How to guide by platesolving scientific images
14 replies to this topic
#1 PeterWar
PeterWar
  • Loc: Roses, Girona (Spain)
Posted 15 February 2019 - 04:22 PM
Greetings,
My 10 Micron GM 3000HPS has encoders and is quite precise, allowing for an unguided 180 second image exposure with an error way below my seeing. I'm using CCD Commander+Maxim DL for image capture with good results, but guiding adds another level of complexity that I would like to avoid.
I'm wandering if there's a way to guide by platesolving scientific images during an image session. Ideally I would like to make 300 images of 120 seconds each without guiding, but still maintain adequate centering of the target star.
Is this possible?
Edited by PeterWar, 15 February 2019 - 04:25 PM.
#2 Charlie B
Charlie B
  • Loc: Sterling, Virginia
Posted 16 February 2019 - 08:24 AM
Greetings,
Is this possible?
One way is to stop imaging about every 50 frames and re-center. SGP could automate this.
Charlie B
#3 han59
han59
  • Loc: the Netherlands
Posted 16 February 2019 - 06:34 PM
If your mount maintains stability below the seeing, lets say 2 arcsecond each 120 seconds, so 60 arcseconds/hour, why do you need centering?  You could image for hours without any action.
Nevertheless, plate solving/Astrometric solving could help. You could either use plate solving for make a perfect model of your setup (mount+telescope) in advance or to center each hour if required.  For Maxim DL your probably are little restricted to PinPoint and scripting is difficult in MaximDL if I remember well.
  • psandelle likes this
#4 psandelle
psandelle
  • Loc: Los Angeles
Posted 17 February 2019 - 11:28 AM
Greetings,
Is this possible?
Are you platesolve modeling before unguided tracking already? That's one of the strengths of the 10Micron; its modeling is built into the mount. I can do unguided imaging all night (and do; only 10 minute exposures, but I've taken longer subs to check). Takes care of most of the repeatable hysteresis problems as well. Just make sure you have a really solid rig.
Paul
  • PeterWar likes this
#5 sdufoer
sdufoer
  • Loc: Bruges, Belgium
Posted 18 February 2019 - 05:07 AM
I have pretty much the same issue as you.  I do some kind of "autoguiding" with the platesolving.  I know how much PE my mount has and hence I know my maximum exposure time so the error stays below pixel resolution.  For my EQ6 and VMC200L I have a max exposure time of 30s.
In CCDcommander I have a subroutine for every object that loops like 300 times and the actions are:
-move to RA/DEC
-Platesolve 20s with sync/reslew
-take 10x 30s images
Then after that I have a skip-to at time/altitude/or RA angle to break the subroutine.  I do this for every object (variable stars mostly).  The platesolves barrely show up on the end results.
With my big setup (ASA DDM85 with 16" cass), the mount model is enough to keep an object centered for several hours.  I do here the same strategry for all-nighter objects: I take 2 hours worth of images, then a quick platesolve to recenter the OTA, and so on the whole night on the same object.  Works flawless.
Here it is with simple copy/paste of 3 actions:
-move to RA/DEC
-take image 60x120s
-platesolve 10s, sync reslew
-move to RA/DEC
-take image 60x120s
-move to RA/DEC
-take image 60x120s
-move to RA/DEC
-take image 60x120s
-move to RA/DEC
-take image 60x120s
-move to RA/DEC
-take image 60x120s
This is 12 hours worth of observing time !!
#6 daw316
daw316
Posted 18 February 2019 - 10:22 AM
Solve/sych/slew is a great way to stay centered!  Do have/care about field rotation issues?
#7 PeterWar
PeterWar
Posted 20 February 2019 - 02:01 PM
-move to RA/DEC
-move to RA/DEC
-take image 60x120s
-move to RA/DEC
-take image 60x120s
-move to RA/DEC
-take image 60x120s
-move to RA/DEC
-take image 60x120s
-move to RA/DEC
-take image 60x120s
-move to RA/DEC
-take image 60x120s
Thanks, that could work as a partial solution. I have a 60 star model in my 10 Micron with virtualy no polar aligment error, so field rotation is not an issue. I want to use this feature for exoplanet photometry and would be great to have a tool to do this without loosing 10-20 seconds platesolving as they could be important to ascertain the correct shape of the transit.
#8 StarmanDan
StarmanDan
  • Loc: Where the stars at night are big and bright...
Posted 20 February 2019 - 04:18 PM
You don't need super precise tracking to do exoplanet photometry.  My club has a 24" f/9 scope and camera that produces a 10x10 arc min FOV.  We have no guiding on our scope and don't have the fancy absolute encoders like on your mount which allows it to do very accurate unguided tracking.  As long as the stars are reasonably round in each exposure you're good.  Our tracking is good enough that we simply monitor the exposures every 5-10 min and mark where our target star is, and if we see it starting to drift, we manually adjust the tracking rates to keep the target reasonably centered in the camera.  But with your mount, the encoders should get you very good tracking without needing to guide.
