2019 NE Ohio Amateur’s 22” F/4.16 / 8” F/4 Observing Log
16 replies to this topic
#1 andreww71
andreww71
  • Loc: NE Ohio
Posted 05 January 2019 - 11:03 AM
I’m following some other forum member’s posting style and consolidating my observing notes for 2019 under one thread. Most of my observations will be using the 22” since the number of nights I observe are so few I try to get the most out of my time observing.
01/03/19 – I took the scope out in the front yard for my first observing session of the year. I stuck to the classic late fall / early winter favorites. From my location NE of Cleveland, a half mile from the south shore of Lake Erie I can, on clear nights this time of year see the Milky Way very faintly overhead in Cassiopeia stretching down to the northwest in Cygnus. This was a short 1 hour session though as the amount of traffic on the street and neighbor’s porch lights were really annoying me.
01/04/19 – The NWS was forecasting clouds for NE Ohio but the visible satellite showed me that I might get a few hour observing session in so I headed out to my local dark sky site. I ended up getting about three hours in before a broken band of clouds overtook my location from the south.
I took this night to do a casual tour of winter time favorites interspersed with a few not so well know objects as well. The transparency was a very good but the seeing early on was horrible though it got better about an hour into the session.
Nebula: NGC 2175 – I used the OIII filter and 86x, M42 and surrounding area, IC 434/B33 – Horsehead Nebula – I used the H-Beta filter and 86X
Open Clusters: M35, M36, M37, M38, NGC 1907, NGC 1807, NGC 1817, NGC 2141 (need to check this one out under darker skies), NGC 2158, NGC 2194
Planetary Nebula: IC 2003, IC 351, NGC 1514 (astonishing what the OIII does for this object!), NGC 2392 – I used 334X for a great view
Although I didn't log any new objects this was a very satisfying night under the stars none-the-less.
  • Ptarmigan, JohnnyMac, Phillip Creed and 7 others like this
#2 Pete W
Pete W
  • Loc: Hutto, TX
Posted 06 January 2019 - 09:13 AM
Sounds like a great evening of observing.  Thanks for sharing.  Planetaries, large apertures, and high mag go together well!
  • andreww71 likes this
#3 andreww71
andreww71
  • Loc: NE Ohio
Posted 06 January 2019 - 10:24 AM
01/05/19 – Second night in a row the NWS forecast was for mostly cloudy and the visible satellite showed clear for at least a couple hours before clouding over. I headed out to my local dark sky site again. Unlike the previous night both the seeing and transparency was sub-par. I decided to focus on the area of the sky near zenith using Uranometria charts 36 & 37.
Nebula: NGC 2261 (Hubble's Variable Nebula) – This was the last object I looked at before packing up. This is a pretty neat object. R Monoceros shines like a beacon at the tip and the nebulosity fans out behind it though it is pretty uneven in brightness.
Open Clusters: M103, TR1, NGC 654, NGC 663, NGC 659, NGC 743, NGC 225, NGC 189, NGC 136, NGC 381, NGC 433, NGC 436, NGC 457.
In regards to open clusters it’s incredibly valuable to have access to published observations of these objects as opposed to just using cataloged information. For example, one book that I have lists the total number of stars in NGC 189 as 90 but a published observation revealed about half of that number using a 24” telescope. Obviously an image will reveal a larger number so the catalog value is most likely correct. From my local site I counted about a half dozen stars over an extremely faint haze. I’ve also found that I am not always able to see the “un-resolved” background haze reported by others because my skies are so bright which leads to confusion as to whether or not I’m actually observing the object. In this case I note that I need to observe the object when I’m at one of the two darker sites that I observe from. Challenging these open clusters are!
Planetary Nebula:
NGC 246 – located on the meridian at the end of evening twilight I used 86X and the OIII to get a pretty nice view. It was extremely difficult to view this without the OIII. From CCP, WV this object is visible in my 9 X 60 finderscope!
