Blue blotches - lens flare or what?
5 replies to this topic
#1 khobar
khobar
Posted 11 January 2019 - 11:52 AM
I've noticed some blue blotches on my pics and am wondering what they are. Using an 80mm ES80 APO with a modded Nikon D5100, a ES field flattener and Orion imaging LPF. They've been present in my B33/Flame, M42, and M45 at least. I thought there was just three but when I looked at my M45 from last night there seemed to be a whole lot more.
These were stacked in DSS, adjustments *applied* just so I could bring out what I was talking about. There are some dark spots, too, probably just dust. But the blotches - just dirt? Pin holes in the filter? Something else? Thanks.
Just off M42:
M45:
#2 khobar
khobar
Posted 11 January 2019 - 12:22 PM
As a follow up, here's a shot of NGC2467 using same equipment, same night, etc. There are fewer subs (6) however.
I don't *think* I see the blotches.
#3 einarin
einarin
Posted 11 January 2019 - 12:36 PM
Reflection from brighter stars.
You could try without field flattener.
  • khobar likes this
#4 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 11 January 2019 - 03:44 PM
Yep, reflections from stars.  I'd blame the LP filter before the FF though...they're usually the culprit.
#5 bill5wjw
bill5wjw
Posted 11 January 2019 - 04:31 PM
Are you using flat frames in your stacking process? If so, then as einarin said above, remove the flattener, and try again.
I also had a problem with a reflection in this region of the sky and it turned out that a threaded adapter I was using was causing reflections that looked like arcs. I spray painted the inside of this adapter with flat black paint and now there are no more reflections.
#6 khobar
khobar
Posted 11 January 2019 - 11:17 PM
Very interesting!
I am using flats.
It was supposed to be cloudy tonight, but I was able to get about an hour in before it clouded over and can confirm without the FF I can see no blotches, blue or otherwise, at least not with M45.
So, what now?
