N00b Q yet again: Who's correct about 46P/Wirtanen's location?
4 replies to this topic
#1 fewayne
fewayne
  • Loc: Madison, WI, USA
Posted 06 December 2018 - 02:24 PM
So if I run KStars for my location and, say 7 PM Dec 8, it thinks 46P/Wirtanen is 3h 39m 17s, +6° 16' 00". Easy-peasy. Since that's what I usually use to point my scope, I'm ready to go...right?
Except if I ask, say, the SkyLive Blog or JPL's Horizons ephemeris, translating local to UTC, I get significantly different answers. (Can't get the table formatted, so doing a screen shot -- sorry!)
Is there that much of a difference between the J2000 and J2018 epochs? Or is something else going on here? Should be something like 15' discrepancy, right, not 9 degrees!
Edited by fewayne, 06 December 2018 - 02:26 PM.
#2 RyanSem
RyanSem
  • Loc: Marietta, GA
Posted 06 December 2018 - 02:45 PM
I ran into this problem with SkySafari vs. Stellarium. Luckily they were both close enough to be within a couple FOVs so I just went from one to another I see which was accurate. In the end, SkySafari was correct.
SkyLive is the same as my SkySafari, so I would go with that.
Edit: Incidentally, tonight would be a very easy night to find it, being that it's right next to the star Azha (which is bright enough that I can see it in a border red/white zone)
Edited by RyanSem, 06 December 2018 - 02:46 PM.
#3 sg6
sg6
  • Loc: Norfolk, UK.
Posted 06 December 2018 - 02:51 PM
There is a reasonable difference. Skysafari uses 2018, university I visit uses the 2000 - big old catalogue of stars and objects. If you are inputting the RA+Dec then I would expect the 2018 to be the more accurate at this time.
If reading what a handset says, you do not really get a choice.
Guess it is caused by our movement and precession of the earth about its axis. May also be something from the elliptical orbit we have
#4 beggarly
beggarly
  • Loc: Belgium
Posted 06 December 2018 - 04:05 PM
I think you need to update the comet orbital elements in KStars.
I used C2A to calculate an ephemeris using the latest orbital elements. Set location to 43°4′N 89°24′W time zone UTC-6.
(I still may have overlooked something.)
Edited by beggarly, 06 December 2018 - 04:24 PM.
  • fewayne likes this
#5 fewayne
fewayne
Posted 06 December 2018 - 05:45 PM
A-HA! That was the key! Actually all I had to do was go to Data | Updates | Update Comets Orbital Elements and KStars was right with the others. But thanks for the link, too, with that I was able to update Stellarium too (which, oddly, didn't have 46P/Wirtanen at all).
Now I just have to switch my Raspberry Pi running StellarMate over to WiFi (instead of being a WiFi hotspot), do the same, and I ought to be able to do a GOTO Saturday night.
Sadly, I have commitments tonight and tomorrow both which will preclude astro, at least from a dark site. But I'm rubbing my hands for Saturday. (Will have to rub them a LOT on Saturday night, as it's expected to be 20° F / -7° C.)
