 AM
Jaimo!,
Pentax XP-8, it was designed for a camera projection. But still works nice, but the eye relief is a little tight.
Jaimo!
#45
Posted 03 November 2018 - 10:12 AM
Clear skies!
Thomas, Denmark
I think a cheaper route is to get a celestron 1.25" prism diagonals and then put an 0.965 to 1.25 adapter in the nose and then put a 1.25 to 0.965 compression adapter on top. May be a little heavy.
#46
Posted 03 November 2018 - 10:43 AM
Cheaper, yes, but also requires much more back focus.
Clear skies!
Thomas, Denmark
- salt2001 likes this
#48
Posted 03 November 2018 - 11:29 AM
Thanks Terra for posting a picture. Will keep an eye out for it if it ever comes up in the classifieds
#49
Posted 03 November 2018 - 02:16 PM
Almost no one made 8mm 0.965" eyepieces in modern times. On top of my hat I can think of only four: Carton (8mm plössl), Vixen (huygenian-mittenzwey), Spectros and Zeiss (both orthos). The 8mm Zeiss ortho is made in only one batch and in very small numbers and sells for outrageous amounts of money (+$1k) among collectors, who now own almost all of them.
There's probably others as well, but compared to the number of other focal lengths that are easily available, 8mm is a rare bird and not easily found.
Clear skies!
Thomas, Denmark
Thomas, this is an 8mm worth looking for. Nothing is stamped or labeled, maker or focal length. The body is delrin with a rubber eyeshield that has micro-focusing via diopter adjust. It is very light weight due to the construction materials. The camouflage pattern and diopter adjustment leads me to think that they were made for a spotting scope. The glass and coatings are very nice and the images are very sharp to the edge. I believe the design is a König, but I am not certain. The field is wider and sharper than a typical Kellner. This one was given to me several years ago but I believe Bill Vorce of Telescope Warehouse used to sell them. It is my only 0.965” 8mm eyepiece. My Carton 8mm Plossl is my only 1.25” 8mm.
- Astrojensen and Bomber Bob like this
#50
Posted 03 November 2018 - 02:23 PM
It's a former binoculars eyepiece (pocket compact binos). Konig. Have one I got from him.
- Terra Nova and Bomber Bob like this
