Explore Scientific EOS T-ring
dslr equipment
5 replies to this topic
#1 1997xf11
1997xf11
  • Loc: Ottawa, Canada
Posted 06 December 2018 - 07:18 PM
Greetings!
I just purchase an Explore Scientific field flattener with EOS camera adapter for my ED80 scope. When I attach it to my T4i camera, I get either of the following message from the camera - "Firmware update failed. Try updating again" or "Err01 - Communications between the camera and lens is faulty. please clean contacts".
The camera is running the latest firmware and the contact have been cleaned. Any suggestions would greatly be appreciated.
#2 bobito
bobito
  • Loc: Litchfield County, CT
Posted 06 December 2018 - 09:22 PM
On my EOS M100 I had to put the camera in Movie Mode then change a setting to allow shutter release without lens attached.  I don't recall if I got an error on not, so not sure if this is your issue.  See about half way down this article for details:  https://support-hk.c...8203597900.html
#3 bill5wjw
bill5wjw
Posted 07 December 2018 - 04:17 PM
Sounds like that message has nothing to do with the flattener, as the flattener itself has no electrical contacts like a typical Canon lens (with auto focus ability for example). Connect a  Canon lens to the camera (if available) and see what message pops up- there appears to be an issue within the camera itself. Other than that, I see no reason why your scope/reducer/camera combination won't function normally-unless the underlying issue won't let the camera snap a picture.
#4 Melgabean
Melgabean
  • Loc: Colorado
Posted 07 December 2018 - 05:10 PM
Can you send us a link to which field flattener and t ring you purchased?
#5 1997xf11
1997xf11
Posted 07 December 2018 - 06:43 PM
Thanks for your replies. I should have been more specific in my original post. Indeed, the flattener itself is not the issue however the T-ring has what looks like some kind of chip and contacts glued to it. Here's the link : https://explorescien...ener-ffedapo-ca
and a photo...
The camera works fine with a regular lens.
Edited by 1997xf11, 07 December 2018 - 08:45 PM.
#6 Melgabean
Melgabean
  • Loc: Colorado
Posted 07 December 2018 - 09:41 PM
And you tried cleaning the contacts on the t ring? Those contacts are supposed to line up with the contacts in your camera. If lenses work and the t ring doesn't after cleaning I'd send it back and get a different t ring.
Also tagged with one or more of these keywords: dslr, equipment
