Meade LX70: $199
Meade mount
341 replies to this topic
#326 Pat Rochford
Pat Rochford
Posted 12 June 2019 - 01:11 PM
The drive arrived an hour ago (UPS) from Scope Essentials in British Columbia, the price shipped was $78.12 USD.  No customs charges.  Double boxed, plenty of packing materials and all the parts were there.  Mounting hardware and tools included. Nice instructions ...  pictures and words!
About ten minutes to install it, seems to work fine.  Will know for sure the first clear evening. As mentioned earlier in this thread, the only screw-up in the design of the mount, is the inability to disconnect the cable connection at the motor without removing the motor assembly cover.  I'd be a little peeved if it were necessary to do this often, but since I can't see any need to do so, I probably won't lose any sleep over it.
The hand box has an on/off switch, north/south switch & reversible 2x and 8x sidereal speed buttons.  A green LED lights up when the box is turned on and becomes red when any of the buttons are pushed.  Tomorrow I'll swing by Lowes and pick up some heat shrink tubing to run the power and hand box cables through.  Should dress things up a bit and prevent dangling cables from catching on other 'stuff'. It's powered by 4 D-cell batteries in pouch that hangs where ever you decide to put it.  I have mine hanging beneath the eyepiece tray/spreader at the moment.
I'll post a picture in the next day or two.
Here's the single axis drive on the LX-70 (supporting an AT102ED). As mentioned above, I added 1/2" heat shrink tubing to the power and hand box cables.  I also glued a hook to the top of the hand box, something that really should have been designed into the system.  Works well under the stars.  Good value for the money and good service from the dealer.  All is right with the world.
Edited by Pat Rochford, 12 June 2019 - 01:22 PM.
  • Terra Nova, clearwaterdave, brentknight and 1 other like this
#327 clearwaterdave
clearwaterdave
  • Loc: Western Maine
Posted 12 June 2019 - 04:18 PM
Pat.,that looks good..,neat an tidy.,Doesn't that 102 just "belong" on this mount.,.I was out last night with this pair.,I used a Baader zoom most of the night.,tooo much fun.,
  • Jaimo! likes this
#328 Pat Rochford
Pat Rochford
Posted 12 June 2019 - 07:32 PM
Thanks Dave.  Yes sir, these two will be together for as long as they live.  And this marriage was blessed by the bank!
  • Terra Nova and clearwaterdave like this
#329 Pat Rochford
Pat Rochford
Posted 13 June 2019 - 09:39 AM
What I did to solve the problem of not being able to disconnect the RA cable without removing the cover was I bent the metal arm holding the plug-in socket so the socket would line up better. I removed the socket and arm before bending and then just bent the arm a little with a pair of pliers. Took a couple tries but I got it to line up better so now I can plug and unplug it easily.
Reading your post kind of made me feel like Forrest Gump … "I'm not a smart man".  I don't know why this fix didn't occur to me, I usually figure these things out rather quickly.  At any rate, many thanks for the idea.
It took me a few attempts as well.  Bending the bracket down just a bit placed the tab on the plug in the clear, but at the same time it forced the plastic cover out just enough to catch the RA locking knob as that shaft rotated.  Several 'adjustments' later I finally hit on the right amount of bending and twisting for everything to be as it should.
  • clearwaterdave likes this
#330 clearwaterdave
clearwaterdave
Posted 13 June 2019 - 02:56 PM
Between the badly placed screw and the unreachable plug.,the motor cover is pretty much a pain on this mount.,I'm sure glad the rest of it is so darn nice.,.lol.,
  Thanks again to the OP for the heads up.,and to Terra for the thumbs up.,waytogo.gif .,
  • Terra Nova likes this
#331 AhBok
AhBok
  • Loc: Lakeland, TN
Posted 13 June 2019 - 05:11 PM
The mount is basically very good, but the smaller things like the motor cover and alt az knobs colliding make me think this was a design quickly thrown together to make use of existing parts, etc. Apart from that, I am very pleased with the purchase and believe a few simple workarounds can mitigate some of the shortcomings. So far I’ve replaced the alt az knobs with some nicer ones from ADM (but it doesn’t totally eliminate the crashing into each other.) I also placed a small chrome flat washer under the screw head for the plastic motor cover to give it a bit more support.
