Let the antique speak for itself...
171 replies to this topic
#151 Ben H
Ben H
Posted 06 February 2020 - 12:13 AM
Thanks for keeping this thread up! This is probably the most I've ever seen/learned about large refractors from the '40s. It seems like very little from the period survives today, even compared to 19th century telescopes.
  • John Higbee likes this
#152 John Higbee
John Higbee
  • Loc: Virginia
Posted 07 February 2020 - 11:02 AM
It's fun...first time for me to do a restoration this deep...and to learn about a rare version of a superlative telescope line (Tinsley Saturn).
Good karma continues...I don't have a set of the original Tinsley eyepieces, but came across a set of six late '30s eyepieces (four Mogey, two "unidentified") in a Virginia antique store...so now I have an eyepiece set from the same era as the telescope! (for more info, look at the separate topic covering it on this forum).
  • Terra Nova and Bomber Bob like this
#153 John Higbee
John Higbee
  • Loc: Virginia
Posted 07 February 2020 - 11:08 AM
Do you have any plans of building a backyard observatory with an equatorial mount for a permanent pier observatory? It really is a great scope but as I found out, you will not want to keep on going to various star parties and set it up and take down for too long. Besides, with the proper size GEM you could add other scopes such a wide-field aux. scopes for the whole high-power viewing and low power rich-field experience.
But regardless of what you decide, it's a great scope and a nice piece of history. Do not let the naysayers bother you with the chromatic aberation problem. I believe a minus-violet filter coupled with modern, sophisticated eyepiece designs will most likely render that problem to the point where it is undetectable by the human eye. Enjoy your beautiful scope and don't be shy about showing it off.
Clear skies and good luck!
RalphMeisterTigerMan
I do...but how the Tinsley will figure in it is "to be determined". I do intend to take it up to NEAF 2020 and display it at ATS; then take to a star party for each of the clubs I belong to (Westchester Amateur Astronomers, and NOVAC)...need to build a strong case for the OTA...another item on my list.
Edited by John Higbee, 07 February 2020 - 11:11 AM.
#154 marcyc
marcyc
  • Loc: Northern VA, USA
Posted 07 February 2020 - 01:39 PM
Ooooo..... Can't wait until it shows up at a NOVAC event. Give us a heads up when you plan to bring it, okay?
#155 John Higbee
John Higbee
  • Loc: Virginia
Posted 07 February 2020 - 09:38 PM
Will do, Marcy! John
#156 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 08 February 2020 - 05:18 PM
The OTA has come a long way John.  You have made great progress.  How do you plan to paint the tube?  With a spray gun?
#157 John Higbee
John Higbee
  • Loc: Virginia
Posted 09 February 2020 - 08:50 PM
Hi, Johann! thanks for the compliment!
Plan right now (subject to comment and improvement): Once I get a day where the temperature will stay above 60 degrees, I plan to suspend the OTA on my homemade "painting jig" under our second story deck (this is a 1" seven foot long wooden dowel suspended by two loops of chain from the deck supports).
The jig allows me to manually turn the tube on the dowel during painting (I used it successfully when I painted the pier for the Spacek 6")
Then:
1) Two light coats of gray Rustoleum etching primer (lightly sanding each coat once it dries), followed by
2) Several thin coats of Rustoleum blue gray enamel (the same shade that Robert used on his 4" Tinsley resurrection)
3) I'll also be painting the focuser assembly by hand (not on the jig) using the same sequence as for the OTA.
The balance of the scope:
* Tripod Legs: lightly sand the legs, then restain with a mahogany stain that closely matches the original
* OTA Rings: sand, prime and paint with Rustoleum black enamel
* Finder rings: paint to match the OTA
* Finder (no paint necessary - I found a match for the original finder that I will use (will restore the original finder after I finish the major restoration))
* The diagonal drawtube and the straight drawtube - leave as is (honorable usage scars)
* The objective cell - leave as is (honorable usage scars)
* The alt-az fork mount, tripod hub, and rising pier mechanism: sand/prime where necessary, then spray with Rustoleum black enamel
* Rising pier braces to legs: sand, prime and paint with black Rustoleum enamel
* Rising pier handwheel: sand and paint the same shade as the OTA
I am going to replace aluminum hardware where feasible with brass (dress up the scope a little bit). Finally, I need to make an OTA box to allow for safe travel to NEAF.
So, I'll be busy over the next 6-7 weeks! John
Edited by John Higbee, 09 February 2020 - 08:54 PM.
  • George N, Terra Nova, Bonco2 and 2 others like this
#158 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 09 February 2020 - 09:24 PM
How soon do you need the box?
#159 John Higbee
John Higbee
  • Loc: Virginia
Posted 09 February 2020 - 09:37 PM
Johann - The last week in March...(NEAF is the first weekend in April). Any advice on how to do this will be gratefully accepted! John
#160 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 09 February 2020 - 10:07 PM
We could build it together John.  I have all the woodworking tools we need.  Do not know how fancy you want the box and what else besides the scope you want to store in the box.