I then moved on to M76 which was almost directly overhead. Using 127X and OIII I was impressed with the brightness of the core and wispy extensions on either side. My 2” OIII filter no longer threads into many of my eyepieces so I had to stick with this low power view.
After two hours a band of clouds moved in from the north. I decided to pack it up and head home thinking the NWS was right. Once I got home the sky was dead clear and it stayed clear to about midnight.
  • KidOrion and Cron like this
#4 andreww71
andreww71
  • Loc: NE Ohio
Posted 06 January 2019 - 10:28 AM
Planetaries are an interesting group of objects. Many require really large aperture to reveal their subtle details but others look great in much smaller scopes. I remember the first time I saw the internal structure in the Eskimo Nebula. I was using an 18" scope but then was able to repeat the observation with a 12-1/2" no problem.
Andrew
  • Cron likes this
#5 andreww71
andreww71
  • Loc: NE Ohio
Posted 11 March 2019 - 06:15 PM
So, after January 5th I have been shut-out of observing until Friday night, March 8th - the last night of EST. There have been very few clear evenings this winter but about a half dozen clear mornings. I have a hard time getting up to observe objects that are well placed for viewing in May or June in February. I may change my habits some day but until then...
I started out very low in Canis Major and looked at a few open clusters but it was not happening. Everything seemed washed out. I then moved up into Monoceros to observe a couple of standout clusters but only M50 caught my attention. Only NGC 2360 in Puppis stood out and looked impressive.
Changing gears I moved the scope over to NGC 2903 in Leo and it looked surprisingly good! I've concluded that from my skies I'm really only going to get excited about the brightest of galaxies.
I finished up the night with a peek at some of winter's best before packing it in. It was clear the whole night but at the end of a long work day an all-nighter was not in the cards.
#6 andreww71
andreww71
  • Loc: NE Ohio
Posted 30 March 2019 - 12:27 PM
March 2019 rolled on and has offered many nights of observing.
03/11/19
03/12/19
Looking at my observing log shows that March is tied with November(!) with the most nights with recorded observations - only September has more, for the past four year period of 2015 - 2018. After my ho-hum session on 03/08 where I was left unsatisfied with my observations I found some enthusiasm by heading out to the driveway for some work night astronomy a few days later.
The late winter sky makes driveway astronomy enjoyable with its myriad of open clusters and planetary nebula that hold up well under my sub-urban skies. I spent both Monday and Tuesday nights looking at many of the bright winter favorites: M46, M47, M42, M42, M35, NGC 2392, M36, M37, M38, Double Cluster, NGC 1817, M78, M76, NGC 1245. Unlike the night of the 8th these were pretty leisurely sessions but I found them extremely enjoyable and very relaxing.
I finished the session on the night of the 12th with a view of the Pup. My wife was just finishing walking our own Pup so stopped by for a view. I first jumped over to Rigel to show her how close the companion is to the main star and then moved back to Sirius. It took a minute or two but she saw it. I thought I thoroughly explained to her that she was looking two stars but when I got back into the house after putting the scope away I found her googling for images of the “Pup Nebula!”
03/23/19
I took advantage of this clear Saturday night with about 2 hours of darkness before moonrise and headed out to the local dark sky site.
Highlights include going far south for open clusters M93 and NGC 2421. Looking at my notes shows no observation logged for M93 so this was a first. The stars were a bit bloated at this low elevation but the view was excellent.
On a whim I pointed the scope at Regulus hoping to catch a glimpse of Leo I. With no finder chart and my less than dark enough skies I really had no chance. I did see the nearby galaxy IC 591 without difficulty.
The highlight of this session though was when I put in the 4.7 Ethos (569X) and turned the scope first to NGC 3242 and then to NGC 2393. I don’t often get very steady seeing in the late winter / early spring but both of these planetaries looked fantastic!
I packed up at moonrise and was home in bed by midnight.
