Let the antique speak for itself...
160 replies to this topic
#126 deepwoods1
deepwoods1
  • Loc: Connecticut
Posted 03 September 2019 - 07:14 PM
Exciting indeed!
  • John Higbee likes this
#127 John Higbee
John Higbee
  • Loc: Virginia
Posted 11 September 2019 - 02:52 AM
I have also been working with the ATS folks on their website.  One of them provided me a picture of a Tinsley cassegrain with the OTA painted the same "medium green" as my original paint (as protected by the OTA rings).  So, there Is a precedent for this color on Tinsley telescopes...a medium green with the slightest amount of "wrinkle" in it.
I am going to restore the original aluminum tube...but am seriously considering making a second OTA out of brass for actual observational work.  Brass is over twice as heavy as aluminum, thus should be able to withstand the rigors of travel, set up and disassembly better than the original.  The mount, pier and tripod are extremely robust and should have no problem handling the additional load.
Edited by John Higbee, 11 September 2019 - 02:53 AM.
  • tim53 and combatdad like this
#128 Terra Nova
Terra Nova
  • Loc: America’s Heartland
Posted 11 September 2019 - 10:40 AM
I know a person who has a 6” F15  brass Carroll refractor. It’s the one Chesley Bonestell used to observe the moon with back around 1950 when he was doing the illustrations to be used by Walt Disney and George Pal in their films and the old (original) Disneyland amusement park ride-Flight to the Moon. Anyway, long story short (please forgive the pun), the brass tube is in two half-sections that couple together. It’s a very strong union that always preserves collimation yet it makes transport much easier. He takes it to the field frequently on fairly long trips in the back of his pickup, (or used to, I haven’t seen him or the scope in fifteen years, yet I hear that both are still doing well).
  • Mr Magoo, John Rogers, John Higbee and 1 other like this
#129 oldscope
oldscope
  • Loc: State of perpetual confusion
Posted 13 September 2019 - 07:26 PM
Johann and I had another session with the 6" objective yesterday, and made some significant progress in objective alignment and DPAC.
Last weekend, we had several unresolved problems at the end of the session:
  • Signficantly skewed Ronchi lines on the DPAC
  • Newton rings that were skewed away from the center of the objective
  • An objective that fit so tightly into the cell that there was no slight "rattle" heard after objective reassembly
David G. gave us some good advice on troubleshooting, which we followed yesterday:
  • Removing the cell from the objective, and checking the shims and air gap between the crown and flint
    • Shims were in good shape, and air gap was even around the objective perimeter
    • Using a template, found all three to be symmetrical (120 degrees apart, plus or minus a degree)
  • Checking the three support points at the bottom of the cell for proper placement
    • Using a template, found all three to be symmetrical (got similar spacing results as for the shims)
We also cleaned the inside of the cell:
  • Removed a lot of dirty film from the inside cell walls
When we re-assembled the objective, we ensured that the objective shims and the lower support points were aligned.  The objective went in on the first try with no difficulty.  We also ensured that the objective retaining ring was installed "hand-tight, then backed off slightly"...and we did get the "slight rattle" that had been missing previously.
Newton rings were symmetric and centered...and we had three straight lines on the DPAC testing!  (...and there was great rejoicing! grin.gif ).  It's possible that one element may have very slightly cocked in the cell during last week's activities, due to the dirty residue on the cell walls...that, and/or the misalignment of the objective shims to the cell support points, may have been the cause of last week's problems.
As a final (unrelated) step, we cleaned and tested the 3" f/6 objective for the finder on the 6" Spacek.  I had not been able to disassemble the finder previously, but with Johann's help we got it apart, and found that one of the objective shims was out of the air gap entirely (was on the edge of the objective...we reinstalled it after cleaning both elements).  During reassembly, Johann demonstrated for me what DPAC results for a reversed objective and flipped element looked like...as Dave G. says, DPAC will immediately show you those conditions if they exist!  Finder is reassembled, shows fine images, and is reinstalled on the 6" OTA.
All in all, a great day!  Many thanks to Johann, for his support and his patience teaching a refractor "newbie" about optical maintenance and testing!
