New A-P Stowaway First-lights, Reviews, and Shootouts
1179 replies to this topic
#1126 Moondust
Moondust
  • Loc: The Show Me State
Posted 08 November 2019 - 10:31 AM
Not exactly.  The dew cap flange is so shallow that it will come off by pushing on just one side of the cap.  The majority of drops are because you bump the cap on one side and it falls off.  If the flange were deeper then pushing on one side would just crimp the cap against dew shield.
For that reason, the felt they’re shipping will only make it slightly better by increasing the friction.  IMHO, the only correct solution is to have a deep enough flange that it can only go on and off if it is properly aligned.
Not sure if you misread or understood everything I wrote or if my description was just plain poor, but I think we agree. If the black retaining ring on the end of the dew shield were flush with the dew shield instead of protruding out as it does, or if the retaining ring were prutruding out as is but much deeper, then a deeper flange on the cap would work. As far as a solution to the present design perhaps Roland has something up his sleeve we are unaware of. The felt he sent out to those complaining may be just a temporary fix. Don't underestimate Roland, these are his babies as much as ours.
#1127 jay.i
jay.i
  • Loc: Minneapolis, MN
Posted 08 November 2019 - 10:41 AM
All this fuss about the lens cap makes me think about the commotion about the green lens coatings and China accusations rather fondly... smirk.gif glad we are back to nitpicking the little things.
  • eros312, pao and kkt like this
#1128 Moondust
Moondust
Posted 08 November 2019 - 11:08 AM
Ya, finally some action smile.gif.   Nitpicking is what's separates something merely adequate to something really special!
Edited by Moondust, 08 November 2019 - 11:09 AM.
#1129 stevenwav
stevenwav
  • Loc: New England
Posted 08 November 2019 - 11:14 AM
It's a tribute to the quality of the scope optically if all we do is discuss the mechanics. I'll take one!
  • Paul G, kkt and jeremiah2229 like this
#1130 jeremiah2229
jeremiah2229
  • Loc: Illinois, USA N 37° W 89°
Posted 08 November 2019 - 11:17 AM
LOL... since we're nitpicking I'll throw mine in. The powder coat paint, that is so slick in my old dry hands that I feel like I'm trying to hang onto a flopping bluegill to throw him in the bucket. And the cap is so tight on my example that I pull the dew shield out when I go to remove it. Surely, won't be keeping because of these, how could I?   ;)
Bottom line is this thing is dumping ALL the light into the airy disc. Best optic to ever be in my hands and even with the slickery paint and the too tight cap, I think it is staying right here.  waytogo.gif
Peace...
  • R Botero likes this
#1131 Fibble
Fibble
  • Loc: SE PA
Posted 10 November 2019 - 02:55 PM
Looking for advice/confirmation:
I want to get an adaptor to add my ZWO ASI1600MM Pro (actually to my ZWO EFW which is then connected to my camera), to my  AP92 Stowaway with the 0.8x telecompressor.  I need 64.1 mm of backspace according to A-P website.  I'm going to order a custom part to make up that space, so just wanted to make sure my thinking is correct.
0.8x Telecompressor --> 37.6 mm effective length adaptor (excludes threads from length of adaptor) --> ZWO EFW (20 mm) ---> ASI1600MM Pro (distance to sensor from front of camera (6.5 mm)).  This would total (37.6+20+6.5) = 64.1 mm.
**Edit *** looks like i should add 1mm more to take into account optical distance of filters....
I'm sure others have adapted this camera, or have gone through the same calculations, so any help is greatly appreciated.
Joe
Edited by Fibble, 11 November 2019 - 08:33 AM.
#1132 Zoomit
Zoomit
  • Loc: SoCal
Posted 11 November 2019 - 03:25 PM
Stowaway #249 first light was this morning's Mercury solar transit.  I had been waiting to get an appropriate mount but after briefly viewing the transit with my 80mm, f/7.5 achro and white light filter, I decided to try it out.  I was using a Manfrotto 055MF3 with 701RC2 head, which I normally use with 15x70s but it works ok with 80mm achro for terrestrial.  I moved the mount shoe to the Stowaway dovetail and determined that, with care, I could safely use the Stowaway on the 055MF3/701 combo.
The focuser was a little stiff but I got my Ethos focused on a bush on a ridgeline 5 miles away and knew this was going to be a different experience than with my other small telescopes.  I dropped in the Nagler Zoom and cranked it up to 3mm (204x) and was seeing limited at the low elevation but could resolve branches and groups of leaves.
After adding the white light filter, I watched the hole punch move across the sun for the next hour.  Seeing was remarkably steady, which allowed me to use powers that I never expected.  The mount was the obvious limitation, but I was able to learn the altitude sag pretty quickly and follow the sun at 100-200x fairly well.  This is not a setup I'd recommend, but it worked ok given the rarity of the Mercury transit.