03/25/19
The skies were a deep blue the entire day and by the time I got home from work I decided to pack the scope up and head to the local dark sky site to take advantage of a work night observing session. These work night sessions will come to end about the beginning of April as the end of AT will extend too late into the evening to make these observing sessions practical. Make hay while the sun shines…
I decided to take advantage of the darker skies and focus on nebula this night.
I started out about 20 minutes before the end of AT with M42. I used a number of eyepieces and just took in the view. I saw the standard A, B, C, D, E, F stars as well as number of others outside of the trapezium. I need to spend some time to see if I can spot those inside of the trapezium.
Next was the planetary NGC 1514 in Taurus. An excellent example of what an OIII filter does for an object. Without the filter the CS is blinding but the surrounding nebula is almost imperceptible. Put the filter in and the nebula fills in nicely.
I dropped the scope down to the southern horizon, still chasing the winter milky into Puppis. Using the 31N2 I brought the open cluster NGC 2467 into the field. There is a hint of nebulosity without a filter. I put the OIII in and nebulosity becomes much more obvious. This is an outstanding object that surely would be a showpiece if it wasn’t so far south from my latitude. None the less I was rewarded with an excellent view.
I moved the scope north into Canis Major to view Thor’s Helmet and though the skies were pretty good for my local site I’ve seen this object much better in WV.
I dipped back south into Puppis again to catch the bright planetary NGC 2440. I found the southern declination didn’t hurt the image at all and so I ended up with the 4.7 Ethos observing this object at 569X. The oblong shape is pretty obvious even at lower power but the mottling across the surface reminded me of M82.
I finished my session in Orion with a view of Abell 12. The planetary is difficult to view given that it is right next to Mu Orionis so you can’t even put the 4th magnitude out of the field to reduce the glare. I put the OIII in and at 172x the round glow of the planetary comes into view.
03/26/19
High clouds were on their way in but it looked like the skies would stay clear for few hours after sunset this night so I settled for a driveway session.
Along with the usual suspects I added the bight planetary NGC 2371-72 and two rich open clusters in Gemini, NGC 2304 and NGC 2266 to my list.
There’s a slim chance it’ll be clear the night of March 31st here so I may add one more night to an already productive month!
Edited by andreww71, 30 March 2019 - 07:21 PM.
  • Phillip Creed and KidOrion like this
#7 andreww71
andreww71
  • Loc: NE Ohio
Posted 01 September 2019 - 07:43 PM
My last post in this thread was March 30th! I made a concerted effort to get more observing in this spring though none of it was under really dark skies. June, July and most of August brought lots of smoke to northeast Ohio as a result of various fires in Alaska, Canada and even Russia!  I did get lucky the last week of August with a two night trip to Calhoun County Park in WV to observe under truly dark skies.
Observing highlights are listed below. All observations are using a 22” F/4.16.
April
I had one driveway session in April and missed out on two nights late in the month where skies cleared just before midnight but I had already turned in for the night. “Waiting for the clearing” is one of the most difficult aspects of weather to predict here.
May
I logged three nights in May but the first two were somewhat short due to equipment problems.
05/23/19
The last night I logged in the month was the charm.
I spent the night viewing bright Messier and NGC galaxies and came away with some fantastic views.
NGC 4725: I couldn’t detect the pronounced delineation between the core and the spiral arms that appears in photos but I could clearly see a difference between the core and outer arms. The core was smooth while the arms were clearly “rough” in appearance. I feel under darker skies these features will be much more clearly visible.
M81: I could detect the division between the bright core and the outer spiral arms. I was impressed. Seeing anything other than the core from my site is remarkable.
M51 / NGC 5195: WOW! At 334X the galaxy filled the field of view and looked like a photo!  The extensive halo surrounding NGC 5195 was clearly visible. This is the best view of this galaxy I have ever had.
June
06/29/19
I headed out to my local dark sky site for a short session. The night was very warm and humid and the seeing was (surprisingly) horrible.
NGC 6369: The little ghost. I used 127X but didn’t note anything other than its shape. I expect this will look much better, and reveal more detail with better seeing and more magnification.
