December 2018 Observing Challenge
EAA
57 replies to this topic
#1 Alien Observatory
Alien Observatory
Posted 04 December 2018 - 03:06 PM
December is a hard Observing Time for most of us due to the weather and cold temps.  However M42 and the related Nebula Emissions in the M42 Area are the winter-time Jewels in the Sky.  M42, M43 and the Running Man Nebula (NGC1973/74/75), the Horsehead Nebula (IC 434) and the Flame Nebula (NGC 2024) are the most common images we see.  Several smaller Emission Nebulas are in the M42 area but seldom imaged due to their low brightness.
So the Challenge is to try to image the hard ones and give us a look at your Best M42 this December.
Most Descriptions from WIKI or SS5....Have FUN...
p.s. Added Comet C46P/Wirtanen as a Bonus Find as it will be closest to Earth on December 16, 2018...Pat Utah smile.gif
M42...The Orion Nebula (also known as Messier 42, M42, or NGC 1976 is a diffuse nebula situated in the Milky Way, being south of Orion's Belt in the constellation of Orion. It is one of the brightest nebulae, and is visible to the naked eye in the night sky. M42 is located at a distance of 1,344 ± 20 light years and is the closest region of massive star formation to Earth. The M42 nebula is estimated to be 24 light years across. It has a mass of about 2,000 times that of the Sun. Older texts frequently refer to the Orion Nebula as the Great Nebula in Orion or the Great Orion Nebula.
M43... Also known as De Mairan's Nebula and NGC 1982, is a star-forming nebula with a prominent H II region in the equatorial constellation of Orion. The De Mairan's Nebula is part of the Orion Nebula (Messier 42), being separated from the main nebula by a dense lane of dust known as the northeast dark lane. It is part of the much larger Orion Molecular Cloud Complex.     M 43 contains its own, separate small cluster of stars which have formed in this part of the Orion Nebula, and lies at a distance of about 1400 light years.
NGC 1973/74/75... The Running Man Nebula is found along Orion's sword of just north of M 42, these nebulae are between M 42 on the south and open cluster NGC 1981 to the north. Like M 42, NGC 1973-75-77 are also associated with Orion's giant molecular cloud, which lies about 1,500 light-years away. But these objects are dominated by the characteristic blue color of interstellar dust reflecting light from hot young stars.
NGC 1999... A 10th Magnitude dust-filled bright nebula with a vast hole of empty space represented by a black patch of sky, as can be seen in its images. It is a reflection nebula, and shines from the light of the variable star V380 Orionis.  NGC 1999 appears roughly 16.0 x 12.0 arcminutes in size.
IC 430... Another 10th magnitude Bright Nebula appearing in the constellation Orion. It is 154 light years from our solar system.  IC 430 appears roughly 11.0 x 11.0 arcminutes in size, corresponding to a physical diameter of 0.5 light years.
NGC 1990...  A 10th magnitude Bright Nebula appearing in the constellation Orion. It is 1337 light years from our solar system.   NGC 1990 appears roughly 50.0 x 50.0 arcminutes in size, corresponding to a physical diameter of 19 light years.
IC 434...The Horsehead Nebula, also known as Barnard 33, is a small dark nebula silhouetted against the glow of the emission nebula IC 434. Only by chance does the dark nebula resemble the head of a horse - but its coincidental appearance has led to its becoming one of the most photographed objects in the sky.
NGC 2023... Another 10th magnitude Bright Nebula appearing in the constellation Orion. It is 1533 light years from our solar system.  NGC 2023 appears roughly 10.0 x 10.0 arcminutes in size, corresponding to a physical diameter of 4 light years.
NGC 2024... The Flame Nebula is a beautiful emission nebula that covers a 30 arcminute area with patches of nebulosity cut by subtle dark bands and threads. A broad dust lane nearly bisects the nebula. A secondary dark lane runs from near the south end of the main rift into the eastern wing of the nebula. At least a dozen stars of magnitude 10 to 12 are embedded in the nebula.
IC 431/432...  These two nebulae are faint bluish glows around bright stars. IC 431 consists of two areas surrounding 8th and 9th magnitude stars. IC 432 is the brighter and larger of the two nebulae with a 7th magnitude illuminating star.
Comet 46P/Wirtanen... Comet 46P/Wirtanen was discovered photographically on January 17, 1948, by the American astronomer Carl A. Wirtanen. The plate was exposed on January 15 during a stellar proper motion survey for the Lick Observatory. Due to a limited number of initial observations, it took more than a year to recognize this object as a short-period comet.
Edited by Alien Observatory, 04 December 2018 - 10:08 PM.
