Orion the Hunter at 50mm f/2.8
dslr imaging Orion astrophotography
17 replies to this topic
#1 BQ Octantis
BQ Octantis
  • Loc: Red Centre, Oz
Posted 23 January 2019 - 05:11 AM
Still clearing out old data. I had four reasonably sharp, unguided shots of the Orion asterism through my Nifty Fifty Mk1 from December 2017. With some careful tweaking, I could bring out a little of the background detail:
Orion the Hunter
Orion the Hunter (Asterism), 2017-12-21, 54˚ elevation
Canon 50mm f/1.8 Mk I@f/2.8, Canon T3i (unmodified)
4×30 sec@ISO 800, 50×darks + 20×flats
Skywatcher SkyView Pro EQ Mount (unguided)
Aligned & stacked in Lynkeos 2.10
Processed in Photoshop CS5 w/Annie's Astro Actions v7.0
Full sensor view, scaled to 1600×1067
Tropic of Capricorn, NT, Australia
I think my flats at 50mm need some work…
BQ
  • zjc26138, nofxrx, jstrandberg and 5 others like this
#2 Clete
Clete
  • Loc: Tomball, TX
Posted 23 January 2019 - 03:51 PM
That's a killer photo!
I'm totally doing one!
When you say that your mount is "unguided", do you mean no autoguider or that the mount doesn't track the stars at all?
Given the exposure time, I'm guessing the latter but I just wanted to make sure.
Edited by Clete, 23 January 2019 - 03:52 PM.
#3 BQ Octantis
BQ Octantis
Posted 23 January 2019 - 04:08 PM
Cheers, mate!
You are correct—I meant "no autoguider", just sidereal track. At the time, I only had the Skywatcher two-axis motor kit installed that had no autoguider port. I've since upgraded to the GoTo motor kit.
BQ
#4 Clete
Clete
  • Loc: Tomball, TX
Posted 23 January 2019 - 04:41 PM
Cheers, mate!
BQ
Cool!
One question - does the autofocus work or did you just set the focus at infinity or what?
#5 jstrandberg
jstrandberg
  • Loc: Prescott, AZ
Posted 23 January 2019 - 07:05 PM
I love this.  There is actually quite a lot of nebulosity visible in the shot.
#6 BQ Octantis
BQ Octantis
Posted 24 January 2019 - 02:24 AM
Cool!
I don't have a Bahtinov for the 50mm, so I do manual focus on a bright star with Live View at 10x zoom. I stop down (~f/4 or so) and hold down the f-stop simulator button on the body while trying to bring star to a point. The focus point is when the thin fringe around the star changes from green to magenta (or disappears).
BQ
#7 Clete
Clete
  • Loc: Tomball, TX
Posted 24 January 2019 - 08:22 AM
BQ
I tried it last night and found that I couldn't get it to focus very well at all until I figured out to stop it down. F/4 was the magic number.
I didn't get a lot of subs because it took forever to figure out the focus and because my session was cut short by dew starting to form on the camera lens (not to mention the Gibbous Moon coming up). I got several 30 sec shots though so I'll stack those up and see what it looks like.
I also played around with the exposure time and found that I could get 120 sec shots with next to zero star trailing so I took some of those as well.
If the stacked images look promising, which I'm betting they will, maybe I'll do another night's worth of data collecting.
Even with the focus fighting me like a wet cat, I still enjoyed the heck out of doing it. That was the first time I had ever thought that my 50mm lens was worth a nickel. Thanks for a great idea!
Clete
#8 BQ Octantis
BQ Octantis
Posted 24 January 2019 - 04:08 PM
Clete
No worries, mate! I look forward to your output.
Wide open (f/1.8), my 50 struggles with coma at the center and strange star shapes at the corners. But stopped down to f/2.8, the coma is gone and the corners are passable. The field size makes it pretty unique—it's produced my best shot of the full extent of the LMC to date.
BQ
#9 Clete
Clete
  • Loc: Tomball, TX
Posted 24 January 2019 - 05:31 PM
BQ
I'm so envious of the stuff you guys can see down south. I've never seen the LMC with my own eyes before. Maybe I'll get to go way south on vacation one of these days.
That's another cool shot, by the way. I wonder what this 50mm lens would do with the Andromeda Galaxy?
#10 Clete
Clete
  • Loc: Tomball, TX
Posted 24 January 2019 - 07:41 PM
So, here's my attempt to copy your image...
I sort of rushed the stacking and processing job. I stacked every 30s sub I took, meaning I didn't weed out the bad ones.
This is 84 30s subs at ISO 1600, stacked with 10 darks and 14 flats.
