GOT TO GO TO GOTO RESTO....
142 replies to this topic
#26 clamchip
clamchip
  • Loc: Seattle
Posted 21 December 2018 - 08:18 PM
Have you tried all the solvents on the Galactic Swirl?
I start with water and then move on to solvents.
Solvents are in 2 groups, petroleum and alcohol, if I remember correctly.
I start with the alcohol family and then the petroleums.
I have not experimented with citrus, and these can be very strong. After
hearing about lens coating damage from citrus I stopped buying any soaps or
cleaners with citrus but it may be worth a try if the lens is uncoated.
Robert
  • TOM KIEHL likes this
#27 TOM KIEHL
TOM KIEHL
Posted 22 December 2018 - 02:38 PM
New case lid is now glued and screwed to framework . Had to make a template from wax paper to match  the holes  in the frame to the holes in the case lid plywood skin . After glued and screwed , I put a pass of masking tape to protect the original finish then trimmed the  the excess from the luann with a router flush cut bit after the plywood was put in place . I have to do the bottom of the case next .
  • davidmcgo, Mr Magoo, Pete W and 11 others like this
#28 TOM KIEHL
TOM KIEHL
Posted 22 December 2018 - 03:20 PM
 I'm really liking this new brand of Luann plywood .. The grain is just about Spot On to the original . I think  it will look fine once I color match the wood stain .
  • davidmcgo, Mr Magoo, steve t and 10 others like this
#29 Compressorguy
Compressorguy
  • Loc: Clayton, NC
Posted 22 December 2018 - 03:32 PM
Well that there is just plain awesome.
  • deepwoods1, TOM KIEHL, Geo31 and 1 other like this
#30 TOM KIEHL
TOM KIEHL
Posted 23 December 2018 - 12:23 PM
BOTTOMS UP  !
  • clamchip, steve t, deepwoods1 and 5 others like this
#31 TOM KIEHL
TOM KIEHL
Posted 26 December 2018 - 07:23 PM
I lightly sanded the interior of the case today to give a brighter natural unfinished wood finish just to remove dirty stains . Also went to Benjamin Moore paint store for Old Masters Oil wood stain . I Might have to mix two colors to get the desired tone ......Cedar , and Red Mahogany . I will finish sand a test strip of the Luann plywood and preform numerous test stainings     prior to final application on the lid and bottom exteriors . I plan to glue the bottom skin on the case tomorrow . Dry overnight then router trim , sand , and replace  metal brads in bottom to match as per OEM . Then replace all WHITE felt trim in the case to match original specs.
  • steve t, deepwoods1, Bomber Bob and 2 others like this
#32 Stew44
Stew44
Posted 26 December 2018 - 08:04 PM
Tom,  I presume your stain testing will be based on percentage variations of each of the two stains.  This stain you mention has a sealer and will have a slightly glossy finish or will you add something after staining to provide the original level of sheen?
Thanks for sharing all of this!
  • steve t and shredder1656 like this
#33 clamchip
clamchip
  • Loc: Seattle
Posted 26 December 2018 - 09:44 PM
I had to rebuild one of my Goto  legs, searched and found the correct grain Philippine Mahogany and
Varathane oil base Colonial Maple was a good match.
Robert
  • Mr Magoo, Jaimo!, Compressorguy and 13 others like this
#34 TOM KIEHL
TOM KIEHL
Posted 26 December 2018 - 09:47 PM
Yes Stew ....IF.... I have to mix ..... It will be done on percentages  . The stain is solely just a oil based wood stain , unlike a Minwax finish that combines stain and sealer / finish ie. One step finish . The final semigloss satin finish will be Deft satin urethane brushed to the lid and bottom skins only after stain is thoroughly dried . Maybe 1-3 coats depending ...Then rubbed out with 0000 steel wool and Johnson's paste wax .
  • shredder1656 likes this
#35 TOM KIEHL
TOM KIEHL
Posted 26 December 2018 - 09:55 PM
Robert
Those legs look fantastic Robert ..... Yes I already have some " Colonial Maple " stain that I will be adding to the test strip . The case  lid and bottom , unlike your legs Robert , has a varnish like top finish to give a sort of sheen .
#36 Geo31
Geo31
  • Loc: Willis, TX
Posted 27 December 2018 - 08:13 AM
Do you rub it out with the wax IN the steel wool?
#37 TOM KIEHL
TOM KIEHL
Posted 27 December 2018 - 09:01 AM
  • Geo31 and shredder1656 like this
#38 Geo31
Geo31
  • Loc: Willis, TX
Posted 27 December 2018 - 10:16 AM
That makes a really nice satin finish.  I've finished a few things this way.
