Mr Magoo's Cave
118 replies to this topic
#101 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 07 December 2018 - 06:45 PM
I know Cave was using any tubes they could get near the end. Paper wound tubes and Meade Fiberlites.
  • Mr Magoo likes this
#102 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 07 December 2018 - 11:54 PM
Ken - no.  That is the Cave I got in 2012 from a fellow CNer in upstate New York.  It dates to March 1979...the optics are very good; the tube is a Sonotube, focuser is a 2"/1.25" Meade, the declination drive uses a segment arm, and the setting circles are Bakelite.  The mount and the pier are in excellent condition, and the legs are set up on casters...so I can roll it out of my garage on demand.
The Cave I've mentioned on your topic dates to mid-1975...was privately owned, then donated to a university from which I purchased it (they had used it for several decades).  Haven't star tested it yet.  The tube is a Parks product, focuser is 1.25" only, the dec drive uses a shaft mounted gear, and the setting circles are engraved aluminum.  It came without a pier or legs, but the university threw in three very large Edmund Scientific legs (probably from a '60's vintage 8" reflector that they no longer have).
John
Very nice!
#103 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 09 December 2018 - 12:46 AM
Well, I made a rather embarrassing mistake. As a sheet metal worker for more than 30 years I should know better than to trust someone's measurements.
I cleaned carpets most of the day and was relegated to the garage while they dried. To keep myself occupied I decided to finish stripping the OTA of all its accessories. As I removed the end rings I thought boy that tube looks bigger than the 14.5" that I was told. Grabbed my tape and lo and behold it is 15 5/16" O.D! I felt pretty darn stupid at that point and checked it a few more times. I figured out that they were measuring the inside of the end rings.
My apologies to everyone for getting it so darn wrong. Still can't believe I did that. I'm always preaching to my guys to never trust anyone's info, not even mine. Measure twice cut once right? I took two showers to get the egg off my face.
So as Paul Harvey would say, now for the rest of the story. My tube is 15.3125" O.D. as I just mentioned and the I.D. of the rotating rings are about 16". Now I see why they had to use the 16" rings. My question now is is this normal to have a tube over 15" O.D. with the rings 16" and a bunch of shims? Mine was shimmed with some sort of white plastic about 3/16" and 1/4" thick cork.
What I think I will do when I put it back together is to fabricate a shim from aluminum flat bar and attach it either to the tube or the ring and then use a strip of cork to fill the rest. I thought that if I attached the flat bar ring to the OTA then I could put the rings on without the worry of marring the tube.
Oh and I haven't counted them yet, but there are a bunch of extra holes in this tube. The oddest ones are on the rear end in line with the mirror cell holes, but more than 12" away from the end. Maybe they had a shorter focal length mirror in it at one time, who knows.
I have identified what a lot of the others are for. I am missing one counterpoise bracket. Don Rothman may have one in his warehouse of stuff.
  • terraclarke, TOM KIEHL and Defenderslideguitar like this
#104 Geo31
Geo31
  • Loc: Willis, TX
Posted 09 December 2018 - 08:55 AM
Ken, the tube diameter you have is not standard,  As others have said, apparently Cave had to get more creative in sourcing in the later years and I suspect that is the issue here.
The shims you describe should work fine.  I assume you’ll add some curvature to them.
I would assume the second holes for the mirror cell were for imaging (move the mirror up), but 12” seems extreme.  How far up are the “normal” holes?
#105 CHASLX200
CHASLX200
Posted 09 December 2018 - 09:31 AM
I saw a late 70's 12.5" F/5 Cave with a spiral wrap inside the OTA many years ago.  I think it could have been a Meade Fiberlite tube.  Parks always seems to have a rough inside with a clean seam and have that Parks smell that not other tube maker gave us.  I know that Parks smell a mile away. Even tubes that are 50 years old have that Parks smell when ya stick your head in there and sniff.
Guess i am a tube sniffer. Better than glue sniffing i guess.  Seems tube OD's also would vary by maker and years that Cave used.  All in all it seemed Cave used Parks until around 1976 then it was all over the board.
As for extra set of mirror cell holes, 1 to 1.5" seem to be the norm that i have seen.
Edited by CHASLX200, 09 December 2018 - 09:32 AM.
  • Mr Magoo and deepwoods1 like this
#106 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 09 December 2018 - 12:44 PM
I will get a piece of aluminum flat bar and roll it up to the correct I.D.
The mirror cell holes closest to the end are right at 2". There is another set at 3.375" and then the other holes that line up with them are at 14.5" from the end.
I counted all the holes (including the focuser hole) in the tube and the grand total is 65 holes! What the heck lol! So what is the best method to fill holes in a fiberglass tube?
