7.5" diameter f3.7 LENS - what to do
4 replies to this topic
#1 scout72
scout72
  • Loc: SF Bay Area
Posted 13 February 2019 - 11:31 PM
I have no idea what the original use was- it is an air spaced doublet in a very nice machined cell...I am thinking ---wide field sweeper, but wondering if it is worth it to mount given the coma this is going to have- anyone used a similar lens?
#2 Sean Cunneen
Sean Cunneen
    Let Me Think
  • Loc: Flossmoor Il.
Posted 13 February 2019 - 11:38 PM
I don't know about your lens specifically, but most show bad correction as they were for photographic use and corrected in yellow light. At f 3.7, there will be lots of crazy color and only the very center will be in focus. Usually, anyways...
  • scout72 likes this
#3 starcanoe
starcanoe
  • Loc: Gulf Coast, Panhandle of Florida
Posted 13 February 2019 - 11:49 PM
Rig up a temp tube/board. Mount the lens on one end....focuser on the other.
Probably horrible at f3.7. But stop it down so that it more like a 4 inch f8, use a 50 mm plossl, and might make a darn nice wide field scope. Might not even be too bad at medium powers.
#4 Ian Robinson
Ian Robinson
  • Loc: 33S , 151E
Posted 14 February 2019 - 04:07 AM
Some of these are military surplus (ex WW1 , WW2, and more recent wars).
If it's from an old aircraft mounted aerial camera , it's going to be a very good astrocamera with a very flat focal plane that's huge.
http://alag3.mfa.kfk...enses/200mm.htm
Is it a The Perkin-Elmer Type I Aerial Camera Lens, for 9x18 in plates/film
Photos of it will help people ID it for you.
Edited by Ian Robinson, 14 February 2019 - 05:21 AM.
#5 Jeff Morgan
Jeff Morgan
  • Loc: Prescott, AZ
Posted 14 February 2019 - 10:02 AM
That would make a very interesting scope for a NV eyepiece. With a H-alpha filter, color correction is not a factor (you're only letting in 656nm.) And it could be very good with a 640nm long pass filter for clusters and galaxies.
If you don't have a NV eyepiece, I suppose you could apply the same principles and build a scope dedicated for O-III use. Unfortunately, list of large O-III targets (the scope would not have much focal length) is pretty small.