NGC 6445: The Box nebula looked, well, boxy. I think darker skies as well as better seeing might reveal more detail including a bit of the broke outer halo of nebulosity seen in images.
August
August is typically one of my least active months. This year I logged three nights, all with excellent transparency.
08/24/19
IC 1311: Located in Cygnus this cluster looked impressive at 206X. It wasn’t fully resolved in the 22” but instead showed a number of stars superimposed over a faint background haze. Regardless of the level of resolution, this cluster just looks really good!
08/28/19
The two factors that never seem to align: clear skies and no commitments, came together this past week to allow me to take a trip to Calhoun County Park, WV. The weather looked very promising with a strong cold front coming through providing at least two mostly clear nights, daytime temps in the 70’s and low (for the east coast) dew points in the upper 50’s.
Unlike my site close to home, Calhoun offers much darker skies that are only a 3-1/2 hour drive away. By 9:25 (20 minutes before the end of AT) I could clearly make out the pipe nebula naked eye!
I spent the early part of this night very low on the southern horizon checking off open clusters in Scorpius. Sadly, given the crappy seeing this low on the horizon, none of the objects looked very good. Targets included NGC 6400, NGC 6404, NGC 6451, TR31, M6 and M7. Even the big Messiers were somewhat lacking though a smaller scope with a wider field would have given a better view.
NGC 6520 / B86: The cluster looked okay but the real show stopper was its pairing with the prominent dark nebula B86. This is a really interesting pair of objects that looks fantastic. After the less impressive views of the objects in southern Scorpius above, coming across this pair perked me up a bit!
Czernik 38: This open cluster in Serpens boasts an impressive number of members (80) in various publications, but its catalog number of CZ38 implies it is not an eye popper in anything other than a really big scope. Using 206X with the 22” revealed a number of stars in the field with a hint of haze in the background. I need to study an image of the cluster and then make another observation to try and determine just how many stars are visible.
IC 4954 / 55: These are two reflection nebula located in Vulpecula. My deep sky field guide to Uranometria doesn’t clarify the location of each catalog number – it only states it is a pair of detached nebulosities aligned NW – SE.  I first observed these the night of 08/24 at my local dark sky site but wanted to check them out under darker skies.  The northwest component is the fainter of the two but it extends due south around a parallelogram of stars. I did confirm that I saw the brightest portion of each section at my local site but in general more nebulosity was visible under darker skies.
During the course of the night I stopped by and looked at many favorites in between objects on my list.
08/29/19
I started out the night concentrating on object on Uranometria chart 339. At the end of twilight, objects on this chart would be passing through the meridian. There are a number of show piece objects on this chart including M17, M24, M20 and M8 to name just a few.
M8: I placed the Lagoon Nebula in the center of a 31mm eyepiece (86X), which gives a FOV of just under a degree and was amazed to see the faint extremities extend outside of the FOV. The level of detail was amazing! The large dark rift that runs through the center, effectively splitting the object in half was very pronounced. There is a very bright knot of nebulosity on the west side that also stood out. Panning around revealed the extensiveness of the nebulosity.
M20: I moved up to the Trifid nebula for an equally impressive view. Without a filter, both “halves” of the object appeared equal in brightness. I found with the 13mm eyepiece (206X), the entire object fit neatly in the FOV. I spent some time just soaking in the view.
NGC 6546: In spite of this open cluster’s II1r classification, I found it challenging trying to define its extents in a very rich star field. My best view was using 206X.
NGC 6603: I’ve seen this cluster before but the view is always incredible with this object being situated within the boundaries of M24. Talk about stars and more stars!
NGC 6589/90: These two reflection nebula lie due south of NGC 6603. I kept to low power (86X) and found these two nebula to be pretty easy.
IC 1283/84: Using low power and the OIII I was not able to identify this object from the background.