#107 TOM KIEHL
TOM KIEHL
Posted 09 December 2018 - 03:00 PM
I use this https://www.smooth-o...products/mt-13/  with blue painters tape to back up the hole on the OD. and fill the hole from inside .  Can't reach the inside ? ..... put a glob of mixed epoxy on sticky side of blue painter tape , and press into hole and smooth tape over till hard , then remove the tape .
The best part of this product is IT'S WHITE !
Edited by TOM KIEHL, 09 December 2018 - 03:02 PM.
#108 CHASLX200
CHASLX200
Posted 09 December 2018 - 03:31 PM
So how do you order it? I sure don't need a big bucket of it.
  • TOM KIEHL likes this
#109 TOM KIEHL
TOM KIEHL
Posted 09 December 2018 - 03:46 PM
Duh foreheadslap.gif ohmy.gif  https://www.amazon.c...e/dp/B06XGNC42B
#110 CHASLX200
CHASLX200
Posted 10 December 2018 - 06:22 AM
Perfect. Better than caulk.
  • Mr Magoo and TOM KIEHL like this
#111 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 29 December 2018 - 04:18 PM
Working a lot of OT lately has not left me time to do much of anything. I had been soaking the stuck counterweight for several weeks in penetrant with no luck in getting it to move.
I decided to get a more aggressive with it and took it to work with me to put some pressure on it. I rigged up a poor man's shop press by welding together three of my shop horses and putting a 10 ton Porta Power in between them and the shaft. After about 6 pumps on the ram it let loose with a big pop. Another couple of pumps and it fell right through.
Now I need to figure out what I'm going to do with the weight and fix the shaft. As I figured, the weight has been drilled out to about a 1/2" diameter hole with no threads left. when someone could not get the set screw loose. Not sure what I will do with that. I may fill the hole by welding in a rod and drill and tap a new hole. I am also still toying with the idea of cutting it in half to make two weights out of it. The shaft has a place in it where they drilled into it that I will need to fill with weld and polish out.
  • tim53, astro140, clamchip and 5 others like this
#112 TOM KIEHL
TOM KIEHL
Posted 29 December 2018 - 04:37 PM
If it was I .......I would first make sure with a depth gauge that in fact the set screw IS gone .
2 . proceed with a soak of a penetrating fluid  of your choice .
3. remove OTA cradle , and Dec housing and bearings from cradle end of shafting .
4. Now all that remains is the bare shaft and stuck counter weight  .
5. sand rusty shaft (with Emery ) from counter weight face to toe saver end of shaft to a smooth rust free finish .
6. Now place a piece of hard wood on the concrete  floor . Pick up and hold OTA cradle end of shaft vertical with stuck counter weight hanging downward over the piece of wood .
7. Impact wood block with varied force with counterweight shaft end ( The "Emery sanded end " ) . Lifting counterweight and shaft up and down to impact stationary wood block on the concrete floor .
LET GRAVITY DO THE WORK........ Note : No parts are dented this way , like with a sledgehammer lol.gif
IF THIS PROCEDURE FAILS ........Get serious and take it to work and put it in a PRESS waytogo.gif lol.gif
" That's the way aha aha I like it " .....KC and the Sunshine Band band2.sml.gif
https://www.youtube....t=RDq3svW8PM_jc
Great work Ken ! I knew you could git " Industrial " wit it  lol.gif .
Just got to love those Porta Powers
Edited by TOM KIEHL, 29 December 2018 - 05:11 PM.
  • tim53, Mr Magoo, clamchip and 3 others like this
#113 tim53
tim53
  • Loc: Highland Park, CA
Posted 29 December 2018 - 06:04 PM
Well that may be a while as it sure don't get cold like it used to be.
You'll probably be 10 feet under water and 50 miles offshore before cold becomes a serious issue again...   step.gif
  • terraclarke and TOM KIEHL like this
#114 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 01 January 2019 - 09:03 PM
Got into the motor housing today. Lots of stuff going on in there.
  • TOM KIEHL and Bomber Bob like this
#115 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 01 January 2019 - 09:04 PM
  • terraclarke, TOM KIEHL, Geo31 and 1 other like this
#116 Mr Magoo
Mr Magoo
  • Loc: Indiana
  • TOM KIEHL and Geo31 like this
#117 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 01 January 2019 - 09:05 PM
#118 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 01 January 2019 - 09:06 PM
#119 Mr Magoo
Mr Magoo
  • Loc: Indiana
Posted 01 January 2019 - 09:08 PM
Looks like I have some demo work to do. A few extras that don't belong there. Not sure what was going on with that female plug.