My first impression opening the box was that the Stowaway is a very small telescope.  It's like my 130GT shrunk down by 50%.  The views of the transit at 200x defied what I thought a small telescope was capable of.  Admittedly, though, most of my smaller telescope experience has been with various achromats.  The Stowaway image held up to all the atmosphere could yield, which was a solid black pea on the face of the sun at 150-200x.  I dropped in my 2" 1.6x Antares Barlow and watched Mercury and the sun race across the FOV at the 4 and 3mm Nagler Zoom settings (245x and 326x; 68x/in and 90x/in, respectfully).  At 326x, the view was obviously darker and the 0.28mm exit pupil was noticeable.  That power was beyond what the atmosphere could handle and didn't add to the experience.  The best views were between 150-250x.  I never thought I'd see such a steady view of Mercury, as it's always so low in the sky at dusk or dawn.  So here I was with a steady sky and a small aperture and perfectly maxing out both.  The sky steadiness was limiting above 245x, which is right were the Stowaway exit pupil gets too tiny (0.38mm).
I need to give credit to the small aperture, and it's portability, for some of the "steady skies".  My initial views were across asphalt, which I realized was giving off heat.  I picked up my setup and easily moved it to the edge of the pavement.  This definitely helped.  I also know that using larger aperture would be looking through a wider column of air.  So my "steady skies" capable of 250x were in part due to the 92mm column of air I was looking through.
The Nagler Zoom deserves another mention, as it appears to be an outstanding companion to the Stowaway on a manually guided mount.  The ability to zoom out to 100x and then back in to 200x helps tremendously with finding and guiding at the eyepiece.  Manually tracking was a little frustrating on this overtasked mount but it would have been a much worse experience without the Nagler Zoom.
Another shout-out to the 2" 1.6x Antares barlow.  I really like it.  It's gentle on the light cone and relatively short and lightweight.
So I really enjoyed using the Stowaway this morning viewing the transit.  It easily showed me everything the sky could give in a compact package that I can't wait to use at night.  I don't expect to see Mercury so well resolved again until the next transit in 2032.  I expect I'll use the Stowaway again for that one.
Edited by Zoomit, 11 November 2019 - 07:14 PM.
  • k5apl, Erik Bakker, R Botero and 7 others like this
#1133 Bill Barlow
Bill Barlow
  • Loc: Overland Park KS
Posted 11 November 2019 - 03:48 PM
Thanks for the report.  But you will have to go to Europe or Africa to see it.  It won't be visible in North America.
Bill
  • MGD likes this
#1134 areyoukiddingme
areyoukiddingme
Posted 11 November 2019 - 04:11 PM
Thanks for the report x2.
I woke just before 7 this morn to be greeted by thick fog. Your report was exactly what I was hoping to do (but on a Stellarview MC2, which is working out great).
#1135 k5apl
k5apl
  • Loc: Arkansas
Posted 12 November 2019 - 09:32 AM
I put my solar filter on and it rained.  Clear day before yesterday, clear today.  Oh well.
#1136 moshen
moshen
  • Loc: San Francisco, CA
Posted 12 November 2019 - 02:33 PM
I really enjoyed the Mercury transit through my Stowaway and Daystar Quark Ha filter. The Stowaway performed excellent and the form factor and case was very convenient as I had to carry everything to a location with the best view.
I captured a minute of real time video of the transit through the Stowaway:
https://vimeo.com/372705899
  • Paul G, LLEEGE, turtle86 and 6 others like this
#1137 gwlee
gwlee
  • Loc: 38N 120W
Posted 12 November 2019 - 07:33 PM
Just received a message from Paige McDonald at AP saying they have a field installable fix for the loose dust cap that they will ship to me. Suspect that someone at AP monitors CN and spotted my blue tape fix on their $4K scope and barfed :-)
The new shims for the Stowaway cover arrived from AP today. Will try to install them tomorrow and report.
Edited by gwlee, 12 November 2019 - 07:50 PM.
  • turtle86 and jeremiah2229 like this
#1138 ron scarboro
ron scarboro
  • Loc: Raleigh, NC
Posted 12 November 2019 - 08:54 PM
I put 4 felt “shims” and it made it pretty tight.  I don’t think it is a permanent solution though.  If AP doesn’t permanently solve the problem, I’ll buy a soft cover.
  • edif300 likes this
#1139 rockstarbill
rockstarbill
  • Loc: Snohomish, WA
Posted 14 November 2019 - 08:11 PM
Not sure folks here follow the imaging forums as well, so here is the first integration I completed with the 92mm Stowaway:
get.jpg?insecure
  • Paul G, peleuba, Doug D. and 23 others like this
#1140 lcaldero
lcaldero
  • Loc: Albuquerque, NM
Posted 16 November 2019 - 07:04 PM
Stowaway #253 arrived in Albuquerque 11/15. And, of course, it’s cloudy! maybe tomorrow I will have first light.