  • geminijk, S1mas, roelb and 8 others like this
#2 Alien Observatory
Alien Observatory
Posted 04 December 2018 - 09:46 PM
Added Comet 46P /Wirtanen as a Bonus Find for the December Chalange as it will be closest to Earth on December 16, 2018...
On 16 December 2018 the comet will pass 0.0781 AU (11,680,000 km; 7,260,000 mi) (~30 LD) from Earth, reaching an estimated magnitude of 3 to 7.5, making this pass the brightest one predicted, and the brightest close approach for the next 20 years. Its magnitude could peak as bright as magnitude 3 near its December 16, 2018 closest approach.
Edited by Alien Observatory, 04 December 2018 - 09:55 PM.
  • roelb and cmooney91 like this
#3 Don Rudny
Don Rudny
  • Loc: Mauna Kea, Hawaii
Posted 06 December 2018 - 07:46 PM
Thanks for the add on of 46P/Wirtanen, Pat.
Here’s a capture from last night on Maunakea at 9200’ here on the Big Island of HawaiiUsed a SX Ultrastar C on an 11” RASA.  10x30s.
  • Ptarmigan, gun4hire, rob961 and 12 others like this
#4 Alien Observatory
Alien Observatory
Posted 06 December 2018 - 08:57 PM
Very nice set up Don and TY for the great image...Pat Utah
  • Don Rudny likes this
#5 Kaikul
Kaikul
Posted 07 December 2018 - 01:35 PM
Great capture Don.
Is it my imagination or is that a tail pointing to the 4 o'clock direction?
#6 Don Rudny
Don Rudny
Posted 07 December 2018 - 03:50 PM
Great capture Don.
Thanks, Kaikul.
You are not imagining things, but keep in mind that the RASA gives a mirror image right to left.  I’m working to get SX to implement a flip tool in SLL.
#7 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 10 December 2018 - 02:32 AM
Here are my images of M42, 43, Running man, IC 434/B33, NGC 2023 and 2024, These were taken with my AT60ED telescope and 294MC camera, using a Meade F/6.3 reducer/corrector and a UHC filter. Mouse over the pics for details on the images.
Edited by Stargazer3236, 10 December 2018 - 02:35 AM.
  • Rickster, elmiko, roelb and 5 others like this
#8 cmooney91
cmooney91
  • Loc: Massachusetts
Posted 10 December 2018 - 07:49 AM
Friday night  I was able to capture about an hours’ worth of motion of the approaching Comet 46P.
https://www.youtube....h?v=a9CjauTq6K4
It was clearly visible  as a concentrated glowing patch in 7x35 binoculars from Bortle 5 Sudbury, MA. I highly recommend trying to see it visually at least once before it goes.
I also looked at the flame  and horse-head with  a UHC filter for the fist time. I had to use longer exposures, but the increase in contrast on these emission nebula was err... astronomical.
I was using a  RT290 Mono through a 114x450 newt on a OnStep'ed Super Polaris
Flame Uhc filter 5000Gain 32sx7frames 224s Stretched
Horse head Uhc filter 5000Gain 32sx15frames 480s Stretched
Edited by cmooney91, 10 December 2018 - 01:13 PM.
  • Rickster, S1mas, Stargazer3236 and 5 others like this
#9 Alien Observatory
Alien Observatory
Posted 10 December 2018 - 11:54 AM
Very Nice images using a small telescope...TY Pat Utah :)
#10 Alien Observatory
Alien Observatory
Posted 10 December 2018 - 11:58 AM
It was clearly visible  as a concentrated glowing patch in 7x35 binoculars from Sudbury. I highly recommend trying to see it visually at least once before it goes.
Nice Video Capture of the comet (waiting for any clear skies this week here) and the RT Mono looks like it works well with your Newt...Par Utah :)
  • cmooney91 likes this
#11 selfo
selfo
  • Loc: Boulder CO
Posted 10 December 2018 - 04:09 PM
Here is my shot at the December EAA objects.  Quite a range of sizes here so tonight will concentrate on the ones I can see with my Wide field setup 80mm APO with 063 FR.  All pics taken with a UVIR cutoff filter with the exception of M42,43 which had a UVIR cutoff and Omega DGM filter stacked.  ASI 385 uncooled on Alt AZ. with  Master dark
M42 and M43.   51frames_510s_
Horsehead and NGC 2023 and Flame Stack_121frames_1210s_
Running man  Stack_81frames_810s
Hey Pat.  I  tried to image NGC 1990 but it’s too diffuse and large to see in my LP skies but I can sure see Alnilam.  Does that count?  LOL lol.gif
Stewart
Edited by selfo, 10 December 2018 - 04:46 PM.
