I'm not sure how much of it is actually working. It slews to object in both Stellarium and Worldwide telescope and follows the mount as i slew with hand controller. With Stellarium i downloaded Stellariumscope and use it as go between from computer to mount. I will take screen shot and upload for the settings in stellariumscope. Once the settings were right i hit the update stellarium button and it loaded the settings into stellarium under available telescopes. I have found that it seems to work every time if i start my mount with the cable disconnected from my hand controller and connected to my computer. Go through initialization and then connect the cable to hand controller. Then i fire up stellariumscope and make sure its saying the localhost ports are showing connected then start stellarium. Worldwide Telescope was much simpler to connect. Just went to telescope menu and selected driver under the setup button, hit connect and it was up and running. slews work, park button works, sync button works. directional buttons did not work. If the slews are accurate ill be happy with the 30$ spent.
This sounds to be exactly how I have attempted to use Stellarium with the EXOS-2GT including when to physically connect the handbox to the computer. On the rare occasions, it works for a short while. Most times, it simply won't work at all right from the get-go. Other times, it works briefly but after a very short while (after one slew), Stellarium Scope crashes and drops out. And, I get the same results on both of my computers... a Lenovo Ryzen desktop and a MS Surface tablet.
Although I have not had time to touch any of this since early Friday afternoon, I have had far better success with Cartes du Ciel and Starry Night 7 Pro Plus. Actually, using Starry Night 7 Pro Plus was impressive the little bit I used it. I'm still familiarizing myself with both of those programs though.
I might have some time early this week to do some testing again. However, most if not all of my time will be spent with Cartes Du Ciel and Starry Night 7 Pro Plus. I had so many problems getting Stellarium and Stellarium Scope to simply run stable, nevermind effectively control my mount, that I doubt I will spend any more time on Stellarium.
I am glad to hear that others are still trying to work out the bugs.
Patrick : )
Edited by PatrickVt, 16 December 2018 - 10:59 PM.
