Spectrograms of UV Cut Filters Suitable for Astrophotography
astrophotography beginner ccd CMOS dslr dso imaging optics refractor
8 replies to this topic
#1 rekokich
rekokich
  • Loc: Virginia
Posted 20 December 2018 - 02:35 AM
Unmodified Canon cameras have spectral sensitivity roughly between 400 and 665nm. Whereas true APOs and highest quality telephoto lenses will produce images free of chromatic aberration (CA), most conventional achromats, semi-APOs, and standard (affordable) telephoto lenses will exhibit CA in the shape of blue or red halos around brighter stars. One way to improve CA is to reduce aperture by 1-2 stops. Another one is through the use of appropriate UV filters to reduce the spectral range of the light reaching the sensor.
Full-spectrum modified Canon cameras manifest a much wider range, between 370 and >750nm. No refracting system, including the best APOs, is designed to correct such a wide range without prominent red chromatic aberration. Use of UV/IR CUT filters which block light in the violet and in the far-red region is mandatory.
With unmodified cameras, conventional, "photographic" UV filters generally improve star images to a degree by reducing atmospheric light scatter (Rayleigh scatter) which is most prominent in the violet region. They also reduce CA by blocking some unfocused violet light, however the effect is relatively small since most UV filters block below 400nm where unmodified camera sensitivity is very low anyway. As a typical example, look at the spectrogram of the Hoya Pro 1 Digital UV(0) filter which seems to have only minimal effect on the violet end. The most effective "photographic" UV filter is Tiffen Haze 2A. It begins to cut violet light below 415nm, and actually produces very good results in reducing CA and haze. Formatt Haze 2A has an identical bandpass at a substantially higher price. Unfortunately, neither one of these filters is coated, and will generate internal reflection artifacts on very bright stars. In spite of this, Tiffen Haze 2A is so affordable, it should be the first choice for a beginning telephoto lens astrophotographer.
Specialized astrophotography filters are much more expensive, but they are anti-reflection coated, more restrictive in bandpass, and more effective in reducing haze and chromatic aberration. Also, they can all be used with unmodified and full spectrum modified cameras because they block light in the violet and in the far-red region. All of them are available in the 2 inch threaded version which can be screwed into 2 inch telescope focusing tubes, or easily attached to telephoto lenses with step-down filter thread adapter rings.
My personal favorite is the Astronomik UV/IR Cut L3 filter because it is also manufactured in the Canon EOS clip-in version. Clip-in filters are close to the camera sensor, and tend to produce less aberrations than more distant 2 inch filters in telescope focusing tubes or in front of telephoto lenses. Its bandpass is between 421 and 687nm, which yields excellent images with reasonably good optics.
The most restrictive UV/IR cut filter is the Baader Fringe Killer. With bandpass between 420 and 675nm on modified cameras, and 420 - 665nm on unmodified cameras, it is probably the best choice for marginal optics.
Another filter I have found very useful with full spectrum modified cameras is the Astronomik CLS-CCD light pollution filter. Its overall range between 450 and 690nm is even narrower than the Baader's, but it excludes light between 530 and 640nm, which requires doubling the exposure time. The rewards are very high contrast, marked reduction in atmospheric scatter, no chromatic aberration with decent optics, and exclusion of sodium and mercury light pollution.
Edited by rekokich, 20 December 2018 - 11:56 AM.
  • Starman27, happylimpet, xiando and 1 other like this
#2 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 20 December 2018 - 05:38 AM
I would title this 'UV cut' filters, as I understand a UV filter to be one which transmits UV.
  • John Boudreau, RedLionNJ and rekokich like this
#3 SteveInNZ
SteveInNZ
  • Loc: Auckland, New Zealand
Posted 20 December 2018 - 02:17 PM
Interesting study. IMHO, it would be useful (complete) if you also had the spectrogram of an unmodified camera for comparison.
Steve.
#4 rekokich
rekokich
  • Loc: Virginia
Posted 21 December 2018 - 08:20 AM
Steve,
These spectrograms of sunlight compare a full-spectrum modified Canon T3i camera with the transmission range of its internal filters 1 and 2. Notice that it is the anti-aliasing filter 1 which actually cuts UV and IR light, while the "IR cut filter 2" gradually cuts deep red, barely including the Ha line, but without affecting the UV.
If I were doing camera modification again, I would probably remove only filter 2, and leave the anti-aliasing filter in place. That would eliminate the need for any additional UV/IR cut filters.
  • SteveInNZ, sharkmelley and happylimpet like this
#5 rekokich
rekokich
  • Loc: Virginia
Posted 21 December 2018 - 08:34 AM
When the above spectrograms are scanned with RSpec software it becomes evident from the graph that low grade sensitivity range extends beyond the upper and lower bounds visible on correctly exposed photographs. Vertical yellow lines mark what I would consider to be the extremes of the range which might show only on overexposed images.
  • SteveInNZ likes this
#6 rekokich
rekokich
  • Loc: Virginia
Posted 24 December 2018 - 12:55 PM
Here are spectrograms of sunlight taken with an original and a full-spectrum modified Canon T3i camera. Notice that, in addition to a restricted wavelength range, the modified camera also shows less very fine detail due to the slight blurring effect of the anti-aliasing filter. In actual astrophotographs, this loss of fine detail is to me barely noticeable only on short exposures of globular cluster cores.
  • sharkmelley and Nicole Sharp like this
#7 rekokich
rekokich
  • Loc: Virginia
Posted 24 February 2019 - 02:33 AM
CORRECTION: The modified camera shows MORE very fine detail...
  • happylimpet likes this
#8 sharkmelley
sharkmelley
  • Loc: UK
Posted 24 February 2019 - 05:59 AM
That's a very interesting study!
Those spectrograms are beautifully prepared and I love the useful annotated scale at the bottom.
Mark
#9 rekokich
rekokich
  • Loc: Virginia
Posted 10 March 2019 - 04:46 AM
Please see the following link for minimizing purple-red halos around bright stars using UV cut filters:
https://www.cloudyni...d-bright-stars/
Also tagged with one or more of these keywords: astrophotography, beginner, ccd, CMOS, dslr, dso, imaging, optics, refractor
