ZWO ASI1600MM Pro Bright Star Issue
art astrophotography CMOS imaging optics
14 replies to this topic
#1 IvgnfshngAstro
IvgnfshngAstro
  • Loc: Pacolet, SC USA
Posted 15 January 2019 - 11:03 AM
Hello, my name is James and I am experiencing significant halo art of some sort when imaging bright stars (see attachment).  The camera is the ZWO ASI1600MM Pro using a ZWO filter wheel with ZWO filters (31mm).  The scope is an ES 127mm FCD100.  I think this is an issue that has been discussed in the past but I couldn't find where anyone maybe came up with a solution or workaround.  Any help would be appreciated since the money is spent, my rig is set up, and there are plenty of bright stars up there to photograph!!
Thanks, James
  • rwstanley and 1stan like this
#2 Mark326
Mark326
  • Loc: Florida
Posted 15 January 2019 - 11:20 AM
Microlensing is what you’re seeing I believe. Many threads on this issue with that camera. I do not own but am considering purchase. Alnitak (star) makes OSC difficult in that region too, hard to captiure dynamic range of Nebula without over exposing (blowing out) the bright star.
Edited by Mark326, 15 January 2019 - 12:58 PM.
  • mumbles likes this
#3 jerahian
jerahian
  • Loc: Maine
Posted 15 January 2019 - 11:26 AM
You can try Dave Ault's approach to remove the halo and the internal reflection artifact.  It's lengthy for one halo, but the Curse of Alnitak has struck your otherwise lovely image in a major way.
Dave's tutorial:  http://trappedphotons.com/blog/?p=616
The process is derived from this post on CN:  https://www.cloudyni...tak-i-hate-you/
If you decide to do it, please let us know how it turns out!
#4 FlankerOneTwo
FlankerOneTwo
  • Loc: Vegas, baby!
Posted 15 January 2019 - 12:27 PM
You have classic ASI1600 microlens reflections (the little blotchy brights spots). The halo could be from the filter, the edge does appear to me more distinct than in some other microlens reflection examples that I've seen, not sure which one you are using in this image. In LRGB I get a smooth flare but not a distinct halo with Astrodon filters, I've heard reports that they are the best in this regard. I have not personally imaged this target with the Optolong LRGB I had before, though. The Optolong H-alpha I'm currently using does produce a (smaller) distinct halo, someday I'll pony up for an Astrodon and see if it's better.
#5 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 15 January 2019 - 03:01 PM
Just for the record, this is not Microlensing.  That is the name for small intensity fluctuations in star brightness caused by (often invisible) foreground objects, see Wikipedia
What you see there is diffraction patterns caused from reflections on the non-AR coated microlenses of the camera sensor.  And unfortunately there's nothing you can do about that (other than getting a camera with a different sensor).  Check this thread, especially the theoretical moddeling by sharkmelley.
  • Mark326 likes this
#6 PhotonHunter1
PhotonHunter1
  • Loc: Northwest Suburbs of Chicago
Posted 17 January 2019 - 08:09 PM
A common issue with the ASI1600 cameras. I just imaged this object with my ASI1600MM-C and experienced the same distortion and halo effect. Here’s another thread that covers this same object/topic. https://www.cloudyni...ease/?p=9075189
#7 rottielover
rottielover
  • Loc: St. Louis MO
Posted 17 January 2019 - 08:15 PM
I'm sure you can find the threads but most of us have ditched the ZWO filters in favor of Astrodon's or Baader filters.
Edited by rottielover, 17 January 2019 - 08:16 PM.
  • tcchittyjr likes this
#8 Seanem44
Seanem44
  • Loc: Stafford, VA
Posted 17 January 2019 - 08:47 PM
It’s all about the filter. Astrodon are expensive but work perfect. I see motiveless difference between my AD Ha and Baader Oiii
#9 AdamJ
AdamJ
Posted 18 January 2019 - 08:31 AM
Thanks, James
As others have said this is two things.
1) The microlense diffraction pattern is inherent to the camera (its the smaller spots closer to the star).