John
John,
Some years (decades?) ago, I had a conversation with Barry Greiner, the 'G' of D & G Optical. He mentioned that retaining rings should not really allow the glass to rattle. Of course, neither should they be applying undue pressure. But they need to keep the elements from moving freely. At most, you want to hear an almost imperceptible clicking ... you should have to shake the cell and barely hear it. If the sound is obvious and easy to hear, your ring is a bit too loose. This is especially true if there are soft spacers such as paper or plastic. You definitely don't want any obvious rattle then.
Well, that's my 2 pence.
BR
Bart
  • Terra Nova likes this
#130 John Higbee
John Higbee
  • Loc: Virginia
Posted 13 September 2019 - 08:12 PM
Bart - thanks for the advice (which I agree with).  The objective is at the "slight clicking" level you describe...rattle would be overstating its degree of motion in the cell.
Just finished stripping the OTA this afternoon.  will be stripping the focuser and the OTA rings tomorrow...leaving the worst for last...the 50# fork and "rising column" mechanism. shocked.gif
Still shooting for a slot at the ATS booth for the 2020 NEAF...John
  • deepwoods1 likes this
#131 John Higbee
John Higbee
  • Loc: Virginia
Posted 15 September 2019 - 10:04 AM
Here is the focuser before several hours of hand sanding:
and after:
the focuser casting is beautiful (no flaws in the casting that I can see)
Almost want to seal it (after polishing it) and install it as is...but Saturn telescopes focusers were painted the tube color, and its tube (once "un-dented") will be painted...so this is only a temporary view.  In any case, it's nice to see how well it was made!
On to the OTA rings...
John
Edited by John Higbee, 15 September 2019 - 10:06 AM.
  • astro140, deepwoods1, Terra Nova and 2 others like this
#132 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 15 September 2019 - 11:05 AM
a lot of hard work John.  You are doing a great Job.  I have been extremely busy these last couple of months otherwise I would be helping.
Johann
#133 oldscope
oldscope
Posted 29 September 2019 - 05:16 PM
Does the nameplate come off? You might find the original color underneath. Also, not too difficult to get the focuser draw tube replated..Whoever does the work can strip the old plating chemically, but don't let them polish the hell out of the tube before plating it. That should be done very gently on a lathe or you will get uneven polishing and a gimpy focuser.
Bart
Edited by oldscope, 29 September 2019 - 05:18 PM.
  • Terra Nova and John Higbee like this
#134 John Higbee
John Higbee
  • Loc: Virginia
Posted 01 October 2019 - 05:15 AM
Bart
Bart - I did find the original color (a medium green, non-gloss, with a very fine "wrinkle" texture) when I took the OTA rings off the tube.  There were also traces of it on the focuser casting.  I verified that Tinsley used this color (one of our ATS friends pointed me towards a picture of a Tinsley 12" Cassegrain with a green OTA).
On the other hand, the only other 6" Tinsley we know of has the classic Tinsley "blue/grey" gloss finish...which I like better than the green.  So, I could go either way...will probably stick with the green if I can find a match for it in an "over-the-counter" enamel color.
Replating the focuser tube will be a future project...right now, it is operating well, and getting the focuser knob off looks to be a challenge (looks like it is fastened to the shaft with a pin, not a screw).  Getting the OTA and the fork/rising pier assembly repainted, and final refinishing done on the maple tripod legs, are next on the agenda.
Edited by John Higbee, 01 October 2019 - 05:17 AM.
  • oldscope likes this
#135 oldscope
oldscope
Posted 09 October 2019 - 06:48 PM
The pin you mention might be a tapered pin, which is actually easy to remove. If it is, one side will be slightly smaller than the other. Of course, tap the smaller side and it should come out with little trouble.
B.
#136 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 09 October 2019 - 07:53 PM
Which 6" Tinsley are you referring to?   A refractor or a Cassegrain?  I have a 6" Tinsley Saturn Cass, but I've never heard mention of another one.  The original paint on mine was that unusual blue/gray (+ green?) gloss.
Edited by Bomber Bob, 09 October 2019 - 08:05 PM.
