Thinking about the upcoming lunar eclipse...
6 replies to this topic
#1 aeroman4907
aeroman4907
  • Loc: Castle Rock, Colorado
Posted 06 December 2018 - 07:06 PM
Praying for clear skies and good seeing for the lunar eclipse next month!  He is an image from the lunar eclipse earlier this year that I am hoping to improve upon dramatically if I can get lucky.
  • Achernar, elmiko and kbev like this
#2 kbev
kbev
  • Loc: Far, far east Mesa
Posted 07 December 2018 - 03:58 AM
I'm the same way. Also hoping I can get a replacement motor for my CG5 so I can go out someplace with a clear view to the east - my neighbor has several very tall trees that block my view that way.
Sent from my Pixel 2 XL using Tapatalk
  • aeroman4907 likes this
#3 Achernar
Achernar
  • Loc: Mobile, Alabama, USA
Posted 08 December 2018 - 12:38 PM
So am I. Weather willing, I am planning to photograph the eclipse with my 8-inch EdgeHD and my Nikon F3 camera. I can get the whole moon at 2,000mm on the film in one frame, but with the .7X focal reducer I can get the moon nicely framed by the stars even if the eclipse is very dark. It will cut the exposure times in half. I can take a day off from work so I can stay up late enough to photograph it from start to finish.
Taras
Edited by Achernar, 08 December 2018 - 12:39 PM.
#4 james7ca
james7ca
  • Loc: San Diego, CA
Posted 11 December 2018 - 05:00 AM
You probably want a pretty wide field to capture a total lunar eclipse. I've often considered my Tele Vue NP127is at f/5.2 with an APS-C format camera to be nearly the perfect setup for imaging lunar eclipses. The contrast on the eclipsed moon is pretty low and you're really not going to be able to capture a great amount of surface detail regardless of your telescope. Also, the totally eclipsed moon can be surprising dark and so you probably want a pretty "fast" scope to do the imaging.
Here is something I did in September 2015 which was the last "good" lunar eclipse that we had from the west coast of North America. This captured stars down to about the 12th magnitude and the total integration time was 32 seconds (10 x 3.2 seconds).
If we have good weather (I'd rate the chances at less than 20%) this will be the first time that I might try to use a dedicated, CMOS, astro camera to image the eclipse as before I've always used a mirrorless Sony APS-C camera.
Edited by james7ca, 11 December 2018 - 05:07 AM.
  • Carol L, Achernar and aeroman4907 like this
#5 aeroman4907
aeroman4907
Posted 11 December 2018 - 07:59 AM
Nice capture James.  The eclipse last year was kind of a nightmare with having to image in small breaks in the clouds.  I also only had a 300mm lens with a 2x teleconverter and was shooting at f/11.  My post above came out darker than it does on my screen but I didn't get as much color with the conditions I had, which were pretty bad.  I may do a dual setup with my 8" EdgeHD and my Canon 5d M2 and a point and shoot on a tripod.  This is provided we have clear skies which is really more miss than hit at that time of year.
Good luck with your efforts.  Hope you have clear skies!
#6 lakeorion
lakeorion
  • Loc: Lake Orion MI
Posted 19 December 2018 - 03:17 PM
In case anyone hasn't run across this yet, the US Naval Observatory has an excellent local circumstance calculator online.
https://www.usno.nav...s/data-services
Now you can know when you need to be set up because it changes depending on where you are.
Still won't help with Michigan clouds in January, but at least I'll be able to point to a specific cloud and blame it for being in the way.
#7 kbev
kbev
Posted 19 December 2018 - 11:33 PM
Well the one major hurdle has been overcome - I ordered a new motor from Agena Astro and got it installed today. Just tested it indoors and no more runaway slew in dec! I also picked up an M8-1.0 x 45mm socket cap bolt to replace the alignment stud that went missing, had to cut off about 6mm to make sure it fit inside the mount but it works. I'll have to use the counterweight bar and hand control from my CGEM but as of now I have a mount that can hold my C6 and get me out of my back yard. No I just have to hope the weather cooperates
