Restoring a '59 Cave 10" f/7.1
163 replies to this topic
#126 Guy Earle
Guy Earle
Posted 20 April 2019 - 09:25 PM
Pic 2 of 3.
  • Mr Magoo, Jeff B, gelkin and 1 other like this
#127 Guy Earle
Guy Earle
Posted 20 April 2019 - 09:26 PM
Pic 3 of 3.
  • Jeff B, gelkin and Bomber Bob like this
#128 Guy Earle
Guy Earle
Posted 21 April 2019 - 05:58 AM
Okay, I have a bit more to report since I went out this morning than after sunset last night (see page 5). Ironically, I really didn't get to test the mirror until the 21st, so it really did get its 60th second light.
The drive works smoothly and tracks well despite the declination needing about 14 degrees adjusted. My biggest issue, that makes the scope difficult to use, is what seems to be slop in the right ascension. I have to go past an object about 5 degrees until I feel resistance, then let it fall back into view. I can slowly pull the object into view, but not in the other direction. There's no knob to tighten it down, and I was working on the balance making small adjustments on the counterweight, but it never got rid of the slop.
Can you all offer suggestions? Am I just not balancing close enough? Is there something with the gears or a means to tighten it that I have not done?
Thanks, and I've attached a couple lunar pics I took with my phone at the eyepiece. To the eye the Moon was crisp, but the phone was being difficult through the eyepiece.
Guy
Edited by Guy Earle, 21 April 2019 - 06:00 AM.
  • Bomber Bob likes this
#129 Guy Earle
Guy Earle
Posted 21 April 2019 - 10:45 AM
Update: so I checked this morning, doing the initial balancing and looking for anything shifting with the tube and counterweight lateral to each other. I took the cover off the motor and three screws had come nearly out on rear plate, two on top and one underneath the shaft. Tightening those up got rid a vast amount of the sloppiness. Are there only three? I see other holes, and I'm wondering if other screws had worked themselves out over the years.
Guy
Edited by Guy Earle, 21 April 2019 - 10:46 AM.
  • Mr Magoo and Bomber Bob like this
#130 KentTolley
KentTolley
  • Loc: Southern California
Posted 21 April 2019 - 12:04 PM
Those 3 screws attach the rear plate, as you call it, to the polar housing.  It is actually the cover to the clock housing  But loose you would get vibration in the mount.  To your 2nd question, yes.  Any loose screw is nfg.  Check them all.   Legs, pier, pier cap, mount, saddle, rotating rings.  Lift the tube in its rotating rings to check any looseness at the pier cap.  One9 of my scopes is loose there now and I didn't notice it till I checked for too much slack in the rings and the entire mount rotated about the big bolt and nut in the pier cap.  For 50-something years it has only been the weight of the dec axis that has held the whole thing from rattling  around.
Edited by KentTolley, 21 April 2019 - 12:39 PM.
  • Guy Earle likes this
#131 tim53
tim53
  • Loc: Highland Park, CA
Posted 21 April 2019 - 12:23 PM
Since the back plate supports the worm block, there will be movement of the worm block and that could easily add up to quite a lot of slop in RA.  once you get these and other mounting srews snug, make sure the scope is well balanced, and adjust the clutch for the RA until you get just enough tighness to hold the scope in position but not so much that it's hard to move by hand.  And that's pretty much it!
-Tim.
  • Guy Earle and KentTolley like this
#132 KentTolley
KentTolley
Posted 21 April 2019 - 12:28 PM
This is the mount that can rotate about the big bolt.  This single bolt does not hold the mount securely to the pier cap.
Edited by KentTolley, 21 April 2019 - 02:08 PM.
#133 KentTolley
KentTolley
Posted 21 April 2019 - 12:31 PM
This works much better.  Even here while taking a pic I checked and sure enough one of these set screws was loose.
#134 KentTolley
KentTolley
Posted 21 April 2019 - 12:36 PM
BTW if those 3 screws on your mount were allen heads you would be able to tighten them with the big gear and clutch plates in place. I have only disassembled 3 Cave mounts but in each case these screws were allen heads.
Edited by KentTolley, 21 April 2019 - 12:37 PM.
#135 KentTolley
KentTolley
Posted 21 April 2019 - 12:55 PM
(aside)  Thinking I may have a loose screw on my 10" I checked the bolt locking the pier cap to the mount and though it felt tight I was able to further tighten it with a socket wrench and that fixed it.