  • Stevegeo likes this
#137 John Higbee
John Higbee
  • Loc: Virginia
Posted 11 October 2019 - 12:58 PM
I'm referring to the 6" f/16 achromatic refractor I am refurbishing (picture below).  Tinsley records reviewed by Clint Whitman in 2010 indicated that only three of these were ever made.  I have one; a member of the Antique Telescopes Society (ATS) has another; location of the third is unknown.
My OTA and focuser were largely bare (no primer was used).  The traces of color coat left on mine were a "forest" green with a very fine wrinkle texture. The ATS member's scope has the more common Tinsley "gloss bluish gray".
John
  • tim53, CharlieB, astro140 and 8 others like this
#138 Bomber Bob
Bomber Bob
Posted 11 October 2019 - 08:35 PM
Yeah, I thought you were probably referring to the refractors.  Is the paint (that's left!) on my Cass that blue/gray you mentioned?  It has an unusual sheen in the sunlight that I haven't seen on any other scope, and it has a hint of green in it to me.  Indoors, the blue dominates.
[I've been trying since I got it from Bob Midiri to determine if Tinsley ever made another of these 6" Casses, since they aren't in any of the catalogs I've seen.]
I've been following your restoration with great interest -- and admiration.  Talk about a Big Project!!
#139 KennFromTX
KennFromTX
  • Loc: Pharr Texas
Posted 18 December 2019 - 07:46 AM
Hows the restoration going?
#140 John Higbee
John Higbee
  • Loc: Virginia
Posted 19 December 2019 - 03:16 AM
Kenn - Have been paused for the last two months for the usual reasons (workload at the office; family commitments)...and the unusual (finalizing design for our retirement home on Virginia's Northern Neck; working astronomy outreach at the Naval Academy Class of '41 Observatory; and preparing for retirement late in 2020).
During my time off over the holidays, I'll be taking the stripped OTA and focuser assembly into an auto body shop to accomplish tube dent removal, and potential powder coating to match the "forest" green original paint.  I'll also ask the machinist who repaired the tube ring assembly to make a duplicate set of finder rings.  This will allow me to mount my second Tinsley finder on the other side of the OTA from the current finder (the scope is massive enough to warrant a finder on either side of the OTA).
Work at home will include:
  • stripping and repainting the OTA ring assembly, and the massive alt-az fork/rising pier assembly (black)
  • "finishing the refinishing" of the tripod hardwood legs (lightly sanding the current coatings, then doing the final staining).
Objective / mounting cell are clean, and the objective is installed and has been successfully collimated (checked with the DPAC test).
Once the above work is done, we (Dave (combatdad) / Johann (starman876) and me) will reassemble and first light the scope, and do a comparison of its performance with my Spacek 6" f/15.
I'll provide commentary and photos on this thread as progress is made.  I am still shooting for displaying the restored telescope at NEAF 2021 at the Antique Telescope Society's booth.
thanks, John
Edited by John Higbee, 19 December 2019 - 03:34 AM.
  • Terra Nova, Bomber Bob and TSSClay like this
#141 RalphMeisterTigerMan
Posted 19 December 2019 - 10:31 AM
Do you have any plans of building a backyard observatory with an equatorial mount for a permanent pier observatory? It really is a great scope but as I found out, you will not want to keep on going to various star parties and set it up and take down for too long. Besides, with the proper size GEM you could add other scopes such a wide-field aux. scopes for the whole high-power viewing and low power rich-field experience.
But regardless of what you decide, it's a great scope and a nice piece of history. Do not let the naysayers bother you with the chromatic aberation problem. I believe a minus-violet filter coupled with modern, sophisticated eyepiece designs will most likely render that problem to the point where it is undetectable by the human eye. Enjoy your beautiful scope and don't be shy about showing it off.
Clear skies and good luck!
  • John Higbee and combatdad like this
#142 Steve Allison
Steve Allison
  • Loc: Olympia, Wash. 98502
Posted 19 December 2019 - 03:42 PM
But regardless of what you decide, it's a great scope and a nice piece of history. Do not let the naysayers bother you with the chromatic aberation problem. [....]
Agree 100%.
