EAA with a manual Dobson... it´s working!
EAA
137 replies to this topic
#26 Ubuntu
Ubuntu
Posted 17 December 2018 - 09:18 AM
Thank you Adun! I measured now with the measure stick and got down to a reduction of 0,58x which leads to F/D of 3.4. So a little bit better. On the ST80 i can reduce further with some spacers if I do not use the diagonal. However that is not an option on the dob. I'll try how it goes with 3.4. Doesn't sound too bad actually. There is always the option to stack multiple drifts.I assume Ubuntus stacked single drifts.
Hi Sondob... you're right I mostly stack single drifts... but repositioning the scope allows you to stack as many drifts as you want...
F/D 3.4 starts to be good but don´t forget that the objective is to go under 2 (exposition time will be divided by 2.5).
My advice would be to put a spacer to reach this F/D :)
But I'm already curious to see results with F/D 3.4 :)
#27 SonDob
SonDob
Posted 20 December 2018 - 05:52 AM
Hi Ubuntu,
I grinded down my camera box case to a more circular shape. The case looks really scary now but I am able to dive deep into the focusser without any adapters. This way I achieve a reduction factor of 0.33x with brings me down to a F/D of 1.93. I could test on the moon through some cloud hole and it fits completely into view so FOV is around 0.5 degree. Already impressive how slow everything drifts compared to before. I am able to integrate in-camera for close to 5 seconds before seeing star trails. Next test will be with sharpcap when clouds and moon are gone. Planning to go for that Horsehead Nebula on my bucket list.
  • Adun and cmooney91 like this
#28 Ubuntu
Ubuntu
Posted 20 December 2018 - 06:48 AM
Hi Ubuntu,
Niceeee :)
Could you tell us the telescope that you use ?
1.93, now we are speaking... can't wait to see the pictures when your sky is better :)
Have you already used sharpcap ?
#29 SonDob
SonDob
Posted 20 December 2018 - 07:16 AM
It's a skywatcher 205/1200 but I have access to a 305/1500 as well. So in the future I may try both. No experience with sharpcap so far except for the dry run to explore the live histogram stretching and capture settings.
  • Adun likes this
#30 Ubuntu
Ubuntu
Posted 20 December 2018 - 02:41 PM
Yeah it's important to play with the histogram... sharcap pro has also an autostrech function that does it automatically laugh.gif
Is your skywatcher motorized ?
Edited by Ubuntu, 20 December 2018 - 02:42 PM.
#31 SonDob
SonDob
Posted 21 December 2018 - 04:16 AM
No it is all manual. No EQ platform either.
#32 Ubuntu
Ubuntu
Posted 06 January 2019 - 06:01 AM
I did a little video to show what I'm seeing before stacking... :D
https://www.youtube....h?v=XxYw9eSeCm4
  • Ptarmigan, Asbytec, Adun and 1 other like this
#33 DSO_Viewer
DSO_Viewer
Posted 06 January 2019 - 01:53 PM
Nice but if you can I would put a tracking system on that Dob in order to maintain round stars which is making your image or viewing blurry.
Steve
#34 Ubuntu
Ubuntu
Posted 06 January 2019 - 02:55 PM
Steve
Hi... i can't afford a mount but I did this video to show what we could see... before stacking...
I'm usually stacking with a lower exposure to keep the stars round...
  • DSO_Viewer and SonDob like this
#35 Ptarmigan
Ptarmigan
    Lagopus lagopus
  • Loc: Arctic
Posted 06 January 2019 - 03:46 PM
The image looks good for 2 seconds and highest gain for IMX385 for Orion Nebula.
Andromeda and M81 and M82 are clearly visible under 1 second at highest gain.
How was the sky condition like?
#36 Ubuntu
Ubuntu
Posted 06 January 2019 - 06:21 PM
The sky condition where I live is quite good...
