ASI071 MC Pro Wont cool to selected temp
7 replies to this topic
#1 birddog99
birddog99
  • Loc: Houston, Texas
Posted 18 January 2019 - 11:47 PM
A good friend in our astro club is letting me try his ASI071 MC Pro. When I select a temperature to cool down to, ie: -20, -10, I watch the temp drop down on the display down to almost the temp I select, but it wont get to within 5 degrees of the temp I select. I verified this in Sharpcap pro and SGP. Out of 5 imaging sessions over the last 2 weeks, only 2 sessions had the temp reaching the selected temp. Dew heater on or off doesn't matter. The cooler will run at 100% during this time. I'm wondering if it's a camera issue or a software issue. The correct ASCOM drver is installed. Ant ASI071 users have this problem?
#2 AhBok
AhBok
Posted 19 January 2019 - 12:02 AM
It sounds more like a cooler problem. What is your ambient temperature? Mine easily cools to 35c below ambient, more if I run above 80% power. Are you sure your fan is running? Do you have at least a 5 amp supply? Have you measured your voltage under load?
#3 ThatsMyCoffee
ThatsMyCoffee
  • Loc: Czech Republic
Posted 19 January 2019 - 01:31 AM
Sounds like your temp setting is just too low.  It should do 35c below ambient.  If it won't, contact zwo.
What is the outdoor temp and what temp are you trying to reach?
Edited by ThatsMyCoffee, 19 January 2019 - 01:32 AM.
#4 birddog99
birddog99
Posted 19 January 2019 - 03:52 AM
5amp power supply confirmed. I'm inside now running Sharpcap. Ambient temp is 25.3C. Target temp -10.0C.  After about 5 minutes the cooler settled in at 68% and locked in at -10.0. I lowered temp setting to -20.0C and with the cooler running at 100% the lowest temp it reached was -16.1. It would go back and forth from -16.1 to -15.4 while cooler running at 100% So if it should do 35C below ambient, then -10 is all I should expect for it to cool to, right? So maybe all is ok, and it's the ambient temp that is the issue.
#5 jgraham
jgraham
Posted 19 January 2019 - 08:12 AM
When my camera is out on the scope I like to keep my TEC load no higher than 30%. While colder is better, what you are really after is thermal stability. I run my ASI071MC Pro at 0 to 10C in the summer, -10 to -20C in the winter. When taking darks inside I never run the TEC below -10C.
Sounds normal to me. Make sure that the air vents are clean and clear.
Edited by jgraham, 19 January 2019 - 08:13 AM.
#6 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 19 January 2019 - 10:02 AM
Correct, nothing is wrong. The cooler is not specified to reach some absolute temperature, only a drop of (approximately) 35-40 degrees below what it would have without cooling (i.e., the ambient temperature).
As jgraham mentions, as soon as your cooling power hits 100% your camera temperature will not be stable anymore, but vary with the ambient temperature.  And constant is much more important than low.  Just make sure you take darks at the same temperature!
#7 birddog99
birddog99
Posted 19 January 2019 - 11:28 AM
Got it. Thanks, guys
#8 Alex McConahay
Alex McConahay
  • Loc: Moreno Valley, CA
Posted 19 January 2019 - 11:36 AM
Put your camera in the freezer in the kitchen, and see how cold it can get. It should be getting to -15 or so without much power at all. This is a test to see if it has the cooling capacity.
Alex