At the magnifications my local seeing allows, my 4 inch Tinsley F/15 achro (thanks Dave Trott) keeps up very well with my Takahashi FS-102 NSV apo. And at F/15, I can get 150X with a comfortable and inexpensive 10mm eyepiece.
Many of these quality classic achromats are beautifully corrected for spherical aberration, as are John's and mine.
Edited by Steve Allison, 19 December 2019 - 03:43 PM.
  • John Higbee, combatdad and Defenderslideguitar like this
#143 John Higbee
John Higbee
  • Loc: Virginia
Posted 23 January 2020 - 07:20 AM
Have been busy working the renovation.
Spent a weekend with a good friend learning the wonders and mysteries of Bondo.  As you recall, the Tinsley tube was a mass of dents and creases (the result of long use on a 1/16" thick aluminum tube).  Most were small; a handful were deep.  None impinged on the light path.  After applying Bondo in several thin coats (sanding in between coats), here's the current state of the tube:
I've finished sanding with 120 grit, and will sand with progressively smaller grit in preps for priming with an etching primer.  After long consideration, I've decided that the color coat will be the traditional gloss gray-blue that Tinsley used on the Saturn line.
More to come...John
Edited by John Higbee, 23 January 2020 - 07:21 AM.
  • CharlieB, astro140, clamchip and 6 others like this
#144 John Higbee
John Higbee
  • Loc: Virginia
Posted 23 January 2020 - 06:48 PM
Continuing on:  here's a picture of the OTA "as received" for comparison purposes:
Definitely have come a "fur piece" on this one!
John
  • astro140, Terra Nova and Bomber Bob like this
#145 John Higbee
John Higbee
  • Loc: Virginia
Posted 23 January 2020 - 06:50 PM
next - the focuser - pretty much ready as is...
will give it a light sanding with fine grit prior to its coat of etching primer...virtually no flaws on this casting!
John
Edited by John Higbee, 23 January 2020 - 06:52 PM.
  • astro140, clamchip, Terra Nova and 1 other like this
#146 John Higbee
John Higbee
  • Loc: Virginia
Posted 23 January 2020 - 06:56 PM
Am hand sanding the OTA rings (mindful of what Robert found when he used chemical stripper on his "return from the dead" Tinsley 4" string).
That string has been my "how to guide" throughout my journey with the 6"...thanks, Robert!
Edited by John Higbee, 23 January 2020 - 07:07 PM.
  • clamchip, Terra Nova and Bomber Bob like this
#147 John Higbee
John Higbee
  • Loc: Virginia
Posted 23 January 2020 - 07:02 PM
Now, here's my Christmas in January story...
I received the 6" without the focuser diagonal and the focuser extender...they had come with the scope, but were "absent without leave" when I picked it up.
I had pretty much given up on finding originals, and had had a local machinist fabricate an adapter allowing a Unitron drawtube to connect with the Tinsley's rack and pinion focuser...it works great! (thanks, Dave Komar!)
THEN...
Edited by John Higbee, 23 January 2020 - 07:03 PM.
  • clamchip, Terra Nova, combatdad and 2 others like this
#148 John Higbee
John Higbee
  • Loc: Virginia
Posted 23 January 2020 - 07:06 PM
I got a call from my friend at the donating astronomy club, telling me that the club had come across a box labeled "Saturn" with the following contents:
BINGO!!  Christmas in January!!!
  • astro140, clamchip, deepwoods1 and 4 others like this
#149 John Higbee
John Higbee
  • Loc: Virginia
Posted 23 January 2020 - 07:32 PM
Here's what arrived:
the diagonal:  paint's worn and flaking, but the prism looks to be in good shape
the long focuser extender:  paint looks great on this one
and an old fashioned Barlow...don't know if this is a Tinsley or not...reminds me of a '60s vintage Edmund, but the metal is thicker and more robust
In the background, you see my other hobby...Lionel O gauge trains!!
John
Edited by John Higbee, 23 January 2020 - 07:34 PM.
  • clamchip, deepwoods1, Bomber Bob and 1 other like this
#150 mpsteidle
mpsteidle
  • Loc: Cincinnati OH
Posted 05 February 2020 - 10:03 PM
Exciting! I cant wait to see what you have in store for it.
