Ioptron Cube G, No Text Hand Controller
3 replies to this topic
#1 CableGuy
CableGuy
Posted 16 December 2018 - 04:09 PM
I cam across a really deal on a Ioptron Cube G that was supposedly used once, then set in a corner of a room for 4 years.
I threw batteries in it when I a got it home. The mount turns on, the hand controller backlight is on and I can slew the mount with the directional arrows on the controller. The problem is there is no menu system showing in the display of the hand controller even though it's backlit.
Ive tried several times to flash the hc with new firmware though it doesnt seem like this mounts drivers are compatible with windows 10. Im getting a error code 10 in device manager when attempting to connect the mount.
So out of ideas I figured Id run this buy you all.. Any suggestions, or known solutions?
If I don't get it fixed tonight Ill probably call Ioptron on Monday to see if they can help.
Thanks Jer
#2 biz
biz
    Vendor
  • Loc: New Zealand
Posted 16 December 2018 - 07:11 PM
Thanks Jer
Two things I can suggest you try..
Remove the back from the hand controller and reset the ribbon cable in its socket.. just slide the little levers each side of the socket and remove and refit the ribbon cable then slide back the levers. Make sure you push the ribbon cable right the way in.
While you have the back off the hand controller case replace the button cell battery as it will most likely be down on voltage.
Try that first and see what happens.
cheers
Graham
#3 CableGuy
CableGuy
Posted 17 December 2018 - 02:31 PM
i did try reseating the ribbon cable into it's socket, the ribbon itself looks damaged. It looks like a bad design. The back of the hand control has two corners  that push right down on the cable when assembled. The corners are molded plastic meant to reinforce the hanger bracket. From the looks of it there are two pin holes in the ribbon cable from that.
I dont see a button battery though, sure these little alt az hand controls have a battery?
Thanks Biz
#4 biz
biz
    Vendor
  • Loc: New Zealand
Posted 17 December 2018 - 05:09 PM
Thanks Biz
What is the number of the hand controller ?   Like, is it an 8401?
Can you put up on here a photo of the insides?
cheers
Graham
