First mount
7 replies to this topic
#1 niccoc1603
niccoc1603
  • Loc: Firenze, Italy
Posted 09 December 2018 - 12:17 PM
Hi, I am looking at my first mount.
I have narrowed down the list to these three options that are in the same range
- iOptron EQ30pro, 15kg payload,
- Skywatcher Heq5 pro 15kg payload
- Orion Sirius 13.5 payload
Recommendations?
I want to control the mount from PC, including guiding from PHD via ASCOM. I understand with skywatcher I need a special cable for EqMod, not sure about Orion and iOptron.
iOptron has some extra features (like GPS) but I's also the most expensive.
What about gear/motors and tracking performance?
#2 scadvice
scadvice
  • Loc: Lodi, California
Posted 09 December 2018 - 02:45 PM
The iOptron models are the ones I know the best so I would opt for this one on your list.
iOptron iEQ30 Pro Equatorial Mount
Includes Tripod with 2" Diameter Legs & Hard Case  $1398.00
https://www.highpoin...d-case-3002e-hc
However here is a discussion about the HEQ5 vs the NEQ6 which will give you more information on the HEQ5 Pro
https://astrobackyar...m/heq5-vs-neq6/
Consider that the iEQ30 and the HEQ5  are actually almost the same price when both have the GPS.
Also consider that the EQ6-R Pro is only just a little over $220 more with GPS added and is a much more substantial mount.
I know nothing about the Orion Sirius so I can't comment on it compared with the others.
There's a saying here on CN and it's " Always go with the best mount you can, even at the expense of the ota."
  • bobzeq25 likes this
#3 bobzeq25
bobzeq25
Posted 09 December 2018 - 03:05 PM
Recommendations?
These are all closely comparable.  Performance likely varies more with individual samples, than across mounts.
You'll need a cable/adaptor for the iOptron,   "RS232-RJ9 cable" is included, but you also need this, unless your computer has an RS232 port (unlikely).
https://www.ioptron....duct-p/8435.htm
GPS is mostly needed for polar alignment, a PoleMaster will do that better/faster/easier.
I buy iOptron because the old man needs the light weight.  <smile>
Edited by bobzeq25, 09 December 2018 - 03:10 PM.
#4 Stelios
Stelios
  • Loc: West Hills, CA
Posted 09 December 2018 - 03:54 PM
The Sirius and the HEQ5 Pro are pretty much the same mount. I would take either over the iOptron simply because of a very long history of excellent performance with those mounts.
GPS is only an advantage if you don't own a smartphone *and* have no internet connection when imaging *and* forget to look up your intended site in advance. Not much of a reason to buy something.
Don't expect to use 15kg loads for imaging without performance degradation. Marketing and reality are different things.
#5 niccoc1603
niccoc1603
Posted 09 December 2018 - 05:05 PM
Thanks for reply
I will use a polemaster, so I understand GPS is not essential.
Both heq5 pro and eq30 pro can be controlled via ASCOM from PC and PHD2, correct?
I once red somewhere that the Sirius is lacking of the most modern connection, not sure about it.
#6 scadvice
scadvice
Posted 09 December 2018 - 08:33 PM
Thanks for reply
Yes they can.
#7 Simon B
Simon B
  • Loc: Vancouver, BC
Posted 09 December 2018 - 10:26 PM
Skywatcher HEQ5 = Orion Sirius
#8 bobzeq25
bobzeq25
Posted 10 December 2018 - 10:42 AM
Thanks for reply
The Sirius can do ASCOM.  You also may need the right cable for it.
http://eq-mod.source...t/reqindex.html
The 30Pro may be a bit easier to set up, could be I'm just used to iOptron.
I mildly disagree with Stelios, the 30Pro, the second generation of the 30 series, is a well sorted mount, a solid performer for that price class.
Edited by bobzeq25, 10 December 2018 - 10:46 AM.