Still the two set screws are better than one big bolt with course threads.  When it's convenient I'll drill the pier cap for those 2 set screws.
Edited by KentTolley, 21 April 2019 - 01:06 PM.
#136 Guy Earle
Guy Earle
Posted 21 April 2019 - 09:47 PM
Thanks for the info, as I was concerned that another had fallen out at some point. I thought I had checked them all when I fixed the cord, but I missed those. Everything is happily snug now and it seems really good. I'm getting up again tomorrow morning for another test while the Moon and Jupiter are in a good part of the sky for me.
  • KentTolley likes this
#137 Guy Earle
Guy Earle
Posted 21 April 2019 - 09:49 PM
-Tim.
Tim,
I've checked everything you've mentioned except for adjusting the clutch for the RA. How does one do that?
Guy
#138 KentTolley
KentTolley
Posted 22 April 2019 - 06:59 AM
Tighten or loosen the 3 screws under the springs on the round clutch plate so you can move the scope in RA by hand but tight enough to hold the scope after you point it to an object.
Edited by KentTolley, 22 April 2019 - 07:54 AM.
#139 Guy Earle
Guy Earle
Posted 26 May 2019 - 07:18 PM
So the scope has been fully restored at this point and tracks smoothly. I'm used to the stiction of a dob, so I'm still tweaking the RA as I have to go a touch past an object to get the gear to engage and fall back onto the object. The mirror is super smooth and the f/7.1 has already shown some beautiful lunar views. I snapped two at the eyepiece with my Samsung Galaxy s9. Lastly, I did a quick fix on the focuser and tapped a set screw in order to keep the modification down to a minimum. Thanks to all who have helped along the way!
Clear skies,
Guy
  • astro140, gelkin, Bomber Bob and 1 other like this
#140 Guy Earle
Guy Earle
Posted 26 May 2019 - 07:19 PM
A few more pics.
  • astro140, Bomber Bob, CeeKay and 1 other like this
#141 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 27 May 2019 - 06:00 AM
Looks perfect!
#142 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 27 May 2019 - 01:19 PM
Caves are impressive looking scopes.  The bigger the better until you have to move it.
#143 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 27 May 2019 - 02:18 PM
12.5" Cave-Astrola Model D F/6, "Transportable".
Quote from the catalog always makes me laugh, "Total assembled weight of the Model "D" Transportable Astrola is 220 lbs. Yet, the instrument can be dismantled by one person in approximately five minutes time and stored inside a standard American stationwagon type of automobile for ease of transportation to a rural observing site."
#144 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 27 May 2019 - 07:12 PM
I would like to see a you tube video of someone doing that in five minutes.smirk.gif
#145 Senex Bibax
Senex Bibax
  • Loc: Ottawa, ON
Posted 28 May 2019 - 06:47 AM
Except there's no such thing as a standard American station wagon type of automobile any more.
#146 apfever
apfever
  • Loc: Colorado
Posted 28 May 2019 - 08:12 AM
that's a car invitation folks, but keep it brief or it will be kept brief.
#147 tim53
tim53
Posted 28 May 2019 - 10:11 AM
Lots of popular modern conveyances fit the role of the standard American station wagon (formerly known as the Depot Hack).  E.g., Vans, minivans, many crossovers and SUVs.
#148 Senex Bibax
Senex Bibax
  • Loc: Ottawa, ON
Posted 28 May 2019 - 11:27 AM
Not my intention to open that can of worms.. 'nuff said on this sideline
#149 Guy Earle
Guy Earle
Posted 21 July 2019 - 04:38 PM
Just a little update on the Cave. For the past month I've been relearning webcam imaging after a 10-year absence, and I'm currently using a 5MP Celestron Neximage and wanted to share the results.
Saturn, 7/19 in the Cave 10" f/7.1, 231 stacked images at 30% processed in Registax
Jupiter, 7/1, 503 stacked.
Moon, 7/10 while imaging the Apollo 15 landing site.
Clear skies,
Guy
Edited by Guy Earle, 21 July 2019 - 04:40 PM.
  • davidmcgo, tim53, Mr Magoo and 6 others like this
#150 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 21 July 2019 - 05:07 PM
Really nice Guy!