2) The large circular halo something else. Assuming the filter wheel is screwed directly to the cameras male connector then its too big to be a filter reflection between the sensor and the filter. That leaves three possibilities you have the older ZWO unmounted filter and its edge is not blackened. Or you have the filter in backwards (as is possible with 31mm). Or the anti-reflection coating on your reducer / flatter is poor and its causing reflections from the sensor to the reducer and its not related to the filter all all.
The cure is to try reversing the filter in the holder to try and fix the large halo. If that does not work try masking off the edge of the filter, if that does not work then try imaging without the flattner / reducer to see of the halo vanishes.
As for the micro lense diffraction effect, the only real way to reduce that is with a more expensive narrower filter such as the 3nm Astrodon that will greatly attenuate the star brightness.
Good luck
Adam
  • Shiraz and cfosterstars like this
#10 cfosterstars
cfosterstars
  • Loc: Austin, Texas
Posted 18 January 2019 - 11:04 AM
Good luck
Adam
I agree with Adam. this is two issues and not one. I have the same camera with Astrodon filters. I see the same microlensing diffraction pattern from the sensor cover glass. However, the large bright halo is likely from the filers. Do you have the new ZWO filters or the OLD original ZWO filters? The old filters have serious halos for the Nb filters. The new ZWO filters are much better. However, the micro lens issue will still be there with even 5nm Astrodon filters.
#11 IvgnfshngAstro
IvgnfshngAstro
Posted 18 January 2019 - 11:53 AM
Thanks guys for your responses.   Sad that it's not fixable but I guess I can't be too upset since the camera does pretty good with most targets, just not the brighter stars. The filter used was the Ha, sold as part of the package deal from OptCorp (camera, EFW, and lrgb + nb filters), but as to whether or not they are the new or old, I don't know. The purchase was about 3 months ago so hopefully they're the new version.  The camera is mounted directly to the filter wheel which I believe is preferable.  As far as flipping the filter I guess I can try that at some point along with the masking idea, to see if it helps with the halo. But the bigger defect is the micro lens diffraction pattern, so I'll just have to avoid the brighter stars with this camera anyways.
And thanks for the link to the tutorial.  I'll give it a shot and post any favorable outcome. As far as trying a camera with with different sensor, I've yet to purchase a cooled OSC, so any recommendations as to cameras with sensors without the micro lens problem I'd certainly like to hear what they are.
Thanks, James
#12 cfosterstars
cfosterstars
Posted 18 January 2019 - 05:42 PM
If you look on the ZWO web site and look at the narrow band filters, it will show you how to tell the difference between the new and old filters. It is actually quite easy and clear which you have by looking a them.
#13 Seanem44
Seanem44
  • Loc: Stafford, VA
Posted 18 January 2019 - 08:42 PM
Man... it must be a quality control issue. I’ve never had microlensing in my 1600. Maybe it has to do with the OTA as well.
#14 Stonius
Stonius
Posted 19 January 2019 - 12:05 AM
If you want to nail down exactly how far away from the sensor the reflection is, there is a handy calculator here http://www.wilmslowa...lae.htm#REFLECT
Cheers
Markus
#15 bigjy989
bigjy989
  • Loc: Saline, MI
Posted 19 January 2019 - 07:17 AM
The only work around with the ASI1600 is to stretch less or remove the stars and recombine the stars again at the end.  I have a similar setup with the ASI1600 but with a 140mm refractor and Astrodon filters (Recently got the same large halo/filter reflection and the same microlense reflections on the same target about 2 weeks ago.).  I gave up trying to correct it and just removed the stars completely in Startools 'heal function - an hour of tweaking the mask, max settings but detail radius 140pixels).  Removing the stars is not too complicated after you find a process.  The good news it is really only affects very few targets.
Starless Horsehead
Edited by bigjy989, 19 January 2019 - 07:18 AM.
  • TheZ3roCool likes this
Also tagged with one or more of these keywords: art, astrophotography, CMOS, imaging, optics
