QHY183C - bias/darks random minimum ADU value 0
15 replies to this topic
#1 niccoc1603
niccoc1603
  • Loc: Firenze, Italy
Posted 11 January 2019 - 04:30 PM
I am testing my new QHY183C
I have noticed a weird behavior with bias/dark frames
I collect the frames in APT with ASCOM QHY driver, settings below
When I analyze my bias/dark frames, sometimes they return a 0 min ADU value, see below.
These three bias are were shot in a sequence with same settings above. Bias 3 shows min ADU=0
The difference I can spot is that Bias 3 histogram is shifted to the left and a tiny line appears in the right part of the hystogram for Bias 3 (circled in red).
I have no idea is this might be the cause and where it comes from
same for the darks:
FITS can be downloaded from here:
https://drive.google...sAF0scKhQ9x9iFE
Edited by niccoc1603, 11 January 2019 - 04:37 PM.
#2 Shiraz
Shiraz
  • Loc: South Australia
Posted 11 January 2019 - 10:06 PM
that is odd.
The camera appears to be sometimes blacking out one and a bit lines at the bottom of the frames. It seems to be only a minor fault that does not appear to affect/shift the main part of the image, so it should be fairly easy to crop - but it should not happen. Maybe worth a note to QHY to see if they can advise/fix it. Might possibly be something to do with the overscan removal, so perhaps try another capture software if you have anything available.
Edited by Shiraz, 11 January 2019 - 10:24 PM.
#3 niccoc1603
niccoc1603
Posted 12 January 2019 - 01:49 AM
I have tried with Sharpcap
no issues with direct QHY Driver capture
by using ASCOM drivers, the issue is back
It seems to be a problem related to QHY ASCOM drivers
Edited by niccoc1603, 12 January 2019 - 01:52 AM.
#4 entilza
entilza
  • Loc: Oakville, ON, Canada
Posted 12 January 2019 - 09:48 AM
Hey, What QHY ASCOM Driver version are you using?
I loaded the fits in Pixinsight, the little bump is there at the beginning but the minimum value is slightly different.
#5 niccoc1603
niccoc1603
Posted 12 January 2019 - 10:50 AM
I am using the latest drivers
Not sure what the magic is in PI , I loaded the "dark 2" (21-29-04) in Nebulosity and it is showing Min 0 as well
Edited by niccoc1603, 12 January 2019 - 10:53 AM.
#6 entilza
entilza
Posted 12 January 2019 - 11:02 AM
I saved Their 0.19 version - ASCOM 0.19  Can you try that and try your test again please?
https://drive.google...BRQ9tNBdkuoShk-
#7 niccoc1603
niccoc1603
Posted 12 January 2019 - 11:05 AM
ok, how do I remove the previous ones?
#8 entilza
entilza
Posted 12 January 2019 - 11:08 AM
Just install this it will remove the old version automatically...
To be sure 0.19 installed check the directory:  C:\Program files(x86)\Common Files\ASCOM\Camera     The QHY DLL files should have a time stamp of 2018-11-30.
Edited by entilza, 12 January 2019 - 11:11 AM.
#9 niccoc1603
niccoc1603
Posted 12 January 2019 - 11:29 AM
something's weird
When I connect the camera the first time, the ASCOM driver window shows FW version
When I open the ASCOM driver settings later FW version is "uknown"
Edited by niccoc1603, 12 January 2019 - 11:34 AM.
#10 entilza
entilza
Posted 12 January 2019 - 11:34 AM
Ack well this didn't help your issue, sorry :(
I'm not sure why pixinsight showed a different minimum?
#11 entilza
entilza
Posted 12 January 2019 - 11:36 AM
At first I was going to say don't use such fast exposures, but I see you have higher exposure tests... Normally you use Dark flats (not bias) for these CMOS cameras...
I'm not sure if what you are seeing is typical for this camera,  maybe everything will be ok.  It could be that overscan area checkbox, that seems to be default for you?  on my QHY163 it is off but it's a different camera.
#12 entilza
entilza
Posted 12 January 2019 - 12:54 PM
Mine does the same "unknown" thing after connecting then clicking properties... Probably not anything major.
Does the minimum 0 still happen after turning off overscan checkbox?
Edited by entilza, 12 January 2019 - 01:02 PM.
#13 niccoc1603
niccoc1603
Posted 12 January 2019 - 01:29 PM
Yes, both checked and unchecked
#14 bulrichl
bulrichl
  • Loc: La Palma (Canary Islands)
Posted 13 January 2019 - 05:36 AM
Mouse-over option 'Unclipped' in PixInsight's Statistics tool and the following help text will appear:
By default, the Statistics tool computes statistics for the subset of pixel sample values within the [0,1] normalized range, that is, excluding pure black and white pixels. Enable this option to compute statistics for the unclipped [0,1] range.
So this is expected behavior and you can toggle it by checking/unchecking the option 'Unclipped' in the Statistics tool.
Bernd
#15 entilza
entilza
Posted 13 January 2019 - 12:03 PM
Yes it's that black line at the bottom... and selecting unclipped shows min zero..
This probably won't affect anything, I don't think anyway.
#16 niccoc1603
niccoc1603
Posted 09 March 2019 - 01:18 PM
for the record, after several iterations with the QHY guys they provided me with a new version of qhyccd.dll that has solved the MIN=0 "black line" issue
I guess they will update the .dll in the new drivers, but for now I have uploaded it here
it must be copied and replaced in C:\Program Files (x86)\Common Files\ASCOM\Camera
Edited by niccoc1603, 09 March 2019 - 01:20 PM.