NGC 6559: There are a number of other nebula in this area as well but trying to identify them using the “outline” shown on the uranometria chart is a daunting task. It’s difficult trying to see where one object ends and another begins. I could clearly make out 6559 and some of the “other” objects in the vicinity. Like hunting down faint planetary nebula, an image of the region will help tremendously in identification. None the less, I was pretty satisfied with view I had of the region as a whole and the amount of detail visible.
IC 4684: Lying north of NGC 6559 and separated from the nebulosity of the whole area, I found this reflection nebula easy to identify.
Working my way north along the Milky Way I stopped to view planetary PK24+5.1 (M4-9). Using 206X the planetary looked evenly illuminated to me though the Deep Sky Field Guide lists it as ring structure.
The rest of the night I continued along the Milky Way up into Cygnus viewing a mix of open clusters and planetary nebula.  Dew on the eyepieces became a problem after 2 and I packed it in at 2:30. The glorious fall Milky Way stretching through Cassiopeia and Perseus was in full display to the north and gave a preview of what will be better placed for evening viewing later in the season.
  • Ptarmigan and KidOrion like this
#8 andreww71
andreww71
  • Loc: NE Ohio
Posted 16 November 2019 - 08:36 AM
We’ve had very good weather from late summer up to the very beginning of November which is somewhat typical for NE Ohio. While I have focused heavily on NGC open clusters the past few years, this fall I expanded my observing to a number of other types of objects including a few that have been discussed here in the Deep Sky Observing forum.
All observations are using my 22" F/4.16 Dobsonian.
M1-92 [IRAS 19343+2926] – Proto-Planetary in Cygnus also known as the Footprint Nebula. I observed this proto-planetary on a couple of occasions under varied seeing conditions. My best view was with 334x where I could clearly see both “sides” of the nebula, one side being slightly brighter than the other. This is a tiny object that really requires more than the 334x I used but conditions did not allow. I’ll try again next summer when Cygnus is overhead and the chances for better seeing will be much better than this time of the year.
NGC 7423 – Open Cluster in Cepheus. This is another object that I’ve observed on multiple occasions this year to try and get the best view that I can. It took a trip to Calhoun County Park to really bring out the best this small cluster offers. It’s only 5’ in size and unless you know exactly where to look it’s easy to sweep over it. Again, seeing is key with something this small and my best view was using 206x. If the conditions allow I can easily up this to 334x.
Images of this cluster show an interesting object close by designated IRAS 22534 5653 – has anyone observed this? I noted that I thought I saw a very faint glow using averted vision but came away questioning whether I saw the object or not.
NGC 7814 – Galaxy in Pegasus. I did not look at an image prior to my observation and using 334x under dark skies I noted a central bulge with what looked to be a dark lane running across the disc during moments of good seeing. The next day I looked at an image and was pleasantly surprised to see that I did indeed see a thin dark lane bisecting the disc. I’m always looking for galaxies that are something other than a faint smudge in the eyepiece and this one is definitely a winner.
M33 – Galaxy in Triangulum. While observing at Calhoun one night I moved the scope up to M33 as it was crossing the meridian. I’ve viewed this galaxy many times from my dark site close to home and it’s a nice object but this night it really knocked my socks off! Along with the familiar, central “S” shape was an extensive outer envelope of nebulosity that extended to the edge of the field of view (54 arcminutes with the 31NT5). Numerous HII regions and bright knots were seen. I’ve since looked at images more closely now to examine the fine details and will make a close up chart of the galaxy to use at the eyepiece. There was far more detail visible through the 22” that I knew about at the time of the observation and will come back to this object again.
PK80-6.1 – Planetary Nebula in Cygnus also known as the Egg Nebula. This object is not plotted on my first edition Uranometria – the chart that I use when I’m at the scope. I made a finder chart showing the object from a DSS image that included a few stars shown on the Uranometria chart so that I could quickly identify the field where the object is located. From my local dark sky site using 334x I could clearly see two elongated lobes separated by a distinct dark lane. It could take more magnification if the seeing allows. This is a pretty neat object that I’ll be sure to come back to again on a night with excellent seeing.
