Field flattener for ED80
12 replies to this topic
#1 JeffreyHorne
JeffreyHorne
Posted 19 February 2019 - 11:45 AM
Hello friends, and thanks in advance.
My my father is letting me borrow his ED80, so I can get some wider FOV shots than with my C8.
He’s mentioned, and I’ve read, that I’d probably want to use a field flattener with the ED80 if I’m going to do imaging.
Explore Scientific’s 2” field flattener is on backorder for months (heard directly from them.)
What brand/type of field flattener do you recommend for the ED80?
Jeffrey
#2 joelin
joelin
  • Loc: Saratoga, CA
Posted 19 February 2019 - 12:02 PM
I'd say this one: https://www.telescop...ctor/p/5195.uts ?
It flattens and reduces slightly. It's threaded so camera connections will be solid.
Edited by joelin, 19 February 2019 - 12:03 PM.
#3 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 19 February 2019 - 12:37 PM
The TeleVue 0.8x worked OK on my ED80.
https://agenaastro.c...r-trf-2008.html
#4 JeffreyHorne
JeffreyHorne
Posted 19 February 2019 - 02:38 PM
Do either of you know how using a field flattener/corrector with a refractor like this matters if using a full frame vs crop sensor?
#5 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 19 February 2019 - 03:53 PM
The blur diameter is something like 14 pixels in the APS-C sensor corner without the flattener (assuming Canon 60D 4.3 micron pixels).  For full frame sensor the blur is about 36 pixels in the corners.  So either way you want a flattener.
#6 Darrenlh
Darrenlh
  • Loc: Alberta, Canada
Posted 19 February 2019 - 04:40 PM
I can personally recommend this flattener also from Orion:
https://www.telescop...yword=flattener
It comes in at a reasonable $139, but isn't a reducer. It works excellent with my Nikon D7200 (APS-C) and Skywatcher 600mm ED80 F7.5
I get sharp stars all the way to the edge.
  • cobestluc likes this
#7 OrionSword
OrionSword
  • Loc: Colorado
Posted 26 February 2019 - 06:22 PM
The Hotech SCA did a good job on the ES ED80 I had, now using it on the Stellarvue SV80ST.  You need 55mm of back focus from the flattener to sensor.  Agena says 56mm which does not match the packing sheet.
https://agenaastro.c...-flattener.html
Edited by OrionSword, 26 February 2019 - 06:23 PM.
#8 droe
droe
  • Loc: Fenton, Mi
Posted 27 February 2019 - 11:33 AM
I did a comparison of the Orion FF and Reducer here. Hope it helps.
https://www.cloudyni...or-es-80mm-apo/
#9 GraySkies
GraySkies
  • Loc: Ontario, Canada
Posted 28 February 2019 - 10:53 AM
I have a William Optics ZenithStar 80mm f/6.8 II ED APO Refractor and I use the WILLIAM OPTICS FLATTENER 4 - 0.8X REDUCER with great results
https://optcorp.com/...cer-flattener-4
[It replaced a Meade Series 4000 Focal Reducer / Field Flattener I was using previously which now sits on a shelf]
#10 Steve OK
Steve OK
  • Loc: OKC, OK
Posted 01 March 2019 - 11:20 AM
I just got the one made for Orion for my ED80, the Orion Field Flattener for Short Refractors.  It seems to do a good job.
Here's an image with it in place.  I don't have a "without" image to compare, but this image has tighter stars at the edges than I ever saw without it.
click for a larger image:
Steve
#11 jstrandberg
jstrandberg
  • Loc: Prescott, AZ
Posted 27 March 2019 - 07:36 PM
The link to your review does not work.
#12 Tristarcapt
Tristarcapt
Posted 28 March 2019 - 06:41 AM
Jeffrey
I have that field flattener and it is not intended for use with dslr's only dedicated astro cameras.  It has only 44mm of backfocus.  I have a ES ED102CF and I use this one:
https://www.astronom...refractors.html
It works great with my Canon/ED102 combo and should work with any f6 to f8 refractor.  It has a 57mm (+or- 4mm) of backfocus.
I use it with this Canon t-ring (which happens to be a t-ring OAG combo)
https://www.teleskop...the-T-ring.html
but should work with any t-ring (depending on camera and type of t-ring you're using you may need a small spacer).  As long as the distance from the sensor on your camera (marked on the top of the camera) to the end of the threads of the field flattener is between 53 and 61mm you should be good.
#13 droe
droe
  • Loc: Fenton, Mi
Posted 28 March 2019 - 06:58 AM
oops sorry.
