IMX178 vs. IMX183 - capturing detail on modest focal length
4 replies to this topic
#1 jtrezzo
jtrezzo
  • Loc: Tampa Bay
Posted 14 December 2018 - 04:22 PM
My goal here is capturing detail in galaxies at a modest focal length. I have an 11" RASA on the way, which has a focal length of 620mm. Looking at the 11" RASA, the specs are a Dawes limit of 0.42" and Rayleigh limit of 0.49". Supposedly, unlike Hyperstar setup, the RASA might be diffraction limited, according to Celestron catalog I had it said "43.3 mm optimized image circle (with a 52 mm useable field) maintains diffraction limited, pinpoint stars to the far corners of even the largest astroimaging sensors". Though maybe this is not the case as I see they no longer have the "diffraction limited" line on their product website now.
Both cameras would produce an image scale of 0.8"/pixel. I am hoping to do short exposures in the range of 5 second or less to overcome seeing effects which I think should work well with RASA.
I have been looking at these two sensors, trying to distinguish any difference besides the obvious one - sensor size. Both are small and should fit most galaxies fine, but to summarize, the differences are:
                                        IMX178                     IMX183
Sensor Size                7.4mm x 5mm        13.2mm x 8.8mm
QE% Peak                         81%                           84%
ADC                                 14 bit                          12 bit
Read Noise (HG-LG)     1.4e - 2.4e                 1.6e - 3e
Both are BSI, both have 2.4um pixels, and both have a maximum 15K fullwell. The 183 is approximately $250 more than the 178 for a cooled version, $300 more for uncooled (which may be an option if I just do short exposure).
Has anyone had any experience with either of these on a RASA or Hyperstar themselves? Or any comparison between the two at all on any scope. I know I've seen Mark Holbrook's incredible galaxy images with the 178 and 183 with a 14" Hyperstar setup which has a 690mm focal length which has been the inspiration here, but that is the pinnacle of greatness, so looking for more experiences. I guess my key questions are just wondering if the extra cost of the 183 is worth it over the 178 for a bit bigger FOV, or if the 14 bit ADC of the 178 puts it ahead a little bit in terms of dynamic range.
I currently have a QHY5III178M (uncooled version I use as a guide camera), which I plan to test out to begin with to see how this goes before buying anything else once I get it...but that brings up another concern, there is kind of an odd diffraction pattern on brighter stars that I do not like, though I did not see that on Mark's images with it.
#2 AdamJ
AdamJ
Posted 14 December 2018 - 05:02 PM
The 178 is the better chip for galaxies, its lower noise due to the 14bit A/D and you dont want to be taking 100's of short exposures with a 20mp chip it will be difficult to stack and store.
#3 ks__observer
ks__observer
  • Loc: Long Island, New York
Posted 14 December 2018 - 06:45 PM
Not sure you can beat seeing, which is on order of 100th second.
The noise difference seems rather small, particularly at unity gain or higher on the 183.
#4 jtrezzo
jtrezzo
  • Loc: Tampa Bay
Posted 14 December 2018 - 10:48 PM
Well, not beat it literally, but overcome a lot of the blurring. I agree the noise difference seems pretty irrelevant.
#5 ks__observer
ks__observer
Posted 15 December 2018 - 04:50 AM
If you integrate over an hour, you will get same total seeing blur no matter if you break the hour into 2 subs or 2000 subs.
The shorter sub would let you better cull out the worst pics.
Edited by ks__observer, 15 December 2018 - 04:51 AM.