  • Ptarmigan likes this
#37 Lukes1040
Lukes1040
  • Loc: Ohio, USA
Posted 06 January 2019 - 08:00 PM
Fantastic results! I may have to give this a try. I have done planetary imagining in my manual dob, but have not given dso’s a go. Thanks for the inspiration
  • Ubuntu likes this
#38 Ubuntu
Ubuntu
Posted 07 January 2019 - 03:27 AM
Hi Ubuntu,
Hi SonDob... any results ? :D
#39 Ubuntu
Ubuntu
Posted 08 January 2019 - 09:27 AM
M81 & M82: 37 frames, total 37s
  • saguaro and Lukes1040 like this
#40 SonDob
SonDob
Posted 08 January 2019 - 09:37 AM
yes and no smile.gif So far I got one clear night only with the 8" under Bortle 5 skies but a lot of moonlight. I first played around without sharpcap with the hardware monitor only. As you remember I wanted to capture the horse head nebula. No luck. IC434 was not visible at all. However the nearby flame nebula was visible. I would say a liitle bit less clear and smaller then in your video. However, with much more noise - but that's ok and expected from using an analog camera.Having no luck with IC 434 and no stacking I wanted to use the notebook, but the capture driver crashed and I couldn't make it work outside. Bad luck. The rest of the night I stayed visual only in Orion to get that dark hole (nowadays assumed to not be a globule but a real hole) in NGC1999 of my bucket list.
Meanwhile the software problem is fixed and I am waiting for clear skies again.
Btw I tried the flame nebula with the 80mm Achromat without tracking and it is visible, too. Of course it appears much smaller and I could use a  longer exposure of 5s or so.
More to come
#41 SonDob
SonDob
Posted 08 January 2019 - 10:12 AM
Hi Ubuntu,
could you do me a favor please and try if you can see IC 434 without stacking or stretching? Under what bortle skies are you imaging?
Thank you!
#42 Lukes1040
Lukes1040
  • Loc: Ohio, USA
Posted 08 January 2019 - 10:17 AM
Hi Ubuntu,
Thank you!
IC 434 is very difficult to see without very dark skies or large aperture, filtered with an H-Beta filter. Stacking will most likely be required.
Edited by Lukes1040, 08 January 2019 - 10:17 AM.
#43 Ubuntu
Ubuntu
Posted 08 January 2019 - 11:25 AM
Hi Ubuntu,
Thank you!
Yes I did already IC434 and with the cam (no stacking) it is hardly visible... visible but very very faint...
I did a stacking and it gave that:
For me this nebula is very difficult because very diffuse...
  • Ptarmigan, Starman27 and SonDob like this
#44 Ubuntu
Ubuntu
Posted 09 January 2019 - 06:36 AM
Observations from yesterday night... with quite some wind... but thanks to the short exposure... was OK laugh.gif
IC434 horse head nebula: 29 frames, total 29s
NGC2014: flame nebula: 76 frames, total 76s
NGC7635 Bubble nebula: 61 frames, 61s
NGC 7023, Iris nebula: 54 frames, 54s
Edited by Ubuntu, 09 January 2019 - 06:36 AM.
  • Ptarmigan, Starman27, rob961 and 2 others like this
#45 SonDob
SonDob
Posted 09 January 2019 - 10:17 AM
Incredible, thank you. So it should be in reach. I saw it visually with the 8" at the same place some month ago. Probably the sky was not good enough when I tried with camera. Will try again.
#46 Ubuntu
Ubuntu
Posted 09 January 2019 - 11:22 AM
Here are some videos of the stacking to help you guys see what happens during the stack :D
https://www.youtube....h?v=qDcgzlA8dZc
https://www.youtube....h?v=2k-9DsMcMSU
https://www.youtube....h?v=ufHtXH4BNuU
  • Lukes1040 and SonDob like this
#47 Ubuntu
Ubuntu
Posted 11 January 2019 - 06:16 AM
M33: 44 frames, total 44s
Running man nebula: 35 frames, total 35s
NGC 891: 161 frames, total 81s
  • saguaro, Adun, Lukes1040 and 2 others like this
#48 SonDob
SonDob
Posted 11 January 2019 - 08:11 AM
Here are some videos of the stacking to help you guys see what happens during the stack laugh.gif
Thank you, very enlightening. I also like the one with the 50mm lens. Did you try stacking with it as well?
#49 Ubuntu
Ubuntu
Posted 11 January 2019 - 09:10 AM
I stacked with it but I did not do a video of the stacking :)
Yeah people tend to forget that having a huge FOV is also fun and there are couple of objects to stack :)
#50 mikenoname
mikenoname
  • Loc: Death Valley Region (Bortle 2 - SQM 21.9+)
Posted 11 January 2019 - 08:44 PM
So my choice was the Rising Tech IMX385, I got it at 285€ on offer and I took an X0.5 reducer from SVbony... I know the reducer is not of good quality (besides it was mounted upside down) but good as I didn't know where I was going and I preferred to ensure at the budget level smile.gif
Thank you for the hint with reversing the reducer. That made all the difference.
Confused. Are you actually reversing the direction of the focal reducer before installing it on the camera?
Also tagged with one or more of these keywords: EAA
