Intes Micro Maksutov
42 replies to this topic
#1 dweller25
dweller25
  • Loc: Lancashire, UK
Posted 08 December 2018 - 03:39 PM
Here is my IM715 ......
  • Deep13, siriusandthepup, IVM and 9 others like this
#2 Astroman007
Astroman007
  • Loc: Northern Ontario, Canada
Posted 08 December 2018 - 03:40 PM
  • bbqediguana and Simon B like this
#3 Eddgie
Eddgie
Posted 08 December 2018 - 04:49 PM
Very nice.  I don't have one, but I have always admired them.  I have had the 6" an 5" Intes MNs though and they were simply superlative.
  • Astroman007 likes this
#4 salico
salico
  • Loc: Germany
Posted 08 December 2018 - 05:08 PM
I had one IM715 three years ago;-)
#5 petert913
petert913
  • Loc: Portland, OR
Posted 08 December 2018 - 05:29 PM
Why does the secondary have a protruding mount?  Instead of just a silvered spot.   Is it collimatible?
#6 MortonH
MortonH
  • Loc: Sydney, Australia
Posted 08 December 2018 - 05:37 PM
Yes.
#7 Eddgie
Eddgie
Posted 08 December 2018 - 06:00 PM
The Intes Micro is a variant of the Maksutov that is called the Rumak (Rutten-Maksutov designed by Harrie Rutten.)
The silver inexpensive silver spot secondary means that you cannot easily have a different radius of curvature on the secondary mirror than on the rear of the corrector.  This is desirable because it allows you to correct for some aberrations that would normally be present in an MCT at f/15.
The US company Questar is reported to have cut the secondary mirror into a recess on the rear of the meniscus so that it could have a different radius of curvature than the rear of the Meniscus, but the Rutten approach is probably much easier to make (and of course we know that Questar scopes are hugely expensive, but that probably is just because it is a very boutique kind of offering).
The Rumak design simply puts the secondary on a separate surface so it can be aspherized easily to correct for aberrations that would otherwise be present in the Gregory design.
These are some of the best telescopes money can buy.
Edited by Eddgie, 09 December 2018 - 08:42 AM.
  • meade4ever, Astroman007 and Conaxian like this
#8 dweller25
dweller25
Posted 09 December 2018 - 08:33 AM
My IM715 now wrapped in thermal insulation and getting ready to observe Mars ...
  • Deep13, TG, R Botero and 9 others like this
#9 Astroman007
Astroman007
Posted 09 December 2018 - 02:27 PM
  • dweller25, Colin exraaf and Conaxian like this
#10 luxo II
luxo II
Posted 09 December 2018 - 04:41 PM
Er... we’ve done this before
https://www.cloudyni...k/?fromsearch=1
#11 dweller25
dweller25
Posted 09 December 2018 - 05:44 PM
Ooooops 😀
Edited by dweller25, 09 December 2018 - 05:46 PM.
  • Jaimo! likes this
#12 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 10 December 2018 - 04:25 PM
Yes its a Rumak or Sigler type Mak. Allows creating shorter faster focal ratios similar to SCTs, which require a different curve than just the back of the corrector.
Myself I have an MN56 (Intes Micro), Mk-67 (Intes), and a LOMO Astele 95.
#13 Kevin Barker
Kevin Barker
  • Loc: Auckland, NZ
Posted 14 December 2018 - 02:27 PM
Some shots of my three IM Maks. 815, 603 and 703. With an 8 inch Meade SCT in the top and middle shots for scale.
Shot 1 L to R 815, Meade, 603, shot two Meade and 703, shot 3 703.
I probably use the 603 the most these days, partly because of it's low mass which fits on  simple goto. The 603 and 703 are f-10 Rumaks and the 815 is an f-15.
Kevin
Edited by Kevin Barker, 14 December 2018 - 02:31 PM.
  • Deep13, Starman27, dweller25 and 5 others like this
#14 Tyson M
Tyson M
  • Loc: 53 degrees North
Posted 15 December 2018 - 01:52 PM
Here is my Intes Micro MN66 with a feathertouch.
It is a bit inconvenient on this style of mount because I cannot sit down, so I will be building a dob base on it.
  • dweller25, Mike E., Colin exraaf and 2 others like this
#15 Tyson M
Tyson M
Posted 15 December 2018 - 01:54 PM
Here is a closer up shot.
  • dweller25, Colin exraaf, jjack's and 1 other like this
#16 Tyson M
Tyson M
Posted 15 December 2018 - 03:45 PM
I have made the perfect dew shield out of a yoga mat.  Bonus, no painting or sewing required!
The outside diameter of the tube and focuser just barely fits around the elastic strap to hold it together!!!
I have put about 7-8" of extension past the corrector.
Edited by Tyson M, 15 December 2018 - 03:45 PM.
  • Starman27, dweller25 and Mike E. like this
#17 dweller25
dweller25
Posted 15 December 2018 - 04:44 PM
I have a similar dew shield and my wife made me the same elastic straps as you have - great minds think alike smile.gif
  • Mike E. and Tyson M like this
#18 Jeff B
Jeff B
Posted 15 December 2018 - 10:36 PM
Nice scopes!
One thing I learned real quick with my Intes scopes was that, while a noble idea, those stock baffled dew shield worked just horribly.  The baffles would allow heat from the corrector and tube to pool inside the shield and spill over the baffles into the light path, giving the scope a terrible case of the thermals.   Not only that, they are H-E-A-V-Y, adding weight up front, exactly where you don't want it.  An odd mistake for such an otherwise, well though out product.
Jeff
#19 Jeff B
Jeff B
Posted 15 December 2018 - 10:39 PM
Some of my current and former Intes scopes.
Jeff
  • Deep13, Starman27, dweller25 and 4 others like this
#20 Jeff B
Jeff B
Posted 15 December 2018 - 10:47 PM
And some more.
Trying to figure out where I parked the photos of the MN55, MN56, M615, M500 (a dynamite little scope)
  • Starman27, dweller25, Mike E. and 4 others like this
#21 Tyson M
Tyson M
Posted 15 December 2018 - 11:38 PM
Jeff
What do you still own, Jeff?
#22 agmoonsolns
agmoonsolns
  • Loc: Puget Sound
Posted 16 December 2018 - 12:47 AM
What rings fit the MN66 tube assembly? I was thinking about getting another set just for mounting finders/accessories on.
#23 Jeff B
Jeff B
Posted 16 December 2018 - 01:23 AM
I still own the APM MW MN86 and the Intes MN76, both very nice instruments.
  • Tyson M likes this
#24 Far Star
Far Star
  • Loc: Germany
Posted 21 December 2018 - 07:08 AM
My Alter M 703:
  • Starman27, dweller25, Mike E. and 3 others like this
#25 Far Star
Far Star
  • Loc: Germany
Posted 21 December 2018 - 07:10 AM
I love it!
  • Starman27, dweller25, Colin exraaf and 2 others like this