#332 earlyriser
earlyriser
  • Loc: Cincinnati
Posted 07 August 2019 - 06:40 AM
Does anyone know if the LX-70 will accept a CGE dovetail bar? I'm guessing it won't, but I thought I'd ask since I just bought a used OTA with that type of mounting bar. Trying to confirm I need to order a CG-5 dovetail bar to replace it.
#333 Astrodave
Astrodave
  • Loc: Centreville, Va. USA
Posted 07 August 2019 - 07:19 AM
No, these vixen/cg5 clones always come with vixen style saddles which are much smaller width than the CGE/Losmandy rails. ADM might make a replacement saddle for it but it would be more than half as much as the mount itself.
  • AhBok likes this
#334 earlyriser
earlyriser
  • Loc: Cincinnati
Posted 07 August 2019 - 07:55 AM
That's what I figured. I'll order a V-type rail since that is only $30.
#335 clearwaterdave
clearwaterdave
Posted 20 September 2019 - 06:05 AM
I just did a short tracking test just cuzz.,I put Rigel under the crosshairs in a 23mm ep and tracked for 45 mins. It was still right behind the x.,
 My test was to see if by just using the 2 marks I put on the deck for the tripod would be good enough to just set the scope on and go without checking level and polar alienment each time.,I think I'm good to go.,lol.,
  I mostly will track if I want to view one thing for a while.,like luna or a planet at high power.,or when sharing the view.,which is not very often.,Gotta go shut it off.,got it on luna now.,cheers.,enjoy your day.,
  • eros312 likes this
#336 Terra Nova
Terra Nova
  • Loc: Under the Blue Moon of Kentucky
Posted 30 September 2019 - 04:26 PM
Here's another, reasonably economical approach to improving the LX70 saddle.  The saddle plate (in the first picture below) can be had for about $36 on eBay, and the white dovetail plate was included with the mount.
Two bolts connect the parts together, and the notch in the dovetail plate makes for a very secure, nonslip attachment.
I've used one of these saddle plates on another mount, and have found they hold my C8 very securely.
Best regards,
Paul
Nice clamping jaw. My only problem with this solution is that you are raising the scope’s center of gravity about an inch. Not a problem with a small, light OTA but becomes incrementally more of a problem the heavier the scope gets.
#337 groupoid
groupoid
Posted 01 October 2019 - 10:05 PM
My mount actually came with a small V-type dovetail plate included.
#338 jcj380
jcj380
  • Loc: 42N 88W
Posted 16 October 2019 - 09:37 AM
Side question - will an LX70 fit on a 3/8-in standard photo tripod?
I put my TW1 on a Manfrotto and much prefer it over the stock Synta (?) tripod.
#339 earlyriser
earlyriser
  • Loc: Cincinnati
Posted 26 October 2019 - 03:26 PM
Does anyone know the size of the power port connector? Looks like maybe a 5.5x2.1mm connector. My old LXD55 drive used a 5.5x2.5mm, but the center pin looks smaller on the LX70 drive.
Edited by earlyriser, 26 October 2019 - 03:28 PM.
#340 M57Guy
M57Guy
  • Loc: Southern California
Posted 21 November 2019 - 10:34 PM
Power mine with a 5.5x2.1mm connector from a 12V supply through this https://www.amazon.c...s/dp/B07BSFSW8N throttled back to 6V.
Edited by M57Guy, 21 November 2019 - 10:35 PM.
#341 M57Guy
M57Guy
Posted 21 November 2019 - 10:36 PM
#342 Etrsi_645
Etrsi_645
  • Loc: Schererville Indiana
Posted 27 April 2020 - 01:30 PM
Just got a Polemaster for my LX70. I'm visual only but due to an old neck injury, I crouch down no more for polar alignments.
First off, I got the universal adapter and tried attaching with velcro to the uncovered polar opening; that was a no go--too spongy of an attachment. Next was Krazy Glue; that seems to be working well so far. I'll let it sit for 24 hours before attaching the camera.
I won't be using the drive hand pad, but rather rotating the axis by hand. My estimate is that it would take 15 minutes to rotate the axis 30 degrees at max 8x speed. I will not be locking/unlocking the axis during this. The scope balance is good enough that it stays put when released.
Is this all gonna work?
Now, just need some clear weather!
Sent from my SM-G960U using Tapatalk
Also tagged with one or more of these keywords: Meade, mount