  • deepwoods1 and John Higbee like this
#161 John Higbee
John Higbee
  • Loc: Virginia
Posted 09 February 2020 - 10:38 PM
Johann - that would be great! Will give you a call/e-mail to discuss...main emphasis would be hitting an optimum point giving the necessary strength while preserving "handle-ability" (if that's even a word)! Might require a second smaller box to store the objective/cell, finder, eyepieces and the focuser assembly, in order to cut down on the >90" length and overall size of the assembled OTA. Looking forward to doing this with you...and really appreciate your help! thanks, John
#162 John Higbee
John Higbee
  • Loc: Virginia
Posted 05 April 2020 - 04:01 PM
Well - today's "painting day" - high in the 60s and little if any wind.  Got my rig set up under the deck, and the patient is ready...not so sure that the "painter" is...
My one consolation is that, however this turns out, the OTA will be in better shape than it's been for the last 50 years or so...
Note the green paint remnants...and the complete lack of primer...we're going to give the OTA a solid primer coat, and replicate the color coat.  Decided to go with a Rustoleum Gloss Hunter Green...this is close to what it originally had...and Tinsley did use a satin hunter/forest green on some of its scopes in the 40s and 50s.
I went with gloss vice satin finish,  because I really liked the Tinsley gloss finish for their blue gray, and thus kept that finish in parallel with staying close to the original color.  Will be using brass hardware for the cell/focuser/finder screws...should look really nice!
Edited by John Higbee, 05 April 2020 - 05:05 PM.
  • L. Regira, Terra Nova, Bomber Bob and 4 others like this
#163 John Higbee
John Higbee
  • Loc: Virginia
Posted 05 April 2020 - 04:12 PM
Using Rustoleum white Bare Metal Primer... after progressively sanding the OTA using 240, and 600-grit sandpaper following the Bondo patching.  Used a spray can with length-of-OTA strokes, rotating the tube one quarter of a rotation between strokes.
Took me several strokes to get into the proper light application density...last time I did this was with the Spacek 6" refractor pier...
First primer coat complete:
After waiting a few minutes, applied the second primer coat, using the same technique.  Looking better, now...
Edited by John Higbee, 05 April 2020 - 05:07 PM.
  • Terra Nova, Bomber Bob and jcruse64 like this
#164 John Higbee
John Higbee
  • Loc: Virginia
Posted 05 April 2020 - 04:24 PM
I then let the OTA sit for 45 minutes (the Rustoleum instructions specify applying the color coat within an hour of the last primer coat), then brought out the Hunter Green...
These pictures were taken ~ three hours after I finished painting:
The OTA surface is dry to a "gentle" touch.  Intend to leave it up on the rig overnight - then take it down and let it finish setting up in the garage.
Miraculously, there were no bugs embedded in the paint...had a problem with one "unfortunate visitor", during the priming phase, but was able to gently remove him using the edge of a piece of paper.
Tomorrow, I'll be finishing up the "hunter green" painting (the focuser assembly, and the two finder scope brackets).
Edited by John Higbee, 05 April 2020 - 05:09 PM.
  • stevew, deepwoods1, Terra Nova and 3 others like this
#165 John Higbee
John Higbee
  • Loc: Virginia
Posted 05 April 2020 - 04:31 PM
Here's a picture of "Tinsley green" on one of their 12" Cassegrains...
  • tim53, stevew, deepwoods1 and 5 others like this
#166 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 05 April 2020 - 04:34 PM
Looks great John.  Keep up the great work and stay healthy and safe.waytogo.gif
#167 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 05 April 2020 - 05:43 PM
John, she's looking good -- and that's a LOT of tube to paint.  I didn't know about the Tinsley Green, but I like how it makes brass hardware stand out with a glow.
Thanks for your hard work, and for sharing it with us!
#168 John Higbee
John Higbee
  • Loc: Virginia
Posted 05 April 2020 - 10:33 PM
You too, Johann!  John
#169 John Higbee
John Higbee
  • Loc: Virginia
Posted 07 April 2020 - 12:39 AM
Thanks, JW!  Congratulations on how well your restoration of your Tinsley 6" Cassegrain turned out...that is one gorgeous scope!
Will paint the focuser assembly today...then will take on the heavy labor of sanding and repainting the OTA rings; the alt-az fork, and the 60 lb rising pier assembly and its radial braces to the tripod legs, with Rustoleum textured black enamel.
Final steps will be the sanding and refinish of the walnut tripod legs; and the replacement of old hardware on the tripod and OTA with brass equivalents.
Not quite on the final lap, but close...
John
  • R Botero, deepwoods1, JonH and 3 others like this
#170 John Higbee
John Higbee
  • Loc: Virginia
Posted 11 April 2020 - 07:12 PM
...and the fruit of today's labor...the focuser, in hunter green!  Have a little touch-up work to do, but it came out pretty well.  John
Edited by John Higbee, 11 April 2020 - 08:21 PM.
  • starman876, clamchip, deepwoods1 and 5 others like this
#171 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 11 April 2020 - 07:37 PM
...and the fruit of today's labor...the focuser, in forest green!  Have a little touch-up work to do, but it came out pretty well.  John
Looks fantastic
#172 rwiederrich
rwiederrich
    Goldfinger
  • Loc: Gorst Washington(center of the Universe)
Posted 14 April 2020 - 02:36 PM
GREEN...Well plaid John.  Tinsley picked a great color for their scopes.  Green is the new White.
Both of my *Big* scopes are a shade of green.
Wonderful work indeed...…
Rob
Edited by rwiederrich, 14 April 2020 - 02:40 PM.