#39 TOM KIEHL
TOM KIEHL
Posted 27 December 2018 - 01:42 PM
As I thought this is going to be next to impossible to try to show , but here we go .
The first image is of three different stains only . All straight out of the can on sanded Luann , no top satin   top coat .
From left to right ........Old Masters - Cedar , Valspar - Pecan , Pratt and Lambert - custom mix that my Father used to stain woodwork thru-out the home .
The second image is of the test strip of Luann with all test .
#40 TOM KIEHL
TOM KIEHL
Posted 27 December 2018 - 02:15 PM
The next  images are of mixes with a flash and one without the flash .
I used the Old Master , Cedar as my base stain . FROM LEFT TO RIGHT ......1st. Old Master , Cedar and the Pratt + Lambert ,custom mixed to a 50/50 mix ........  THEN  2nd., OM ,Cedar and Valspar , Pecan @ 50/50 mix.....  THEN 3rd , equal parts of all three OM , PL , Val .......THEN 4th. , The best in my Real Time Light ( In my opinion ) Two parts OM , Cedar to one part Pratt+Lambert , Custom .
Will let the stain dry overnight then apply Deft satin clear coat to half of all the test stainings . To check for darkening after application . I also have some Varnish satin I will test too .
  • steve t, Bomber Bob, Stew44 and 1 other like this
#41 TOM KIEHL
TOM KIEHL
Posted 27 December 2018 - 07:13 PM
Don't Mind My Dust ! ..... The bottom is now affixed to the case with glue and brads .
  • Pete W, DreamWeaver, steve t and 8 others like this
#42 DreamWeaver
DreamWeaver
  • Loc: Tucson, AZ
Posted 27 December 2018 - 07:45 PM
Where's the secret source for your Luann plywood Tom?  You can tell me here.  I won't tell anyone.   whistling.gif
#43 TOM KIEHL
TOM KIEHL
Posted 27 December 2018 - 08:27 PM
But their stock continually changes .... Just so happened this was a good batch .
  • DreamWeaver, Bomber Bob, TSSClay and 1 other like this
#44 shredder1656
shredder1656
  • Loc: Indiana
Posted 27 December 2018 - 09:25 PM
Looking great.  Impressive!
#45 deepwoods1
deepwoods1
  • Loc: Connecticut
Posted 27 December 2018 - 10:33 PM
I am not worthy to even follow this thread. I have no skills, nor the tools. Impressive work!
#46 TOM KIEHL
TOM KIEHL
Posted 28 December 2018 - 07:28 AM
" Can't never did anything "    Your Quote reminded me of this clip ......
https://www.youtube....v=jjaqrPpdQYc
No but seriously , It's threads like this and many others like it that will hopefully inspire folks like yourself and others to take on these tasks and others related to our hobby .
" With a little help from my friends " .....( The Beatles  ) .... https://www.youtube....h?v=0C58ttB2-Qg
Edited by TOM KIEHL, 28 December 2018 - 07:41 AM.
  • DreamWeaver, Bill Griffith and Geo31 like this
#47 TOM KIEHL
TOM KIEHL
Posted 28 December 2018 - 01:56 PM
Both top and bottom are now in stain . They must dry / cure overnight . Tomorrow I will apply 2-3 coats of amber shellac thinned to a 50/50 mix of shellac and denatured alcohol with 30min . between coats . This will seal the wood and stain so the final top coat of Deft satin clear will not be sucked up by the open wood pores . After the shellac sealer is dry overnight it will be hand rubbed with 0000 steel wool , Tacked with a tack rag , then the Deft will be applied . Maybe 2-3 coats of Deft or till a match is achieved . IN THE MEANTIME , while I watch paint dry lol.gif  . I will read and  recommend this book ,  Lots O Good tips and techniques . Still available on the Zon .waytogo.gif
  • steve t likes this
#48 shredder1656
shredder1656
  • Loc: Indiana
Posted 28 December 2018 - 06:42 PM
  • Bill Griffith, rcwolpert and TOM KIEHL like this
#49 TOM KIEHL
TOM KIEHL
Posted 28 December 2018 - 07:12 PM
#50 TOM KIEHL
TOM KIEHL
Posted 31 December 2018 - 12:28 PM
The case repairs are now finished ..... Now I have to fill it with the , to be restored , telescope and accessories .
  • ArizonaScott, astro140, Pete W and 13 others like this