Laura
PS So, I am kicking back with a glass of wine and telling the new rescue dogs how much they will enjoy astronomy. The dogs are named Luna and Sol — they came with the names! And the day they joined my household is the day I received the notice from AP! I think it’s a good omen.
Edited by lcaldero, 16 November 2019 - 07:13 PM.
  • Paul G, moshen, Castor and 7 others like this
#1141 gwlee
gwlee
  • Loc: 38N 120W
Posted 18 November 2019 - 11:09 PM
The three self adhesive felt strips AP supplied are about 3/4 x 2 1/2 inches. Per instructions, I snipped 4 shims measuring about 3/4”x7/16” off one of these strips and attached them to the existing felt about 90 degrees apart. The dust cap fits very securely now, and there’s a lot of felt leftover. Think three shims 120 degrees apart would have been adequate.
I am not sure whether the felt will take a set over time and loosen up, and not sure how long the adhesive will keep felt adhering to felt, but it’s working fine now. Never had a telescope with this problem before, so never paid much attention to dust caps, but now I am beginning to appreciate the screw-in dust cap that came on my TV NP101.
This is my first AP scope, and I am impressed by the professionalism of their pre-sale and post-sale customer service. Communication was excellent during the wait for the scope. It’s a sweet scope too. Had it out tonight just cruising the Milky Way with a 35 Panoptic.
Edited by gwlee, 18 November 2019 - 11:12 PM.
  • Paul G, Erik Bakker, Zoomit and 2 others like this
#1142 George9
George9
Posted 19 November 2019 - 07:39 AM
You can also do two pieces 90 degrees apart first to see if that is tight enough, or one piece for that matter.
George
#1143 t.r.
t.r.
  • Loc: 1123,6536,5321
Posted 19 November 2019 - 07:46 AM
Yes indeed! I wasn’t one to spend too much time low power cruising but Holy Cow, this thing with a 40XW, 30XW and 21Ethos has me enjoying it more and more!
Edited by t.r., 19 November 2019 - 07:46 AM.
  • Paul G, peleuba, k5apl and 3 others like this
#1144 AstroGabe
AstroGabe
  • Loc: SE Wisconsin
Posted 30 November 2019 - 12:26 AM
Here's my first light with my Stowaway on IC 1805, the Heart Nebula.  I have an RGB and Ha version for now.  The reducer is perfectly matched to it and with the adapter I ordered from preciseparts, I got perfect stars at the corners.
Description:
The Heart Nebula, IC1805, lies around 7500 ly distant in the constellation Cassiopeia. This emission nebulae is riddled with dark dust lanes within ionized hydrogen gas. In this wide-field view of the Heart nebula, the open cluster Melotte 15 contains several bright stars that are up to 50 times more massive than our sun is located near center. The intense radiation from these stars drive the output of this emission nebula. The Fish-head nebula is in the upper right. Riddled throughout the frame are filaments of dark nebulae.
Details for RGB image:
Scope: Astro-Physics Stowaway @ f/5.3
Reducer: AP 0.8x reducer/flattener
Camera: QHY16200A
Guide Camera: ASI174 Mini
Mount: Mach1 GTO
RGB: 51x5min total
Software: Voyager, PHD2, APCC, Pixinsight
5.1 hrs total exposure
Details for Ha image:
Ha: 12x15min total
3 hrs total exposure
get.jpg?insecure
get.jpg?insecure
Edited by AstroGabe, 30 November 2019 - 12:41 AM.
  • Paul G, peleuba, Rick Runcie and 4 others like this
#1145 AstroGabe
AstroGabe
  • Loc: SE Wisconsin
Posted 03 December 2019 - 05:32 PM
Looks like a recent Stowaway has popped up on AM.
#1146 gjanke
gjanke
Posted 03 December 2019 - 05:49 PM
Yep and I offered to buy it. Its an interesting ad. Doubt I will get it. But if I do Ill call it a Xmas miracle
#1147 Tyson M
Tyson M
  • Loc: Alberta, Canada
Posted 03 December 2019 - 10:55 PM
get.jpg?insecure
This is incredible!  Well caught!
  • niteskystargazer and rockstarbill like this
#1148 areyoukiddingme
areyoukiddingme
Posted 09 December 2019 - 01:53 AM
Just curious, did anyone see what the Stowaway on AM auctions went for? I was guessing close to 5k.
#1149 Kent10
Kent10
Posted 09 December 2019 - 02:00 AM
$5512.50 plus shipping.
  • areyoukiddingme likes this
#1150 Disciplus55
Disciplus55
  • Loc: East of France
Posted 09 December 2019 - 02:33 AM
Wow... it is now a bit more expensive than getting one, brand new, in Europe, at AP dealers directly... and I thought it was already super expensive :-O