  • Rickster, elmiko, saguaro and 5 others like this
#12 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 10 December 2018 - 04:20 PM
Gonna try to image and make a movie of Wirtanen tonight.
  • Alien Observatory likes this
#13 Alien Observatory
Alien Observatory
Posted 10 December 2018 - 04:37 PM
Stewart
Very nice images with the ASI 385 C and the 80 mm APO.  Those small scopes sure seem to work well (something I have not tried)...Pat Utah :)
#14 neaptide
neaptide
  • Loc: NY
Posted 10 December 2018 - 10:26 PM
Got a good view of comet 46P the other night under some very clear skies.
E.S. 8" Newt F/3.9
E.S. HR coma corrector
ASI294 Pro
CGX
Sharpcap3.1
21 X 15seconds  Gain 350  Temp. -10c
  • roelb, Alien Observatory, Art_NW AZ and 2 others like this
#15 Alien Observatory
Alien Observatory
Posted 11 December 2018 - 12:03 PM
E.S. 8" Newt F/3.9
ASI294 Pro
CGX
Sharpcap3.1
TY Great Image and you are the master of the file size rules (498.59 kb) ! ....Pat Utah smile.gif
Edited by Alien Observatory, 11 December 2018 - 12:48 PM.
  • neaptide likes this
#16 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 12 December 2018 - 12:38 AM
I spent the latter half of Monday night out in 15F degree weather. Winds calm, no dew, no mosquito's. Captured 46P/Wirtanen and NGC 1999. As always, mouse over each pic to get capture details.
#17 Alien Observatory
Alien Observatory
Posted 12 December 2018 - 11:29 AM
TY for your images, I was wondering what NGC 1999 would look like in an EAA setting.   Great Image (still snowing here)...Pat Utah smile.gif
Edited by Alien Observatory, 12 December 2018 - 02:18 PM.
#18 neaptide
neaptide
  • Loc: NY
Posted 12 December 2018 - 07:14 PM
LOL. I’ve been trying to get my image sizes as close as possible to the limit. The asi294 puts out big files so you gotta play with the resolution and compression sometimes. That one just worked out right.
#19 elpajare
elpajare
  • Loc: Begur-Spain
Posted 13 December 2018 - 03:00 AM
This is one attempt on NGC 1999, this monht..
SKW Quattro+ Risingcam IMX224
20x5"
Risingsky software
  • Rickster, roelb, selfo and 4 others like this
#20 Alien Observatory
Alien Observatory
Posted 13 December 2018 - 02:37 PM
20x5"
Risingsky software
TY for the image of NGC 1999.  The Risingcam 224 takes good images and provides a low cost alternate with good performance...Pat Utah smile.gif
Edited by Alien Observatory, 13 December 2018 - 02:39 PM.
#21 elpajare
elpajare
  • Loc: Begur-Spain
Posted 13 December 2018 - 03:43 PM
Yes, I am very satisfied with both the cameras and the software.
The small bugs of the software have been solved to me quickly those of Risingtech and now it works to me perfectly, even with the new chip IMX294 thah I received recently.
Thaks for comment..
#22 neaptide
neaptide
  • Loc: NY
Posted 13 December 2018 - 06:40 PM
Here's M42 from the other night. Sharpcap 3.2 really does a great job with the color saturation & HDR of this object.
E.S. 8" Newt F/3.9
ASI294 Pro
CGX
Sharpcap3.2
7 X 60seconds  Gain 200  Temp. -10c
  • nic35, Rickster, elmiko and 4 others like this
#23 Alien Observatory
Alien Observatory
Posted 13 December 2018 - 10:57 PM
E.S. 8" Newt F/3.9
ASI294 Pro
CGX
Sharpcap3.2
Very nice with the 294, I tried with the 178 Color (my planet/ Galaxy cam) and your results far exceed mine...will try with the ZWO 1600 if it arrives tomorrow...Pat Utah smile.gif
Edited by Alien Observatory, 13 December 2018 - 11:16 PM.
#24 Alien Observatory
Alien Observatory
Posted 13 December 2018 - 11:02 PM
My best attempt at M42 tonight... CPC 9.25 @F2.2, ASI 178 Cam, 15 seconds, 150 gain, single frame screen shot...Pat Utah smile.gif
Edited by Alien Observatory, 13 December 2018 - 11:05 PM.
  • elmiko, Stargazer3236, roelb and 3 others like this
#25 Alien Observatory
Alien Observatory
Posted 13 December 2018 - 11:04 PM
and 46P... CPC 9.25 @F2.2, ASI 178 Cam, 12 seconds, 300 gain, single frame screen shot...Pat Utah smile.gif
Edited by Alien Observatory, 13 December 2018 - 11:22 PM.