#9 PeterWar
PeterWar
Posted 21 February 2019 - 03:50 PM
StarmanDan I highly recommend the book Exoplanet observing for amateurs, it's freely avaliable at Bruce Gary website, here's an abstract of what the book says on this topic:
When autoguiding is not used the star field will drift across the pixel field and cause systematic errors
that vary during the observing session; all star flux ratios throughout the image will vary. These
systematics won’t be completely removed by the flat field calibration because no flat field is perfect.
I found this to be true, Dennis Conti's excelent guide also states that Autoguiding is essential for research-grade exoplanet observing in order to minimize the drift of
the target and comparison stars.
I think with the help of encoders in my mount I could accomplish the same thing, sending guiding pulses every 120s by platesolving the scientific image could suffice.
Edited by PeterWar, 21 February 2019 - 03:53 PM.
#10 sdufoer
sdufoer
Posted 22 February 2019 - 02:12 PM
My mount needs at least 5s to settle after a correction, so you will lose this time as well.  You could write a program that opens pinpoint+mount driver and reads the most recent fits in the CCDcommander folder and do a platesolve + sync.  You could trigger this program as "run external program" from CCDcommander.  I have a similar self-written program that does allsky blindsolving since it's not a feature in CCDcommander.
Another (maybe OT) question: how do you process the exoplanet transit data?  I load the data into TRESCA.  http://var2.astro.cz...resca/index.php.  Their software makes the curve itself.
This is one of my observations: http://var2.astro.cz...0392783&lang=en
#11 PeterWar
PeterWar
Posted 22 February 2019 - 05:22 PM
Thats very interesting feedback, thank you Sjoerd. I used to model-fit the data using TRESCA, but I have a better option now which is AstroimageJ. I strongly recommend Dennis Conti's guide to help you understand how to use it.
Edited by PeterWar, 22 February 2019 - 05:26 PM.
#12 PeterWar
PeterWar
Posted 14 May 2019 - 08:06 PM
I found a program that does just this, it's SIPS image processing. It came with my Moravian G4-9000 camera, I'm testing this now. Find an abstract from the manual
Guiding Tab
Guiding tab is intended for inter-image guiding. This feature is designed for modern mounts, which are precise enough to keep tracking with sub-pixel precision through the single exposure, and irregularities only appear on the multiple-exposure time-span. Such irregularities are caused by many sources (polar misalignment, differences in refraction calculations, mount and telescope mechanical deformation etc.) and cannot be completely avoided. Inter-image guiding then performs slight mount position fixes between individual exposures of the main camera, which eliminates “traveling” of the observed objects through the detector area during observing session.
Because this guiding method uses main imaging camera, it does not use another guiding camera and naturally does not need neither OAG nor separate guiding telescope to feed the light into it. This also brings another consequences:
The Guide using: Guiding camera/Telescope option is missing from inter-image guiding setup, as the inter-image guiding always use Telescope PulseGuide interface. If the particular telescope driver is not equipped with such interface, inter-image guiding cannot be used. Especially older mounts often rely on the “Autoguider port” only and thus require the opposite port, typically offered by the guider camera. But such mounts are often not capable to keep tracking for any reasonable long exposure without regular guiding, so this limitation is not that important.
The Position detection: Brightest star/Plate solution is also missing as the guiding method is always Plate solution. This means stars are searched within the whole image and matched with the stars on the reference frame (reference frame is the first frame taken after the inter-image guiding is turned on). This method results into more reliable guiding compared to brightest star method, as the mutual offset between frames is calculated as an average of offsets of all detected and matched stars. Brightest star method also requires frame cropping around the chosen star, which is naturally not possible in the case of the main camera.
Hint:
It is necessary to detect at last 3 stars within the image to be able to use Plate match. If less stars can be detected, this method of guiding cannot be used.
Warning:
Searching for stars is crucial for proper function of the inter-image guiding. One algorithm as well as one set of parameters for star searching is used within all SIPS tools (there is a second set of star search parameters, intended for guiding camera, but this is not relevant in this case). It is recommended to use the Astrometry tool to check whether stars within the image can be properly detected and possibly to modify star searching parameters. This procedure as well as the searching parameters are thoroughly described in the Astrometry tool chapter.
#13 555aaa
555aaa
    Vendor (Xerxes Scientific)
  • Loc: Lynnwood, WA, USA
Posted 15 May 2019 - 07:50 AM
Thanks for posting this method, Peter. It's interesting that when we use this method we don't actually have to plate solve to a catalog, we only have to solve the match of one image to the next and then nudge the mount the appropriate distance.
- Bruce.
#14 PeterWar
PeterWar
Posted 15 May 2019 - 09:04 AM
- Bruce.
Thank you, the first results are encouraging:
#15 psandelle
psandelle
  • Loc: Los Angeles
Posted 15 May 2019 - 01:06 PM
Interesting, especially with a 10Micron mount.
Paul