IC 361 – Open Cluster in Camelopardalis. I’ve only observed this cluster from my local dark sky site so on a recent trip to Calhoun I added this to my observing list. This cluster is listed as a type II1r with 60 members packed into 6’ area. Through the 22” it appeared mostly resolved and is a really aesthetically pleasing looking cluster when viewed with a large scope.
B33 / IC 434 – Horsehead Nebula in Orion.  I’ve ended most of my late night / early morning sessions with some casual viewing in Orion. At Calhoun, both the reflection and dark nebula are fairly easy to see without the H-Beta filter. I’ve seen this object many times so identifying the dark nebula is pretty easy once I orientate the field.
Andrew
  • KidOrion and GUS.K like this
#9 andreww71
andreww71
  • Loc: NE Ohio
Posted 26 September 2020 - 01:17 PM
This year has been a pretty quiet year for me in the hobby. There were a number of nights in February and March where the moon was out of the way but I just couldn’t get out. Spring and summer are typically hit or miss here in the Midwest and this year it’s been mostly miss. Late summer and early fall skies have been mostly a no-go for DSO because of smoke. I finally got a little reprieve last weekend after a strong cold front dropped down from Canada, lowering the humidity and clearing out both clouds and the smoke. I took advantage of this and made a three-day weekend out of a trip to Calhoun County Park (CCP) in WV.
I arrived at CCP late Saturday afternoon. I wasn’t sure if I would stay two nights or have to return home Sunday to observe somewhere close by home or drive east to Cherry Springs to outrun the smoke. As it turned out, the smoke stayed well off to the west on Sunday so I didn’t have to leave. There were a few others in the park getting ready for observing and imaging as well. Two older gentlemen from the Pittsburgh area were located on the ridge near the front entrance while another person, Ed, (also from the Pittsburgh area) was in the campground with his travel trailer / imaging dome set up. I proceeded up to my normal observing area in the southeast end of the park.
I put a quick list together of obscure open clusters in the Summer Milky Way to observe on Saturday morning so my session on Saturday night consisted of many of these faint clusters with a mix of summertime favorites thrown in.
All observations are with a 22” F4.16. Some of these clusters have been “penciled” onto charts of my first generation Uranometria 2000 because most are not plotted. I use my “office only” All Sky edition to use as a guide to locate the cluster in my first generation charts I use at the eyepiece. I find observing open clusters can be quite challenging if they are located in the milky way due to the number of stars visible in the field.
Trumpler 32 | Ser | I2m - This cluster contains 50 stars in a diameter of 12’. Using 127x with FOV of 47’ I counted about 20 stars that appeared to be in the cluster.
Berkeley 79 | Aql | II1r – This cluster packs 60 stars into a diameter of 7’. I noted the cluster appeared to be centered at the end of a small arc of stars with a triangle of stars at the end. Only some stars were visible super-imposed over a soft haze.
Trumpler 35 | Sct | I2m – This cluster has about the same number of stars at Trumpler 32 but is half the size. I observed the overall brightness of the members to quite bright. The entire cluster appeared fully resolved and I gave it an “ok” in my notes.
Czernik 38 | Ser | I2r – Using 127x I found averted vision really brought out the stars in this cluster. I viewed it early in the evening while the scope was still cooling down and noted that I need to come back to it later in the night after the scope cooled down (I didn’t). I noted that this is one to come back to as I really liked it a lot.
Berkeley 81 | Aql | II2r – This cluster has a cataloged size of 5’. I used 127x and 206x but did not positively confirm its position. I noted I thought the cluster appeared adjacent to bright star but the DSS image shows nothing bright “adjacent to” the cluster. The DSS image also leads me to believe it’s a pretty faint cluster and it’s possible I had it in the field but did not identify it.
King 25 | Aql | III2m – Using the 13E (206x / 23’ FOV) I noted this cluster appeared pretty faint though surprisingly rich in stars. Granted, it’s difficult for me to sometimes identify the end of the cluster and the beginning of the adjacent star field, especially for clusters in the Milky Way. None the less I noted this is another cluster to come back to.
