Setting circles on vintage mounts
14 replies to this topic
#1 Peter_D
Peter_D
  • Loc: Cologne, Germany
Posted 02 December 2018 - 08:41 AM
I have two Apollo 60/910s, a circle k 4013 and a later circle t 4016. To my beginner's eye, the 4013 has the better quality mount - solid, lots of chrome and practically no plastic. However, one thing that is missing which I found peculiar are setting circles. These are present on the 4016's mount.
My question is how common were setting circles on these types of department store eq1 mounts? Did the average observer use them?
  • Mr Magoo, steve t and Bomber Bob like this
#2 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 02 December 2018 - 10:21 AM
The average observer didn't use them. Mostly because most found it too complicated and on many mounts they were/are too small to be usable. They were pretty common, though, but were frankly often little more than mere decoration.
Clear skies!
Thomas, Denmark
  • steve t and Peter_D like this
#3 Richard O'Neill
Richard O'Neill
Posted 02 December 2018 - 10:22 AM
 Of the many telescopes I've owned or used the only setting circles I've ever found useful were those on a 3.5" Questar and a C8. If I can't see it or star hop to it I use GOTO.
  • pierce, steve t and terraclarke like this
#4 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 02 December 2018 - 11:06 AM
Your first picture looks similar to a 7TE-2 mount.
The setting circles are too small to be of any real use.
#5 pierce
pierce
  • Loc: Santa Cruz, CA
Posted 02 December 2018 - 11:12 AM
indeed, even in my C8 they were pretty much worthless, its easier to star hop, or my preference, use a telrad and match the circles with nearby stars in the same orientation as shown on the chart (which is skysafari on a tablet with the telrad circles enabled)
#6 Don W
Don W
    demi-god
  • Loc: Wisconsin, USA
Posted 02 December 2018 - 11:16 AM
Hmmm...........my first 'serious' telescope was a Celestron C90 Astro. I was able to find plenty of objects with it. In 1981 I bought a C8. I had no trouble using those setting circles. Used them to find all of the Messier objects and a whole bunch of NGCs.
As to the ones on the old spindly mounts, I don't think they were too much fun to use.
  • terraclarke and Geo31 like this
#7 Astrojensen
Astrojensen
Posted 02 December 2018 - 11:22 AM
They weren't. Been there, done that, got the T-shirt.
Clear skies!
Thomas, Denmark
  • rcwolpert and bremms like this
#8 roscoe
roscoe
    curmudgeon
  • Loc: NW Mass, inches from VT
Posted 02 December 2018 - 11:33 AM
I have sort-of used them sometimes, but agree that all those on smaller mounts are to look 'scientific', and work only somewhat.   I think they need to be at least 3 or 4" dia to be any sort of accurate, and have to have good pointers, and you have to be willing to give up your night vision to read any of them.....
All my EQ mounts have them, maybe 1 out of 20 times out I set them up, and often to find just one object.
  • terraclarke and rcwolpert like this
#9 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 02 December 2018 - 11:35 AM
IMO, since I use them frequently, the 7TE-2 mount, like the above 4013 mount, is not spindly.  The 4016 like my 6305a mount are not as good as the other two.  The tripods are another matter, and I have "fixed" them.
For the topic,  the setting circles on those vintage mounts weren't very large, and they were common on many of the "department" store scopes.  Seeing yours without them though, does look good.
#10 Astrojensen
Astrojensen
Posted 02 December 2018 - 11:37 AM
It's not worse that reading a map with a red light, if the setting circles are easy to read.
Clear skies!
Thomas, Denmark
#11 Astrojensen
Astrojensen
Posted 02 December 2018 - 11:42 AM
But why they have to be so small is a complete mystery to me. On many mounts they could easily have been 4" - 6" in diameter without even having to change anything else on the mount. And if the mounts had been designed for them, even mounts for small telescopes could have 6" - 10" diameter setting circles. Just imagine how much easier they would be to use.
Clear skies!
Thomas, Denmark
  • rcwolpert likes this
#12 roscoe
roscoe
    curmudgeon
Posted 02 December 2018 - 12:02 PM
Well, that's it..... a few of the vintage mounts had decent circles on them, so the makers indeed knew how, but..... I think most of the smaller mounts were made very inexpensively but 'real' looking, knowing that most would see starlight only once or twice, so why put the machine time into better stuff that won't get used anyhow...?
It's too bad...because with decent circles and some experience, (and appropriate lighting), they are faster, quieter, and just as accurate as GOTO....except you have to have charts available to get the numbers.
  • rcwolpert and Peter_D like this
#13 Richard O'Neill
Richard O'Neill
Posted 02 December 2018 - 12:18 PM
"But why they have to be so small is a complete mystery to me."
 They were designed for appeal at minimal cost by people who likely never used them. They are usable and better than nothing if all one has are coordinates but amateurs discovered more effective methods of navigating the sky.
#14 pierce
pierce
Posted 02 December 2018 - 12:26 PM
on my C8 (black tube model circa 1990), the dec circle was off by several degrees, with no apparent way of adjusting it.  with the 35mm plossl (my widest 1.25" eyepiece at the time) giving about 50 arcminute field of view, that error was more than enough to put things completely out of the field.   I never did get a 2" diagonal back for that scope to try and get a wider field.
  • Peter_D likes this
#15 terraclarke
terraclarke
  • Loc: Third from the Sun
Posted 02 December 2018 - 07:03 PM
The Zeiss Telementor GEMs, and also Unitron GEMs have very servicable setting circles- the black Unitron setting circles with white gradations and numbers (why did they make them shiny silver for a while!? :foreheadslap: ). Also, back in the day, my very first GEM was the Edmund 5/8” shaft mount that had those black fiberboard setting circles with printed white numbers and gradations and the nails set in the shaft collars for indexes. I actually got pretty good with them and found lots of things with their help. Where there’s a will, there’s a way! I also agree that the ones on my Questar, and also my orange C8 and C5 are very usable setting circles. They need to be big- 3” or more, and they need to be readable!
  • Astrojensen, rcwolpert and Peter_D like this
