Found a way to get the mount my CCD camera at the same angle every time
12 replies to this topic
#1 nateman_doo
nateman_doo
  • Loc: Dirty Jersey
Posted 17 February 2019 - 08:14 PM
I used to have such troubles mounting my camera, that I could never get it at 90°.  Always was off.  So the other night I placed it as accurate as I could and I finally got it at 90°.  I knew I had NO desire to move the camera if I couldnt get that back again, so I designed an adapter that I can attach to the camera so if I take it out for transport I can get it back in the same spot.  (+/- 1° or so).
Starting to cut out the adapter out of some Delrin I had laying around:
Finished cutting and level installed:
A 4-40 screw (with helicoil installed) pulls the unit together and clamps it into place:
installed pictures:
The unit can go on and off in seconds.  All I have to do initially is plate solve until I get the camera at the desired angle and then put it on, and rotate it until its level and lock it in with a few turns of the screw and I never have to worry about it again.  Seems to be a universal CCD camera size with the body being roughly over 3" in size.   Not sure if anyone else had problems, but it was a simple part to design and machine in the course of an evening while I was imaging M13.  The delrin is good to probably -40°, and in any case there is zero stress on the part.  Really is solid, yet subtle.
  • Scott Mitchell, psandelle, elmiko and 3 others like this
#2 iwannabswiss
iwannabswiss
  • Loc: Charleston SC
Posted 17 February 2019 - 08:24 PM
Very nice way to solve your problem.  I just painted a line on the camera and focuser and match up the lines.
  • psandelle, Carl N and Mark326 like this
#3 nateman_doo
nateman_doo
  • Loc: Dirty Jersey
Posted 17 February 2019 - 08:33 PM
I thought about that, but I thought there would be a better way that wouldnt wear off.  I found the use of micro levels very handy.  I installed them on the RA, and the DEC, and I found that with a good polar alignment, when I started up my computer and clicked on an object in stellarium it was actually in the imaging.  details here
When I clicked on the moon when first turning everything on, this is how close it got to the moon:
  • elmiko likes this
#4 BenKolt
BenKolt
Posted 17 February 2019 - 10:16 PM
Very nicely done!
#5 tjugo
tjugo
Posted 17 February 2019 - 10:24 PM
Another way to do it is by platesolving your images. When you plate solve, along with the image scale and central coordinates you also get the rotation angle.
José
#6 nateman_doo
nateman_doo
  • Loc: Dirty Jersey
Posted 18 February 2019 - 12:49 AM
José
thats how I knew I had 90°, I just wanted a way to get it back to 90° every time I take it off and put it back on.  That was step 1 of my process, get the camera to 90°, then never have to do it again.
#7 buckeyestargazer
buckeyestargazer
    Vendor - Buckeyestargazer.net
  • Loc: IN, USA
Posted 18 February 2019 - 08:40 AM
I bought several tiny bubble levels (only about 1/2" long and 1/8" thick) and simply used a dab of silicone sealant/adhesive to mount it to the back of the camera.  Works great!
  • elmiko likes this
#8 elmiko
elmiko
  • Loc: Arizona
Posted 18 February 2019 - 10:04 AM
Good job Natemandoo! I like it.
#9 CharlesW
CharlesW
    Long time member
  • Loc: Chula Vista, CA
Posted 18 February 2019 - 10:39 AM
It’s a nicely done piece of work but I have to ask, why not just leave the image train attached to the scope? Your bubble only really works if your counterweight shaft and saddle are dead-nuts vertical.
#10 nateman_doo
nateman_doo
  • Loc: Dirty Jersey
Posted 18 February 2019 - 10:44 AM
If I go anywhere, I break down my scope:
it fits like a chap in this amazon hard case, so at least now I have a way to get it back to the way it was.
normally that is more my style (and thats what I did the the RA portion of my mount) but I liked not having the draw on the camera, scope or putting glue on the camera if I ever want to sell them later on.  The next owner may not have the same needs or tastes as I do.
  • elmiko likes this
#11 Dan Crowson
Dan Crowson
  • Loc: O'Fallon, MO
Posted 18 February 2019 - 10:51 AM
I leave my camera attached as CharlesW mentioned. It also allows me to go for months (or more than a year) on a set of flats. When I used an AT6RC (it looks like yours is the 8), I had just modified the styrofoam it came in to allow for the camera (and moonlite focuser).
Another option is to use P-Touch tape. I've printed out three strips of -------- . I attach those when the camera is in place and then use a blade to cut where it comes apart. This makes it easy to line up if I remove the camera to clean.
Dan
#12 nateman_doo
nateman_doo
  • Loc: Dirty Jersey
Posted 18 February 2019 - 12:11 PM
There were no real surfaces that could mate up that I could put tape, or even a mark if I wanted to that would give me the accuracy of the level.  Also nice that it fits multiple camera bodies like ZWO as well.
Also I could make another and put it on at 90° for other objects, or just design a new one with a level on the side, which I think I just may do.  There are things (like the double cluster) that look better imaged at 180° vs 90.
Edited by nateman_doo, 18 February 2019 - 12:25 PM.
#13 buckeyestargazer
buckeyestargazer
  • Loc: IN, USA
Posted 18 February 2019 - 04:09 PM
It's for this reason that I have small bubble levels on the RA and DEC axes of the mount.  For the most part I do keep the image train intact.  But I switch out cameras sometimes and of course for travel setup the bubbles are nice.  I've gotten it so that I can still re-use flats even if I break down the kit (as long as I don't notice new dust spots etc).