Berkeley 43 | Aql | II1m – This is another small cluster (5’) that I viewed using the 13E. I noted this as being very faint but averted vision really helped bring out the stars. This is another cluster that I’ll come back to.
I took a nap at about midnight and set the alarm for 1:30. I woke up at 1:15 and resumed observing.
NGC 891 – always a favorite when it’s high in the sky, I used the 13E and the galaxy fits neatly in the FOV with a little room on either end.  It looks just like the pictures!
Mars – with the heavy dew having set in and eyepieces constantly fogging up I decided to end the night with a look at Mars, high up in the southeast sky. I started low (127x) and kept going up, first stopping with the 8E (334x) and ending with the 4.7E (569x). I was impressed! Admittedly, I don’t know my Martian geography that well but the polar cap and a number of dark striations on the globe were easily visible and really pretty sharp. There was probably a lot more to see on the disk but I was pooped and so headed off to my warm sleeping bag!
The weather on Sunday was phenomenal and I walked the hiking trail that winds all the way around the park (~3 miles) with Ed during the day and then prepared a list of objects to observe late in the afternoon. Since I had done all of the “heavy lifting” the previous night I decided to make an observing list of favorites, starting in the southwest after twilight and extending along the milky way up to the northeast. My list contained a mix of M’s, NGC’s and a few Abell planetaries.
Once twilight faded I started in Sagittarius with M8 / M21 and M22. These are showpiece objects that I’ve observed many times but I never grow tired of looking at. The dark lanes in the Triffid were stunning!
Heading northeast I swept through M24 and stopped at the small open cluster NGC 6603. Nothing like stars inside of more stars!
M17 and M16 were next.  I used the OIII on M16 to really bring out the nebulosity.
Continuing northeast I came to the planetary nebula IC 1295 and the nearby globular cluster NGC 6712. I’m always impressed with how faint IC 1295 is without the OIII, but once I put the filter in this object is fantastic. I used 206x on both objects. The globular presented many stars across the face with an unresolved core. The seeing was only okay and I noted the object would look better under better conditions (duh!)
After a few more NGC clusters in Aquila I stopped by Abell 55 (PK33-5.1). Using 127x I had no problem seeing this object without the OIII. Putting the OIII in really enhances the view. On the same uranometria chart is Abell 56 (PK37-3.2). I did a quick search of the area but found nothing. I typically use a finder chart printed from a POSS image to hunt down these faint objects so did not spend a lot of time when nothing really presented itself in the field.
I moved into Vulpecula to observe Abell 57 (PK58+6.1).  I observed this object previously with an 18” scope and had no problem with the 22” and the OIII filter.
Next up was the OC / GX pair at the Cepheus – Cygnus border, NGC 6939 and NGC 6946. Both of these objects are outstanding members of their type in the NGC catalog. At 206x the spiral arms in NGC 6946 are faint but clear.
I swung over to the northwest into Lyra to look at NGC 6791. This cluster really presents itself in the 22”.
I finished up with two more outstanding open clusters in Cygnus: NGC 6819 and NGC 7044.
In a four hour period of time I looked at about half of the objects on my list. Cassiopeia was now high in the northeast and though I was contemplating continuing I decided to pack it in. There will be other nights this fall and early winter for me to catch objects in this part of the sky, earlier in the evening.
  • KidOrion, Matt Lindsey, Sheol and 1 other like this
#10 Organic Astrochemist
Posted 26 September 2020 - 09:39 PM
Great report.
I observed over a hundred fairly bright, rich OC from Scorpius to Perseus this summer and I missed NGC 6819. I’ll add it to my list. Thanks.
NGC 6791 is apparently one of the oldest OC. Maybe you can try for old Berkeley 17 later this year.
#11 andreww71
andreww71
  • Loc: NE Ohio
Posted 27 September 2020 - 07:50 AM
Great report.