Taken on a Canon EOS SL2 with an Astronomik CLS filter and a Canon 50mm lens at f/4
The light pollution was truly horrendous and I'm not sure but I think I may have messed up the flat frames which left a terrible glow 3/4 of the way around the outside of the image. I got a lot of it subtracted out and I cropped out what I could of the rest but there is still that bright area on the right side of the image that I can't get rid of.
I used Photoshop CS2 with no astronomy specific tools.
https://www.dropbox....190124.jpg?dl=0
Edited by Clete, 24 January 2019 - 08:04 PM.
#11 BQ Octantis
BQ Octantis
Posted 25 January 2019 - 03:40 AM
Pretty clean stars corner to corner. The histogram needs a little stretch, though. Using the Curves function (believe this is in CS2), I could bring out quite a bit of detail in the Horsehead, Flame, and Orion Nebulas; just had to reduce the saturation or the reds were overdriven. Unfortunately, the 8-bit JPEG significantly limits the histogram expansion. There was also some sort of pattern around the Orion Nebula…did you have some sort of filter on the lens?
BQ
  • mikewayne3 likes this
#12 BQ Octantis
BQ Octantis
Posted 25 January 2019 - 04:35 AM
A 50mm gives you 25˚ FOV on an APS-C sensor. The Andromeda Galaxy wouldn't take up much of the field, but enough to be interesting IMO. It's below the horizon for me now (and only 25˚ above the horizon at best), so I couldn't say.
The core of the Milky Way at zenith alone is worth a trip to the Tropic of Capricorn. I am fortunate to have seen it for the first time right at zenith just after stepping out of a tent in the middle of an unpopulated Australian Outback, 150 km from the nearest artificial light—I'm even more fortunate that I then captured three 30-sec subs to prove it. The experience bordered on spiritual: I almost passed out when I saw it, and I'm sure I involuntarily uttered some sort of religious gibberish just to recover…
BQ
  • Clete likes this
#13 Clete
Clete
  • Loc: Tomball, TX
Posted 25 January 2019 - 12:29 PM
BQ
No, no filter. I caused that weirdness with my rushed processing job trying to substract out the super crazy light polution that was causing a terrible gradiant across the image. I've figured out that I did something wrong with the light frames (I don't know what) and its cleaner when stacked without them.
I'm reading up on how to process this image better and will try again when time allows.
I'd love to get you the original file straight out of DSS. I'd be interested to see what someone who knows what the heck they're doing can pull out of it.
Edited by Clete, 25 January 2019 - 12:31 PM.
#14 BQ Octantis
BQ Octantis
Posted 25 January 2019 - 06:43 PM
You don't need exotic methods or actions to bring out the brighter nebulosity. Just use the Photoshop Curves function (Image -> Adjustments -> Curves)—a simple 3-point curve works wonders:
I typically do two or three passes to find the right contrast curve; I'll then use Color Balance to improve the color quality.
The exotic methods and actions help with finer detail, noise reduction, and star sizing.
BQ
#15 Clete
Clete
  • Loc: Tomball, TX
Posted 26 January 2019 - 08:30 AM
BQ
What do you mean by "two or three passes"?
Does that mean you make the same (or similar) curves adjustment two or three seperate times?
#16 BQ Octantis
BQ Octantis
Posted 26 January 2019 - 08:42 AM
Exactly as you state. Similar curve adjustments but in smaller increments with each pass. As I approach my final image, I'm pretty much on the straight line.
BQ
  • Clete likes this
#17 Clete
Clete
  • Loc: Tomball, TX
Posted 27 January 2019 - 10:45 AM
I keep messing around with this image. I discovered a program called Regime that took care of the gradient really well but I think at the expense of Barnard's Loop.
I'm still not really happy with this one, it feels over stretched. But, its better than before. At least you can see the Flame & Horse Head Nebulae. Every time I process it, it comes out a little different so maybe I'll keep playing with it.
I can't wait till I have another clear night so I can get some better data to work with!
RG Orion 190124 1600X900
Edited by Clete, 27 January 2019 - 01:13 PM.
#18 BQ Octantis
BQ Octantis
Posted 27 January 2019 - 06:29 PM
You've got 42 minutes of data, so you should have enough to pull out a bit more detail already (I only had 2 minutes). You might try longer exposures/higher ISOs to boost Barnard's Loop; you might also might try much shorter exposures to bring out Trapezium.
Keep messing around…it's how we learn!
BQ
  • Clete likes this
Also tagged with one or more of these keywords: dslr, imaging, Orion, astrophotography