I actually started the obscure open cluster observing project last fall. In December, 2019 while observing at CCP I noted that I attempted to observe Berkeley 17 but could not identify it. Looking at the POSS images shows a fairly rich cluster of uniform brightness stars (its a class III1r) but they appear faint. With no discernible central concentration it blends in well with the background stars. I'll have to take a field finder chart with me for this one.
I need to post my notes of observations of the winter clusters and will do this next as they are all coming into view now.
#12 KidOrion
KidOrion
  • Loc: Eugene, OR
Posted 27 September 2020 - 06:00 PM
Great report!
Lots of good info for when I go chasing some of these with the 12.5" and 20" scopes. (Especially the Abell planetary info!).
Interesting cluster to go after in Cygnus: IC 1311.  Apparently one of the oldest Milky Way open clusters. http://www.deepskyfo...&highlight=1311
NGC 7044 and 6819 are really under appreciated objects, especially the latter. interstellarum calls it the "Fox-Head Cluster," and it's easy to see why in the eyepiece.
#13 andreww71
andreww71
  • Loc: NE Ohio
Posted 27 September 2020 - 07:44 PM
Great report!
There's a number of Abell's visible in a 12-1/2" in the fall sky including: Abell 72, Abell 79, Abell 82 and Abell 84. Most required an OIII to identify. I think your skies are darker than what I observed these under so you shouldn't have a problem. There are two other Abell's that were in fact already cataloged: Abell 75 / NGC 7076 and Abell 81 / IC 1454. These are faint but visible in the 12-1/2" as well.
I observed IC 1311 August, 2019 from my local site and noted that it was very faint, but completely resolved. I need to hit this one up again the next time I'm at CCP. Thanks for bringing it up!
I like small rich clusters and NGC 7044 fits into this category nicely.
Edited by andreww71, 28 September 2020 - 04:19 AM.
  • KidOrion likes this
#14 andreww71
andreww71
  • Loc: NE Ohio
Posted 24 October 2020 - 11:10 AM
October has been a pretty good month and I've been out 5 nights this month, including 2 at my dark sky site at CCP, WV. From my local site I revisited IC 1311 in Cygnus, at 127x, even in poor seeing this cluster is still awesome!
I spent two other observing sessions at my local site mostly hitting some of my favorite open clusters and comparing observations from ones done previously.
My last two sessions observing DSO's were done at CCP. There was an informal start party held starting 10/12 and continuing into the following weekend. I attended with my wife and this was her first time being at the park. We were there 10/16 - 10/18. Both Friday and Saturday nights started out cloudy but cleared out after 10PM and stayed clear the rest of night. I stuck to mostly bright objects while my wife was up but after she went into the camper I sought a few fainter objects that I noted that I wanted to re observe when I was under dark skies.
IC 166 | Cas | III 1 r  - I used 206x and found that averted vision really helped bring out the stars in this cluster. Still, it was not fully resolved but presents an outstanding image none the less
King 1 | Cas | II 2 r - This is one of the easiest non-ngc clusters I've observed. It appears fully resolved and will look good in much smaller scopes.
King 2 | Cas | II 2 m - At 206x this small (4') cluster appeared partially resolved.
IC 361 | Cam | II 1 r - Awesome! This cluster appeared fully resolved and resembles a smaller version NGC 7789.
  • KidOrion and Voyager 3 like this
#15 Chucky
Chucky
Posted 28 October 2020 - 08:48 AM
Great report Andrew. Sorry I missed you at Calhoun this month. A bunch of us from Columbus were there Tuesday and Wednesday nights.
#16 andreww71
andreww71
  • Loc: NE Ohio
Posted 01 November 2020 - 08:20 AM
Chucky - I saw your post in the Calhoun thread but couldn't make it down there during the week. For me, observing season is now getting up to speed and I hope to get down there again during the new moon in November.
#17 Voyager 3
Voyager 3
  • Loc: Near Bangalore, India
Posted 01 November 2020 - 09:19 AM
Great report thanks a lot some new DSOs 🙂 for me .
